Author |
dave36 |
dave36 Renault 5 Driver
Back to top |
at106 |
at106 Brolly Dolly
Back to top |
dave36 |
Back to top |
Martay |
Martay World Chat Champion
Posted: 16:51 - 15 Jan 2012 Post subject: |
Doubt it is a clutch causing the problem, it certainly sounds like a fueling issue.
Is there an air leak between the carb and cylinder? With it idling, spray some WD40 or simmilar flamable subtance around the intake. IF the revs change then theres a leak.
Did you put the float back in correctly? ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express |
Back to top |
st3v3 |
st3v3 Super Spammer
Back to top |
Clutchy |
Clutchy World Chat Champion
Posted: 18:47 - 15 Jan 2012 Post subject: |
As said, sounds like a fueling issue, however it wont hurt you to check to see if the air box (where the air filter is housed) is properly connected or just hanging off, i had this problem, as soon as i used any revs it would bog and cut out, not sure if its the same lay out on a yam but definitely worth a try, or the tube out going from the air box could have perished, or as stated most likely disconnected. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Guide to pass your test with no lessons! |
Back to top |
razzamaytee |
razzamaytee L Plate Warrior
Back to top |
dave36 |
Back to top |
dave36 |
Back to top |
Clutchy |
Posted: 23:59 - 21 Jan 2012 Post subject: |
LONG SHOT but the gasket on the head might not be sealing properly, i had a similar problem regarding this today. ____________________ Malaguti F12 Phantom-Dead, Suzuki AY50- Dead, NRG power DD LQ, CBR125.
Back to top |
Martay |
Posted: 02:29 - 22 Jan 2012 Post subject: |
Its fueling, 100%.Fuel is being restricted so the fuel bowl is not filling quick enough.
Next check would be the fuel tap. Remove the fcuel pipe and vacuum pipe from the from the carb and suck on the vacuum one. Fuel should flow quickly out the other, a trickle is no good.
Also try running it with the filler cap removed, a breather could be blocked. ____________________ Eat well, poo hard
Back to top |
martyn279 |
martyn279 Derestricted Danger
Back to top |
pzeppieri |
pzeppieri L Plate Warrior
Back to top |
The last post was made 12 years, 17 days ago. Instead of replying here, would creating a new thread be more useful? |
