TV electrical Plug too short - Help
Will the great TV power Cord Bodge job Work?
Hell Yea!
60%
 60%  [ 6 ]
Hell No !
0%
 0%  [ 0 ]
Hell You Gonna Die Boy!
20%
 20%  [ 2 ]
Hell ! Hell ! Hell ! Hell ! Hell ! There I said it!
20%
 20%  [ 2 ]
Total Votes : 10
Rogue_Shadow
PostPosted: 23:47 - 06 Feb 2013    Post subject: TV electrical Plug too short - Help Reply with quote
Elllooo
I'm helping my Dad "Modernise" the spare bedroom at home.
New carpet, bed, paint ect but also providing a new electrical plug and aerial as the room originally had only a single plug.
We also decided to mount the TV to the wall nearest these new plugs and this is when we hit a problem.
The standard length of the TV's plug cord, is too short to reach the new plug from the wall mount. When it does it leaves the cable under alot of tension and running diagonally across the wall Thumbs Down
Real modern
Evil or Very Mad
The Question:
As the power supply is "hard wired" into the TV unit, simply buying a new cord isn't a option.
So would it be viable, to cut the cord just after it leaves the TV to join and extend the cord to any length? Ultimately hiding the joint behind the TV and the cable in some capping.
My Dad is a very knowledgeable guy, if I die knowing 50% of what he does I'll consider myself lucky. But he wasn't completely confident this idea would work, or at least not cause any negative effects for the TV.
So I ask for the knowledge of the BCF collective
What say ye? Rolling Eyes
Thank You
(Side note: The TV is an old LCD flatscreen, nothing fancy but by no means a relic. It is years Out of warranty and for its purpose we cannot justify buying a new TV)
keggyhander
PostPosted: 23:49 - 06 Feb 2013    Post subject: Re: TV electrical Plug too short - Help Reply with quote
Computer says no.
Of course the cable can be extended.
Nexus Icon
PostPosted: 00:10 - 07 Feb 2013    Post subject: Reply with quote
Yeah, just get a joining block from B&Q or similar.
Not chocolate block connectors. Laughing
Greetings from Shitsville!
J.M.
PostPosted: 00:14 - 07 Feb 2013    Post subject: Reply with quote
Of course, but do it properly. Soldering iron & heat shrink. Should be fine. Thumbs Up
2004 R1 & 2018 XSR900
Rogue_Shadow
PostPosted: 00:18 - 07 Feb 2013    Post subject: Reply with quote
keggyhander wrote:
Computer says no.
We can't all know everything, But that's why we have the internet hey Smile
Seen enough choc blocks in my line of work to know to throw those in the skip Laughing
Can easily get hold of shrink down material, seems excessive to me but what the hell Thumbs Up
Cheers for the help Keggy,Nexus & J.M Thumbs Up
Old Git Racing
PostPosted: 00:28 - 07 Feb 2013    Post subject: Reply with quote
Just get a 4 plug cable extension then you can plug your hair drier and curling tongs in while you watch TV.
OGR
stuarthouston
PostPosted: 01:14 - 07 Feb 2013    Post subject: Reply with quote
If it's going to be a permanent feature, I'd be tempted to run a spur from the ground level socket up to a single socket behind the TV. It'd be a neater and safer solution than bodging the cable and it'll be plug and play whenever your dad has to replace the TV. Depending on the construction of the walls, you might even be able to fish the cable up to the correct height so you don't have to ruin your plaster. Thumbs Up
Ariel Badger
PostPosted: 01:17 - 07 Feb 2013    Post subject: Reply with quote
Twist them together and wrap in sellotape.
PostPosted: 02:28 - 07 Feb 2013    Post subject: Reply with quote
Honestly?
Is this a real question?
https://fc08.deviantart.net/fs70/f/2012/267/b/4/i_don__t_want_to_live_on_this_planet_anymore_by_warn0238-d5fs2g9.jpg
hmmmnz
PostPosted: 06:17 - 07 Feb 2013    Post subject: Reply with quote
ffs man, undo the tv box, remove short cable from the connectors inside the tv, buy a longer lead and connect it to the internal connectors, put tv back together,
do not join the frigging cable,
the humans are dead
I kick arse for the lord
CaNsA
PostPosted: 06:22 - 07 Feb 2013    Post subject: Re: TV electrical Plug too short - Help Reply with quote
Rogue_Shadow wrote:
My Dad is a very knowledgeable guy But he wasn't completely confident this idea would work, or at least not cause any negative effects for the TV.
