GSXR750/1157 hybrid
P.
PostPosted: 22:30 - 06 Sep 2009    Post subject: Reply with quote
would brakes and forks need changing?? maybe tyres, although they are pretty damn wide as is!!
PostPosted: 23:01 - 06 Sep 2009    Post subject: Reply with quote
You probably could get away with using the 750 carbs with a suitable jetting kit. My GSXR11 has some 38mm carbs on it that I think came from a GSXR750.
PostPosted: 23:55 - 06 Sep 2009    Post subject: Reply with quote
Have you thought about putting rf900 barrels and pistons on it? I think they fit. I would have though the bandit engine to not have anywhere near the top end of the 750. The extra cc should give you some more grunt while keeping the top end.
PostPosted: 00:01 - 07 Sep 2009    Post subject: Reply with quote
RF900 is a water cooled engine, while his 750 is an oil cooled one. Loads of differences.
The 1200 Bandit engine is probably a very easy fit. Just need some spacers for the rear engine mounts and a few minor odds and sods. The Bandit is one of the few bikes that gains a serious amount of power just from changing the silencer let along the full system, and with that it would easily have way more top end than the 750 but with massively more in the mid range. GSXR cams in the Bandit engine would help even more.
PostPosted: 00:51 - 07 Sep 2009    Post subject: Reply with quote
Fair enough, I think it must be the newer 750's that you can put the rf900 barrels on.
What sort of power would a lightly fettled bandit 12 make?
bandit
PostPosted: 02:10 - 07 Sep 2009    Post subject: Reply with quote
I have seen people do your mode...
The problem is going to be the cost Sad / you time i love the gsxr,s...
But instead of spending £1000 plus and all the work Sad , just go and buy a Bandit with all the hard work done Very Happy ..
( getting cheaper at the moment Very Happy Very Happy )
I have owned lots of 1200s the best engines are the pre 2001 i have 2002 model with out lots of modes its more like riding a 600.
(they changed timing, carbs etc etc etc)
My last 1999 model with dyno jet kit gsr750 early inlet cam and exhaust, moded air box , head skimmed 5 degree advance etc,(138bhp at wheel) moded suspension would pull from 20mph in top Very Happy and give me the best fun i ever had as well as trying to smack me in the face with the bars every time i wacked the throttle open in 1st & 2nd Evil or Very Mad , better than sex well just Confused ...
Even after owning R1 and Busa and others Laughing Laughing Laughing the Bandit with Modes always Rocks my Boat in the £1 for power stakes..... Twisted Evil Twisted Evil Twisted Evil
It can be the loving sister or the Evil mother in law all in one package,,,, Let The Fun Begine Cool Cool Cool Cool
All the best with your project Thumbs Up
b12 cg125 gt250 kh125 ss50 cg150 CG250cc
PostPosted: 08:42 - 07 Sep 2009    Post subject: Reply with quote
You will get 10+hp just from changing the can, and getting on for 20hp from a full system. More easy bolt on gains from some cams. Bit over £300 for a set of 1216cc pistons, bringing the compression up a bit. 150hp is not that difficult to get (about what mine manages having had the work done by Big CC).
PostPosted: 08:58 - 07 Sep 2009    Post subject: Reply with quote
To those apart from Keith and BlueX5:
The GSXR 7-11 is a commonly built bike to try to get the advantages of the 750 with the advantages of the 1100 and none of the downsides. Apparently it works surprisingly well, and a lot of the old skool professional stunt guys used 7/11s.
https://oldskoolsuzuki.info/uk_lee/Thebikes/711/711Buildup.htm
The above thread might be useful BlueX5... Smile
British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
SW Motech Shop UK
PostPosted: 09:47 - 07 Sep 2009    Post subject: Reply with quote
Brilliant. It gives me a warm fuzzy feeling knowing that there are still people out there who want a 7/11. I still think the 750M is one of the best looking bikes ever.
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
PostPosted: 12:43 - 07 Sep 2009    Post subject: Reply with quote
BLUEX5 wrote:
especially as good 1100's are £2.5k plus.
