Author |
markb_1984 |
markb_1984 L Plate Warrior
Back to top |
jeffyjeff |
jeffyjeff World Chat Champion
Posted: 05:42 - 23 Oct 2022 Post subject: |
Hey markb_1984, welcome to the wonderful world of motorcycling. Sorry to read that you are losing your grip, especially with your right hand. My quality of life would really take a dive if my right-hand lost grip, I shudder to even think about it. In my estimation, your problem is probably not related to your gloves, but you could try a different pair to see if your grip improves. You could also try squeezing harder. That usually works for me. ____________________ History shows again and again how nature points out the folly of men - BOC |
Back to top |
A100man |
A100man World Chat Champion
Posted: 11:05 - 23 Oct 2022 Post subject: |
markb_1984 wrote: |
I have one particular issue I wanted to reach out to see if anyone can help pinpoint possible causes. |
Late 30s? you seem younger..
Try leather gloves, or as Jeff helpfully suggests, grip harder. ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
Back to top |
Freddyfruitba... |
Freddyfruitba... World Chat Champion
Posted: 11:07 - 23 Oct 2022 Post subject: |
Whatever the cause, I'd strongly recommend trying a pair of Grip Puppies on the handlebars:
https://www.amazon.co.uk/dp/B00F6S7ER8/
Makes the grip larger (easier to hold) and creates more friction between grip and glove. Easy to fit, nothing to lose and a cheaper fix than trying any new gloves ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
Back to top |
Zen Dog |
Zen Dog World Chat Champion
Posted: 11:28 - 23 Oct 2022 Post subject: |
markb_1984 wrote: | For the first 150 miles or so, I had no issues of note with my grip on the throttle. I have found however that each subsequent ride I've been out over the last few weeks, my right hand (glove) seems to be slipping more and not feeling as tight a grip on the throttle as I remember in the beginning. I've developed a few techniques to help, but I'm finding losing grip is especially affecting me in having full control at slow speeds and in moving from a standstill. |
It's hard to advise on this because you don't seem entirely sure where the problem is. So step 1, go and ride the bike without a glove on your right hand. Is the problem still there?
If it is, we can ignore your gloves and look at other issues (freddy's suggestion of grip puppies is a good one if the problem is grip strength, for example). If it's not, consider changing your gloves, though looking at them on sportsbikeshop, they've got a rubberised bit between your palm and thumb which is the most important bit in terms of gripping the throttle. Has the rubber bit on the glove (or your throttle grip) got contaminated with something slippery like oil? ____________________ Current - '94 VFR750FR, '00 VFR800FI Previous - '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win (chinese copy of an old Honda design with a C90 engine)
My bike trip around S.E. Asia 2010/2011 |
Back to top |
Kawasaki Jimbo |
Kawasaki Jimbo World Chat Champion
Back to top |
Pete. |
Pete. Super Spammer
Posted: 12:24 - 23 Oct 2022 Post subject: |
Your grip on the throttle should be light not tight. Carry your body weight through your legs and torso and leave your arms and hands to do the job of controlling the bike through light control. Drop your shoulders and bend your elbows it will make you feel much more relaxed and make controlling your bike easier too. When you come to a bend at a-road speeds, lean forward and into the turn very slightly and notice how much easier making the turn becomes.
Or are you saying that the throttle is rotating in your hand because the return spring is causing it to shut the throttle unexpectedly? Foam grips will stop that. ____________________ a.k.a 'Geri'
132.9mph off and walked away. Gear is good, gear is good, gear is very very good |
Back to top |
doggone |
doggone World Chat Champion
Back to top |
Pete. |
Pete. Super Spammer
Posted: 13:37 - 23 Oct 2022 Post subject: |
I use compressed air to fit foam grips on my BMW because the end of the factory grip is larger than the grip itself. Cut them long, bung in the end, apply air and press the open end against the bar. The foam grips swell up under air pressure until it sldies over the lump on the end of the factory grips. ____________________ a.k.a 'Geri'
Back to top |
Bhud |
Bhud World Chat Champion
Back to top |
gbrand42 |
gbrand42 Could Be A Chat Bot
Posted: 20:20 - 23 Oct 2022 Post subject: |
It's possible that your 125 is more focused on the 17 yr old market, and at that age your right hand grip is probably a lot more developed than a man in his 30s ____________________ Yamaha RD50M, Honda C90, Yamaha RS100, Yamaha RD125LC, Honda XL125 V9 Varadero, Honda NT700VA, Honda VFR800X, Honda CRF1000L, Honda ST1300 Pan European |
Back to top |
trevor saxe-coburg-gotha |
trevor saxe-coburg-gotha World Chat Champion
Back to top |
stinkwheel |
Posted: 22:09 - 23 Oct 2022 Post subject: |
I get tennis elbow occasionally which really affects my grip. If you were suffering from this, you'd notice painful elbows and a lack of grip in other situations too and possibly tingling in your fingers (if mine is really bad, i can't lift a full pint glass in one hand). I have a couple of elastic straps I wear just below my elbow when I ride the bike that prevents this.
That's maybe an aside though. The other thing I did which improves my grip on the throttle was to fit oxford fat grips which are a wider outside diameter than standard. Straight-up gives you more leverage. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
A100man |
Posted: 11:42 - 24 Oct 2022 Post subject: |
stinkwheel wrote: | I get tennis elbow .. (if mine is really bad, i can't lift a full pint glass in one hand) |
Jeez, that is bad. ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
jeffyjeff |
Back to top |
stinkwheel |
Back to top |
jeffyjeff |
Back to top |
Tierbirdy |
Tierbirdy Spanner Monkey
Posted: 18:34 - 25 Oct 2022 Post subject: |
Relax!
Also consider getting something like this, theyre a godsend on long rides so you can keep the throttle open just by resting your palm on it, rather than death gripping and redlining a small 125 to get any kind of speed out of it. |
Back to top |
blurredman |
blurredman World Chat Champion
Posted: 09:21 - 27 Oct 2022 Post subject: |
Tierbirdy wrote: | Relax!
Agreed. I use one on one of my bikes. Though a much cheaper varient. They really work well. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Past: 1991 Honda CG125BR-J, 1992 (1980) Honda XL125S, 1996 Kawasaki GPZ500S.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, MZ TS150 - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k. |
Back to top |
dave001 |
dave001 Banned
Back to top |
Andy_Pagin |
Andy_Pagin World Chat Champion
Back to top |
Nobby the Bastard |
Back to top |
Easy-X |
Easy-X Super Spammer
Back to top |
The last post was made 1 year, 71 days ago. Instead of replying here, would creating a new thread be more useful? |