What were his reasons?
Al
PostPosted: 08:21 - 07 Feb 2013    Post subject: Reply with quote
Hmm I can't see anyway around the problem, I think the best thing to do is buy a new house.
Yamaha FZR400RR 3tj
My Instagram Thingy
Skudd
PostPosted: 08:31 - 07 Feb 2013    Post subject: Reply with quote
Instead of cutting the cable at the TV end, cut it at the plug end. Go to B&Q they have a loads of connectors for the job.
I have exteded lots of things at the unit, hoovers, paint strippers, mowers etc, but these days the way they are fixed together they are not meant to be opened once made.
PostPosted: 08:34 - 07 Feb 2013    Post subject: Reply with quote
Put a socket in closer to the TV.
PostPosted: 08:49 - 07 Feb 2013    Post subject: Re: TV electrical Plug too short - Help Reply with quote
Rogue_Shadow wrote:
What say ye?
I say ye better be female, because if you're not you've lost a metric fuckton of manpoints.
Suntan Sid
PostPosted: 10:18 - 07 Feb 2013    Post subject: Reply with quote
SERIOUSLY?
https://www.eyetek.co.uk/images/super/extension_lead_gsm.JPG
FFS!
PostPosted: 10:22 - 07 Feb 2013    Post subject: Reply with quote
Sellotape? Oooo - look at Mr "Health and Safety"
As long as they don't touch (much) they'll be OK Smile
_Will_
PostPosted: 10:45 - 07 Feb 2013    Post subject: Reply with quote
https://weknowmemes.com/wp-content/uploads/2011/11/are-you-fucking-kidding-me-face.png
Suffering Bike Withdrawal.
robs321
PostPosted: 18:34 - 07 Feb 2013    Post subject: Reply with quote
My Dad used to do this, we had the old black and white telly in our bedroom wired like this for years when I was a kid! Thumbs Up
angryjonny
PostPosted: 19:01 - 07 Feb 2013    Post subject: Re: TV electrical Plug too short - Help Reply with quote
The things on the wall are called "sockets". Best leave the electrical stuff to your dad, eh Wink
Walloper
PostPosted: 19:20 - 07 Feb 2013    Post subject: Reply with quote
Can only offer the following advice mate.
https://www.youtube.com/watch?v=Sm3_qEMTdc4
ScaredyCat
PostPosted: 19:27 - 07 Feb 2013    Post subject: Reply with quote
https://dl.dropbox.com/u/188253/triple_facepalm.jpg
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
Walloper
PostPosted: 19:38 - 07 Feb 2013    Post subject: Reply with quote
You total fckin muppets....
You do know that the colour information in the signal CANNOT pass through sellotape??
So all that time yous HAD a colour TV but Dad's 'Bodge it and Scarper' job had yous all fooled.
Rolling Eyes
Very Happy
Flatbadger
PostPosted: 19:56 - 07 Feb 2013    Post subject: Reply with quote
Step 1 - Cut off TV power chord.
Job done Thumbs Up
You're in ISIS
Rogue_Shadow
PostPosted: 20:50 - 07 Feb 2013    Post subject: Reply with quote
Reading what I typed up last night ... Yea Potato!
To all the memes/picture posters:
Yes, this was a serious question last night Laughing but you cannot leave this planet, we simply cannot allow that.
Oh and
Plug
https://www.hyjo.co.uk/ekmps/shops/hyjoltd/images/5-amp-uk-plug-2262-p.jpg
Socket
https://www.royalhigh.edin.sch.uk/departments/departments/CDT/ahgc_0405/models/socket_render2b.jpg
Thumbs Up I wont even try to cover up the extreme levels of retardation, by ticking these boxes.
https://cdn.bikechatforums.com/files/the_warped_posting_checklist.jpg
I can only hope the internetz can forgive me and that one day, way into the future ... I can roll you up in a carpet and throw you over a bridge Rolling Eyes
Enjoy!
The last post was made 11 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.18 - MySQL Queries: 15 - Page Size: 135.81 Kb
