Author |
nowhere.elysium |
nowhere.elysium The Pork Lord
Posted: 09:46 - 25 Jun 2014 Post subject: NC24 rebuild - Now for sale: see first post |
I need to sell this. I simply don't have the time to work on it now, and I need the garage space. If anyone's got a sensible offer, I'm all ears - I've got most of the bits needed to get this roadworthy now, barring tyres. It has the makings of being a very good bike, it just needs a level of time and attention that I simply cannot give it.
The good: decent collector box, engine spins up happily, tank isn't perforated, all corrosion is light surface rust, forks are decent (just want the seals replacing, which are included).
The bad: the throttle linkage is still stiff as buggery. This wants sorting properly - I've not had the time to do anything much about it, aside from diagnosing the issue. Realistically, it can be sorted by soaking it in a bucket of something volatile for a day or two, I reckon. The fairings are pretty bad - they're cracked completely along one side, and would need some serious work (as well as some mounting bits) to refit them properly.
Things that come with the bike:
I've got a set of brake lines that should fit it, along with a new set of fork seals and brake pads. There's also a set of replacement plug caps to go on there, and a spare top yoke. The air filter and oil look to have been new when the bike was laid up, so I wouldn't be too worried about that. I've also got a set of Abba stand adapters for it.
Things that the bike needs:
Tyres, fuel hoses, radiator cap, stem nut washer and a significant amount of TLC.
I've acquired an NC24 in remarkably good condition. The fairings are shagged, but the engine seems sound, as does the state of the wiring.
More to the point, the collector box and downpipes are in good nick.
https://farm3.staticflickr.com/2924/14500098331_dc2d9f9f68_b.jpg
So far, it wants a new radiator cap, new tyres, new fork seals, new throttle and clutch cables, a clutch lever, a battery, and a starter solenoid. I've got one of the tail fairing pieces, and from that I've managed (through the magic of 3D scanning) to work up a rough 3D model of it. I'm intending to machine a mould from that, so I can start prototyping replacement pieces for it.
https://farm4.staticflickr.com/3837/14480402406_bf7ea37ca9_b.jpg
On the left is the original 3D scan of it, and on the right are the initial attempts at tidying it up. Although it's not very visible in this picture, there are bands that run the length of the two pieces - that's to do with the way that the 3D software I'm using fits a mesh across a series of contours. The black stripes are the contour slices taken from the initial scan. I'm going to make a proper point of tidying up the contours before I even think about machining out the first moulds.
What I'm most likely going to do is design a customised set of fairings that eliminate the rear seat entirely - the front fairings are pretty comprehensively knackered, so I'm likely to just do away with them entirely, leaving me something of a free hand when it comes to the aesthetic of this bike. I know that the purists are going to whinge at me about it, but given that I got the bike for a paltry sum, I might as well make what I want of it, as opposed to trying to restore it to its original form. Once I've gotten the hang of putting together fibreglass fairing pieces, I may even go the whole hog and make carbon fibre ones.
This is also quite likely to be the bike that the digital dash goes on to. The SV had an inordinately complex setup going to its dash from stock, and I really couldn't be bothered to try and decode that much signal data, given that I was using the bike day-to-day. This one is a pure project bike for now, so I should have enough time to work on it properly - the only real constraining factor is money. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project
Back to top |
chris-red |
Back to top |
nowhere.elysium |
Back to top |
Carvel |
Carvel World Chat Champion
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
TUG |
TUG World Chat Champion
Posted: 23:54 - 27 Jun 2014 Post subject: |
Nice! ____________________ Haz ER-5, innit! |
Back to top |
Nick 50 |
Nick 50 World Chat Champion
Back to top |
nowhere.elysium |
Posted: 17:51 - 07 Jul 2014 Post subject: |
Well, got a bit more time to play with the NC yesterday, pre-SE meal.
As Robby has noted, this machine was somewhat lacking in terms of its previous storage location. Aside from the many, many metres of dead brambles I've had to pull from the machine, it looks like it's been subject to several spider extinction cycles.
https://farm4.staticflickr.com/3892/14597324875_ba18b3da17_b.jpg
Just fitted up the new starter solenoid (the original one was missing). Looks OK, so I decided to pull the battery and hook the bike up to a working one.
https://farm6.staticflickr.com/5577/14410688560_184fc0f4a3_b.jpg
To my delight, there appeared to be some form of forest-floor crust building up on the battery itself. Sort of a dessicated compost. Yum.
https://farm4.staticflickr.com/3884/14595402844_83abee51f1_b.jpg
That's the battery bay's cobweb collection after it'd been cleaned out - there was enough cobweb in there to make an audible ripping noise when I initially pulled the battery, most of which stuck to the battery, hence it not being visible in the previous photo. Suffice it to say that it was minging in the extreme.
Anyway - cobweb bonanza aside, I got the battery attached, and then Robby and I spent a long time trying to find the electrical fault. In doing so, we determined that a) the loom was in very good nick, and b) I'm an idiot. The electrical fault was entirely down to pilot error - I'd bolted the starter solenoid terminals on the wrong way round. Derp.
Once we'd rectified this minor cock up, the bike span over like a good'un, which was gratifying. The spark seems decent enough, although we only know this because it's missing a plug cap, so I've got to get hold of one of these, specifically:
https://farm4.staticflickr.com/3846/14597327205_a1a707b4cf_b.jpg
If anyone's got one going spare, please do give me a shout.
