yamaha aerox problem
dave36
PostPosted: 16:26 - 15 Jan 2012    Post subject: yamaha aerox problem Reply with quote
have a aerox 50cc, changed piston and rings ,new plug, new battery, new stantard exhaust, cleaned the carb in parts washer and blew it out with air line so its spotless, fresh fuel init, starts straight away soon as put full throttle on it dies any suggestions
at106
PostPosted: 16:33 - 15 Jan 2012    Post subject: Reply with quote
Is the choke on and have you let te bike warm up? Also is it jetted correctly and is the air mixture screw set to factory specs?
dave36
PostPosted: 16:41 - 15 Jan 2012    Post subject: aerox problem Reply with quote
ticks over lovely had it running idle for half hour so well warmed, has manual choke, never touched the jet settings, would clutch have anything to do with it
Martay
PostPosted: 16:51 - 15 Jan 2012    Post subject: Reply with quote
Doubt it is a clutch causing the problem, it certainly sounds like a fueling issue.
Is there an air leak between the carb and cylinder? With it idling, spray some WD40 or simmilar flamable subtance around the intake. IF the revs change then theres a leak.
Did you put the float back in correctly?
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
st3v3
PostPosted: 18:11 - 15 Jan 2012    Post subject: Reply with quote
As above, sounds very much like a fuel isssue.
Clutchy
PostPosted: 18:47 - 15 Jan 2012    Post subject: Reply with quote
As said, sounds like a fueling issue, however it wont hurt you to check to see if the air box (where the air filter is housed) is properly connected or just hanging off, i had this problem, as soon as i used any revs it would bog and cut out, not sure if its the same lay out on a yam but definitely worth a try, or the tube out going from the air box could have perished, or as stated most likely disconnected.
razzamaytee
PostPosted: 04:50 - 16 Jan 2012    Post subject: Reply with quote
did you find the problem out because i am having the same problem but with a yamaha aerox 100, i was just riding and it started back firing and then cut out, but now it start but asoon as i throttle it, it dies out and wont start up again for about 5 minute
dave36
PostPosted: 07:22 - 16 Jan 2012    Post subject: yamaha aerox problem Reply with quote
float is is correct.. all tubes are good, air box is on right not loose at all, i,ll try WD40 today see what happens
dave36
PostPosted: 22:29 - 21 Jan 2012    Post subject: aerox problem Reply with quote
tried WD40 around intake revs didn,t change.. its reving all the way on full throttle then dies off then revs full again and dies off keeps doing this, thinking it could be running to rich
Clutchy
PostPosted: 23:59 - 21 Jan 2012    Post subject: Reply with quote
LONG SHOT but the gasket on the head might not be sealing properly, i had a similar problem regarding this today.
Martay
PostPosted: 02:29 - 22 Jan 2012    Post subject: Reply with quote
Its fueling, 100%.Fuel is being restricted so the fuel bowl is not filling quick enough.
Next check would be the fuel tap. Remove the fcuel pipe and vacuum pipe from the from the carb and suck on the vacuum one. Fuel should flow quickly out the other, a trickle is no good.
Also try running it with the filler cap removed, a breather could be blocked.
martyn279
PostPosted: 12:07 - 23 Jan 2012    Post subject: Reply with quote
it deffently sounds like a jetting problem mate try buying a set of jets and swapping and changing till it runs hope this helps
matyn
currently riding :
APRILIA RS 125 FULL POWER 33BHP
pzeppieri
PostPosted: 16:42 - 14 Apr 2012    Post subject: Reply with quote
well buy a 72 jet just incase that is the problem and then make sure that none of your pipes are being restricted, for instance if you have taken all your panels off and your seat box when you put them bk on they could be restricting a pipe. check that your air box is on tight and with a little clamp and that the carbreta is screwed on tight.
The last post was made 12 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.99 - MySQL Queries: 17 - Page Size: 79.12 Kb
