Triumph 5TA Engine.
St George
PostPosted: 15:35 - 11 Apr 2019    Post subject: Triumph 5TA Engine. Reply with quote
Can the 5TA engine which has the distributor be converted into points inside the front of the crankcase like the Daytona. If yes how much is involved re parts etc. Thanks.
Triton Thrasher
PostPosted: 16:44 - 11 Apr 2019    Post subject: Reply with quote
Ask on https://www.britbike.com/forums/ubbthreads.php/forums/4/1/triumph-bulletin-board
From my feeble memory, you need to change the timing cover and the exhaust camshaft.
Is it for an electronic ignition?
Rrrrrrrrrrrrrrrrrr
St George
PostPosted: 18:09 - 11 Apr 2019    Post subject: Reply with quote
Had Boyer in mind and cosmetics of the bike, HT leads everywhere, looks like an old car.
Triton Thrasher
PostPosted: 18:45 - 11 Apr 2019    Post subject: Reply with quote
Changing a Triumph camshaft is a lot of trouble to go to, for cosmetic reasons that will make the bike harder to sell.
If you do go that far, I’m getting good service from this Wassell/Vape electronic system, with a dual lead coil. https://www.feked.com/electronic-ignition-system-12v.html
Cheap (though Feked prices are ex-VAT) and looks more robust than Boyer components.
Rrrrrrrrrrrrrrrrrr
WD Forte
PostPosted: 18:54 - 11 Apr 2019    Post subject: Reply with quote
Just get one of these and no one will laugh at your HT leads
https://www.tomcc.org/ImageResizer/profiles/profile17.jpg/?width=960&hq=1
bikers smell of wee
steve the grease
PostPosted: 19:10 - 11 Apr 2019    Post subject: Reply with quote
You could use the points in the dizzy housing to operate a twin lead ( jap type) coil mounted under the tank. So you wouldn't have all the leads going everywhere.
I can confirm that to mount the points in the side you will need a later type cam and timing cover , oil seal, points backplate , cover etc etc.
To remove the cam you will have to drop the head off remove the pushrod tube and wedge the can followers to stop them dropping into the crankcase. It's a lot of work to lose a couple of leads.
St George
PostPosted: 16:46 - 12 Apr 2019    Post subject: Reply with quote
Discovered that the distributor was built by Kirby Rowbottom and the bike is fitted with a Mark 8 Pazon system, so I will keep the distributor.
Thanks for replies.
The last post was made 5 years, 62 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.73 - MySQL Queries: 13 - Page Size: 50.09 Kb