Other than that, the main issues are actually pretty minor: the fork seals have comprehensively shat themselves, which is fun.
https://farm6.staticflickr.com/5528/14595402994_94fdf55f51_b.jpg
This has led to the pads being unrecoverable, which is a bit annoying.
https://farm3.staticflickr.com/2920/14597325355_b2ec81903c_b.jpg
Reminds me of a certain GSXR a few years back, truth be told.
Despite the fact that a lot of the bolts have starting going brown, there's not been any major seizures yet - everything that we've had a go at has come out, although it's been a little reticent on occasion.
https://farm6.staticflickr.com/5493/14596675582_941b878e5d_b.jpg
And on a final note; behold the intact collector box!
https://farm4.staticflickr.com/3914/14595401324_90293ebc26_b.jpg
So, things that want doing:
Change over cables - the new ones are on their way to me.
Unstick the throttle - it's a bit jammed up at the carburettor end, which I'm not looking forward to.
Change over the fuel/breather hoses - radiator hoses and such actually look OK.
Check the tank for leaks.
Buy a radiator cap.
Replace the pads.
Replace the tyres.
Sort the lack of bodywork out. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
gavcarter |
gavcarter Could Be A Chat Bot
Posted: 18:04 - 07 Jul 2014 Post subject: |
Back to top |
Boxing |
Boxing World Chat Champion
Posted: 18:05 - 07 Jul 2014 Post subject: |
Would love a VFR next year. |
Back to top |
nowhere.elysium |
Back to top |
gavcarter |
Back to top |
nowhere.elysium |
Back to top |
gavcarter |
Back to top |
Robby |
Robby Dirty Old Man
Back to top |
MarJay |
MarJay But it's British!
Back to top |
Shaft |
Shaft World Chat Champion
Posted: 20:11 - 07 Jul 2014 Post subject: |
If it helps, I've found a couple of different plugs listed as standard, they are all 10mm thread/16mm hex. ____________________ Things get better with age; I'm close to being magnificent........
Back to top |
nowhere.elysium |
Posted: 21:01 - 07 Jul 2014 Post subject: |
C8EH-9s are the listed plug, which is a 10mm plug. The plug caps that are on the bike don't look like they're the stock units, so I'm a little bit nervous at this point. Best case scenario is that they're just oversize caps. Mediocre case is that all the threads have been recut for 12mm plugs. Worst, I'm looking at frankenplugs. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
gavcarter |
Back to top |
spikenipple |
spikenipple Crazy Courier
Back to top |
Nick 50 |
Posted: 20:22 - 08 Jul 2014 Post subject: |
I'll have a look in the garage in the morning to see if I have a plug cap lying about. My NC24 came with a few boxes of spares, but can't remember seeing one, but no harm in double checking.
Good progress though ____________________ Current Bikes: ZX7r 97 (Black Beauty), VFR400 NC24 (The banana)
First bike: A GZ125 Lemon....... |
Back to top |
nowhere.elysium |
Posted: 11:43 - 24 Jul 2014 Post subject: |
Got some replacement plug caps on order, along with a radiator cap. I'm going to check over the tank for leaks, and may even get it fired up and running by next week. Still got to order some fork seals though, and I need to sort out the throttle cables.
Pictures will follow. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
nowhere.elysium |
Posted: 08:13 - 29 Jul 2014 Post subject: |
Well, it would appear that the throttle linkage is seized, so the carbs have had to come off. The process of removing said carbs is vaguely documented at best, and I found myself slightly concerned by the fact that the best rundown of it used the phrase "...then lever them off with a length of wood..."
Yup, that's gonna want cleaning up.
https://farm4.staticflickr.com/3904/14790043763_9c6e328a57_b.jpg
The offending seized part:
https://farm3.staticflickr.com/2909/14769846572_fd4b95f72c_b.jpg
The rear of it is totally inaccessible in situ - hurrah for overly-compacted construction.
So anyway; off with the tank and the airbox:
https://farm4.staticflickr.com/3889/14790042213_4a9c158ff7_b.jpg
You can just about see on the left hand edge of that picture - there's a bracket there, with the cols mounted to it. Only one description of removing the carbs actually mentioned the fact that this needs to be removed - good thing I read around the subject a bit before attempting it, I reckon.
https://farm3.staticflickr.com/2896/14583535568_cff49e4340_b.jpg
The bracket in question. Two bolts to remove that, four more to free the coils off for added accessibility, and a shit-ton of cobwebs and dead foliage for good measure.
Still, using the 'pry off with a chunk of tree' method seemed to work well, since they came away from the bike with a relative* minimum of fuss.
https://farm4.staticflickr.com/3921/14767811014_832853d767_b.jpg
*Relative to every other carb bank I've had to sod about with in the recent past. On a scale of mildly vexatious to bastard hard, this one's somewhere around the realms of 'irritating'. The GS' carbs are doing gleeful cartwheels somewhere over the event horizon of 'fuck you, I won't do what you tell me'.
https://farm4.staticflickr.com/3913/14790042733_2d328a7c3e_b.jpg
The yawning chasm that is the spiders graveyard, after the initial cleanup. I couldn't stomach the 'before' photos, so you'll just have to stick with the 'after' one. The manifold rubbers are a bit on the stiff side, as is to be expected. There's also a bit of a scummy buildup on the front right cylinder - I'm not sure why that's the case, but I'm guessing that a closer inspection of the carb may reveal some information.
I'll be working on the carbs today, so with a bit of luck I'll have more progress to report later on. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
Back to top |
P. |
P. Red Rocket
Posted: 08:21 - 29 Jul 2014 Post subject: |
Back to top |
MarJay |
Back to top |
The last post was made 9 years, 306 days ago. Instead of replying here, would creating a new thread be more useful? |
