Author |
Pol Anorl |
Pol Anorl Banned
Posted: 17:10 - 13 Jan 2014 Post subject: |
CHR15 is a myth it is now proven. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
Back to top |
TQ |
TQ Trackday Trickster
Back to top |
P. |
P. Red Rocket
Back to top |
chris-red |
Back to top |
virus |
virus World Chat Champion
Back to top |
CHR15 |
CHR15 Turbo nutter bastard
Posted: 20:13 - 14 Jan 2014 Post subject: |
1216cc
8.8:1
forged pistons
forged rods
knife edged polished crank
1052 steel clutch with 2 stage lock up
stock gearbox
mistral engineering ported head on stock valves
108/108 timing
gsxr1000k2 tb's
siemens deka iv 630cc injectors
microsquirt v3 running v2xtra firmware
dyna 2.2 ohm coils with bosch 2 channel driver
gt2860 (not the rs version... yet!)
some sort of intercooler perhaps atw just as an interesting project
will probably start out around 15psi to be safe.
some of those things aren't relevant to power output.
before i really thrash it, it could do with new shells though. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
Back to top |
_Iain_ |
_Iain_ Banned
Posted: 14:32 - 15 Jan 2014 Post subject: |
On 15psi of boost?
Nah.
I'm guessing at 275. A busa will run 300+ on 15psi of boost. ____________________ Please be aware that the above post may be full of complete nonsense.
Back to top |
TwoWheelsDail... |
TwoWheelsDail... Scooby Slapper
Back to top |
P. |
P. Red Rocket
Posted: 15:22 - 15 Jan 2014 Post subject: |
_Iain_ wrote: |
On 15psi of boost?
Nah.
I'm guessing at 275. A busa will run 300+ on 15psi of boost. |
Said before he claimed all specs.
240hp. |
Back to top |
virus |
Posted: 18:47 - 15 Jan 2014 Post subject: |
sounds like the makings of 300hp there, nice spec BTW, how much did the porting cost? Im thinking of getting another bandit head to skim, port and cam until I can afford something a bit more boosted.
Cheers
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
Back to top |
hmmmnz |
hmmmnz Super Spammer
Back to top |
CHR15 |
Back to top |
stevo as b4 |
Back to top |
CHR15 |
Posted: 20:13 - 16 Jan 2014 Post subject: |
dunno about boost control yet. i have the abaility to run it, dont know if i will.
tried to fire it up tonight. made some very impressive bangs and blew the tb's off the engine a few times. also managed to backfire so hard it undid the bolt that holds the sprag clutch onto the crank lol.
i got pissed off with it so its been put to bed for today.
i was sat having a beverage and it occurred to me that i might have set the wrong tooth#1 offset.
tooth#1 is 80 clockwise degrees before tooth#tdc1 so i entered 80 into the offset. i think i should have entered 280 instead because your always supposed to measure from tooth#1 to tdc1 in the running direction of the engine which is clockwise.
which would explain the lulzy explosions / backfires because the plugs would be firing just after bdc exhaust on 1 and bdc compression on 4.
on the plus side theres no fuel leaks and it doesn't leak too much oil (for a bandit engine)
will play again tomorrow. ____________________ Turbocharged drag thing / project death weapon / GK73A
Back to top |
CHR15 |
Posted: 18:14 - 17 Jan 2014 Post subject: |
i tried again today with the 280 degree setting and it just blew the tb's and undid the starter clutch again.
ive got a windowed ignition cover somewhere and a timing light so thats tomorrows job.
the only other thing is that the revs seem to jump around like mad when cranking and the 'sync' light flashes from red to green.
ive done like 2000 miles with that rotor / hall sensor so i dont understand why its playing up.
is it possible to wire a hall sensor in backwards? ____________________ Turbocharged drag thing / project death weapon / GK73A
Back to top |
spikenipple |
spikenipple Crazy Courier
Back to top |
chris-red |
Posted: 21:52 - 17 Jan 2014 Post subject: |
I showed my girlfriend that video of the backfires on FB, I explained that you had built the majority of the bike yourself and had made many parts completely from scratch. Her response, "If he went to all that trouble why won't it start?" ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
Back to top |
CHR15 |
Posted: 21:57 - 17 Jan 2014 Post subject: |
you can tell her its because i may have wired the vr sensor into the opto1 input channel and the signal is bypassing the vr conditioning circuit which is why its losing sync whilst cranking.
or it could be because she didn't make any goddamn sammiches yet. ____________________ Turbocharged drag thing / project death weapon / GK73A
Back to top |
Doovy |
Doovy World Chat Champion
Posted: 13:20 - 18 Jan 2014 Post subject: |
I've just seen a video of it running ____________________ Yamaha RXS 100 > Honda CD 250 > Honda Hornet 600 > Honda CBR 600RR > Yamaha RXS 100 > Kawasaki ZX6R J2 > Yamaha FZ1 |
Back to top |
CHR15 |
Back to top |
P. |
P. Red Rocket
Posted: 20:42 - 18 Jan 2014 Post subject: |
Huge amounts of win. |
Back to top |
Nobby the Bastard |
Back to top |
CHR15 |
Posted: 18:42 - 19 Jan 2014 Post subject: |
Back to top |
Howling Terror |
Howling Terror Super Spammer
Back to top |
P. |
P. Red Rocket
Posted: 20:24 - 19 Jan 2014 Post subject: |
Did you get that all on video? The milling part |
Back to top |
The last post was made 10 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
