Project Electric (Push) Bike - Now With Video
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: 21:30 - 30 May 2014    Post subject: Reply with quote
How much did the fire-proof carpet cost? Very Happy Very Happy Very Happy
Aff
PostPosted: 21:35 - 30 May 2014    Post subject: Reply with quote
Shhh. Don't jinx it.
Electric Bike Project
Aff
PostPosted: 11:17 - 31 May 2014    Post subject: Reply with quote
OK, first batch of 50 charged.
I have changed my setup a bit. I spaced them out so much because it made it much easier to put together, the magnets are so strong that it is constantly tying to turn itself into a big ball of firey mess.
The downside of this is that I cant pass much current through the nickel strip and I dont have enough to layer t up over that distance.
The strip was hitting about 50 deg C at about 15A. So I spent some extra time and done this:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0605_zpsefbf12d1.jpg
This lets me put lots of layers of nickel strip to handle the current.
This has halved the temperature of the nickel strip:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0606_zpseae8ed79.jpg
Now I'm being held back by the croc clips. they get very hot above 15A and this charger is capable of 40A so I will try and do something about it so I can reduce my charge time. These amperage levels are nothing for the cells, they are all rated at about a 1C charge rate, meaning that this lot of cells can be charged at about 130-140A, so charging at 15A or even 40A is absolutely nothing to them.
These also turned up this morning:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0604_zps37be3e0a.jpg
Not so hopeful about these, but they were cheap and I have plenty of good cells now.
:edit: Changed all the croc clips to soldered on 10AWG wire, now changing at 25A, stip is at about 30 deg C.
Aff
PostPosted: 19:56 - 02 Jun 2014    Post subject: Reply with quote
These just arrived from Chinaland:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0621_zpsaa5feb28.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0622_zps9e1e1385.jpg
They are a battery spacer, similar to what is used in the Tesla Electric cars (they also use 18650 cells). They have dovetails on all sides so can be configured in anyway you want.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0623_zps9d20eb21.jpg
And then you just cap the ends of the cells with them.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0624_zps66450072.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0626_zps0d49c4f0.jpg
They make the pack very strong, whilst also leaving an even air gap between all the cells to help with hotspots within the pack. The one I'm holding is a 4V ~25Ah cell.
I will configure them like this:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0627_zps61a8a91f.jpg
This is the same as my configuration on the V1 pack, 6s12p. So 24V ~25Ah. I will have 3 of these on the bike.
Aff
PostPosted: 17:12 - 06 Jun 2014    Post subject: Reply with quote
OK so everything has had its initial charge. I will be discarding any that loose voltage over a week or so.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0628_zpsda9fca31.jpg
The rest I will be splitting into packs of 12. Because I have such a mix of cells I will have to then discharge all these cells individually and check capacity, then I can match all the cells up and try and get a capacity of about 20Ah in each cell.
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0629_zps21e35975.jpg
Also to tryand solve my braking problem I bought this:
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0633_zpse2877f87.jpg
https://i1135.photobucket.com/albums/m637/Biles/EBike/IMG_0634_zpsb9ca1771.jpg
Its a bit of a beast. Laughing
stevo as b4
PostPosted: 20:03 - 06 Jun 2014    Post subject: Reply with quote
I like the trick new oversize disc!
Need to get a bigger disc on my Giant, as it's only a 160mm, which is a bit lacking at speed really. Thumbs Up
Gazz
PostPosted: 23:42 - 06 Jun 2014    Post subject: Reply with quote
This thread is fucking amazing. You are a genius!!! Thumbs Up
Cant wait for more updates.
What was the box thing for? (I know nothing of batteries or physics).
TT Zero for you next year my friend. Mugen wont stand a chance.
Aff
PostPosted: 08:35 - 07 Jun 2014    Post subject: Reply with quote
Cheers. Very Happy
Box thing?
KLR600
PostPosted: 19:54 - 07 Jun 2014    Post subject: Reply with quote
The bigger disc will definitely help but it's that Avid brake that is the main problem. I have 3 Avid brakes and they're all a bit rubbish once you really get going. For the kind of speeds you're going you should really be upgrading the brake as a whole. I'd look at something like a Shimano Saint or a Hope Tech 3. Yes they're expensive but I'd much rather have something like that on a bike that you'll be zipping around on at 40mph.
<Take Cool Photos!>
Aff
PostPosted: 19:57 - 07 Jun 2014    Post subject: Reply with quote
The actual braking force is fine, can still stoppie at most speeds (which I think is quite good considering all that weight at the back). It just has a ridiculous amount of fade.
I'm gonna give these a clean and a good bleed and see how things go. If not will have to upgrade. Cheers for the suggestions.
KLR600
PostPosted: 20:25 - 07 Jun 2014    Post subject: Reply with quote
The fade is not going to improve with those Avid brakes regardless of what pads you put in them or what disc you fit or what brake lines you have. Those Avids come OEM on a lot of low to mid range serious mountain bikes and they have a reputation for not being very good once you're out of the car park at the trail head. I'm pretty sure the only MTB brake brand that has a worse reputation than the low end Avids is Hayes so I'd avoid those too if you go to upgrade.