Have they gone up that much? When I bought mine (April last year) prices for an oil boiler were from about £800 to about £2000. I paid ~£1600 for mine, and that includes paying extra for it as it had a longer Spondon swinging arm fitted (could have had a nice standard one for about £1300). For £2500 I would expect one in concourse condition.
PostPosted: 15:12 - 07 Sep 2009    Post subject: Reply with quote
In which case they have rocketted in the last year. £1300 was the going price for a pretty nice K locally when I bought my L. At £1600 the L came with the Spondon arm (which I wanted for what I bought the bike for), 3 spare sets of carbs (a set of 36mm carbs, set of 38mm carbs and a tatty set of 36mm flat slides), dyna 2000 ignition, load of spare gaskets, lockup clutch kit and some other stuff I have forgotten about.
sickpup
Old Timer
PostPosted: 16:44 - 07 Sep 2009    Post subject: Reply with quote
MarJay wrote:
Lee's a mate of mine. Buys bits off of me as well. Wink
sickpup
Old Timer
PostPosted: 20:08 - 07 Sep 2009    Post subject: Reply with quote
There's good reason to use the B12 bottom end, the cam chain is considerably stronger than the GSXR11 item. also the B12 has a different output shaft to the 11K motor that is suitable for use with a 180 rear tyre.
Although iirc the B12 is a lower compression motor than the 11 add a 750J/K head which has the same size valves as the 11 and a wider bore than the long stroke 750 and the compression will end up slightly higher than the 11 lump so overall a slight power increase.
1216 big bore although not that big a jump ups the volumetric efficiency nicely giving a bigger mid range.
You will as far as I know need an 11 exhaust.
Carbs I would use the 38mm mikuni's. Factory do a kit for them on the 11 engine, pretty sure the airbox won't fit as the 11/B12 is a taller lump. The best inlet manifolds are the ones off of the 750L/M, straighter inlet path. I have several sets kicking about, some take off that haven't been used and are almost new condition.
If you were feeling up to it a crank balance can make a hell of a difference to smoothness on these lumps, they are good as standard but a little extra help never goes amiss.
temeluchus
PostPosted: 09:46 - 08 Sep 2009    Post subject: Reply with quote
If its anything like my slabby 7/11, its pretty easy.
I used RS36's for mine.
PostPosted: 10:21 - 08 Sep 2009    Post subject: Reply with quote
sickpup wrote:
Things
That's some serious knowledge you have their sickpup. Thumbs Up
I've only ever seen standard GSXR1100s, and judging by the size of the steering damper they were rather wayward. (For those that haven't seen it, similar to a bicycle pump.) That bike was mint and standard and only cost £1500 a couple of years back.
temeluchus
PostPosted: 11:43 - 08 Sep 2009    Post subject: Reply with quote
It wont, the intake angle is a little different and the GSXR11/B12 motor is a fair bit taller. I just fitted the obligatory K&N double pods.
Its worth drilling and tapping the tops of the outer K&Ns (or S&B or whatever) and fitting a rain cover as the right hand pod can let water in when parked on the sidestand.
PostPosted: 15:17 - 08 Sep 2009    Post subject: Reply with quote
I kept the stock airbox on my Bandit when the engine was tuned. Guy who did the carb setup wasn't too happy as he thought he could get it better on single filters, but it went well, was fairly quiet and fairly subtle (gave a dyno guy a shock when he ran it without knowing about anything more than the exhaust). I did chop the lid of the airbox up though rather than keeping the small stock intake.
Currently it has some 40mm flat slides which mean it is running on K&N filters (and a chopped up airbox to hold the chrome covers and hide the air filters).
temeluchus
PostPosted: 15:25 - 08 Sep 2009    Post subject: Reply with quote
BLUEX5 wrote:
Meh....would be a stretch as I've spent the last 15 years telling everyone how shit pod filters are. I'm still not convinced the standard airbox can be matched for all round running, especially with a K&N drop in filter.
Its more of a case that the airbox simply wont fit with the B12 engine in place.
treat yourself to a nice set of RS36's, work lovely with pod filters. Also perfectly tractable on the road. I disabled the accellerator pump on mine and was still great. I averaged 40-45mpg on a cruise with them on my 1100G.
The last post was made 14 years, 277 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.08 - MySQL Queries: 13 - Page Size: 140.74 Kb