Like I said, I have 3 of those Avids and they all fade before the end of a DH run lasting a few minutes. I have an old Hope M4 on the front of my DH bike though and it's great. Consistent stopping power all day long with great feel.
<Take Cool Photos!>
Gazz
PostPosted: 21:01 - 07 Jun 2014    Post subject: Reply with quote
How much have you spent putting it all together?
Excluding the trial and error parts?
Aff
PostPosted: 22:36 - 07 Jun 2014    Post subject: Reply with quote
Really not that much.
If you don't include the bike (cost will vary massively) maybe about £250-300. Making my own battery saved a huge amount of money.
KLR, can you recommend any cheaper alternatives to the ones you mentioned? I can't really justify that cost and if the Avids are as bad as you say they are I imagine there will be plenty of better alternatives. Very Happy Thumbs Up
MattWadz
PostPosted: 23:00 - 07 Jun 2014    Post subject: Reply with quote
Avid Juicy brake?
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
Aff
PostPosted: 23:05 - 07 Jun 2014    Post subject: Reply with quote
MattWadz wrote:
Avid Juicy brake?
Yea, 3's I think.
PostPosted: 10:34 - 08 Jun 2014    Post subject: Reply with quote
If you wanted cheap, you could consider some sliding pin pit bike brakes - but chunky and you'd need to make a bracket etc.
But then, keeping adding more weight and you'll need more power. Which will need strong components. And... then you've got a pit bike, basically Smile.
PostPosted: 14:46 - 08 Jun 2014    Post subject: Reply with quote
What about those ice tech pads? Fade is because of heat right? Heatsinks on the pads = less heat = less fade
PostPosted: 15:07 - 08 Jun 2014    Post subject: Reply with quote
Hadn't seen them before, but yes - makes sense.
Could even add fins to calliper, presumably.
PostPosted: 00:10 - 09 Jun 2014    Post subject: Reply with quote
That wasn't aimed at you specifically, dunno why I quoted you!
KLR600
PostPosted: 00:15 - 09 Jun 2014    Post subject: Reply with quote
Honestly that Saint at £127 is going to be a good bet I reckon. I'm purposefully recommending DH/Gravity hydraulic brakes over trail/XC brakes as they strike a good balance between brake power and heat dissipation. To give you an idea, the top of the range Avids come in at around £150 each on Chain Reaction Cycles. You'd only really need a front brake too I reckon as that's where you'll be doing the majority of your braking anyway.
I suppose it's a bit pricey when you consider that you can pick up some used R1 blue spot calipers for less than £70 on ebay. It'd just be a shame to get a thread update where you've crashed into a hedge because you couldn't stop in time!
There are some offers about on second hand stuff too.
Hope M4 front brake 1
Hope M4 front brake 2
Hope M4 front brake 3
That was just a quick search of the first few results on ebay so I'm sure you could find a good deal with a bit of scouring. Make sure the caliper will fit your fork or that you have an adapter to make it fit though.
Saying all that, you might end up being fine with just this disc. I know if it was me and I was making something faster I'd be sure to think about slowing down faster too though Laughing Thumbs Up
<Take Cool Photos!>
PostPosted: 00:23 - 09 Jun 2014    Post subject: Reply with quote
Speaking of which, I once put an entire R6 front end on a push bike, though I only connected up one Brake disc I think - that had 'adequate' stopping power, even for the extra 40kg of weights I added to it, to simulate the sort of weight converting the rear end to R6 along with a few other bits would add. (Total weight around 76kg I think it was.)
Did get up the VERY steep hill behind my place ok, albeit very slowly - but still overtook the cyclist that had earlier overtaken me, but had got off to walk Smile.
KLR600
PostPosted: 23:56 - 09 Jun 2014    Post subject: Reply with quote
I remember seeing photos of that thing floating around on here years ago - wasn't it a yellow and black Carrera? Weren't you going to ride the London to Brighton thing on it? Laughing
<Take Cool Photos!>
PostPosted: 00:14 - 10 Jun 2014    Post subject: Reply with quote
Yea, that was it - never got around to finishing it, as with so many of my rides. Did do 10 miles or so with the weight above on it.
400bandit
PostPosted: 20:08 - 10 Jun 2014    Post subject: Reply with quote
https://www.chainreactioncycles.com/shimano-deore-m615-disc-brake/rp-prod108802
Got to be an upgrade on the avids, get good reviews too
PostPosted: 20:39 - 10 Jun 2014    Post subject: Reply with quote
I got one of those for the front of my hybrid - which is quite heavy with all the extra stuff I've got on it and normally full-ish panniers.
It does the job ok for my uses and is a little better than the cable brake it was replacing (I needed new pads anyway, so thought for an extra £20-25, I might as well get a whole new front brake system.)
But, think I'd be aiming higher for a bike that would likely have more stopping from speed.
The last post was made 9 years, 358 days ago. Instead of replying here, would creating a new thread be more useful?
Page 6 of 9
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 143.81 Kb
