Author |
McJamweasel |
![](images/spacer.gif) McJamweasel BCF Junkie
![](images/avatars/19046982247e1743c07b7e.jpg)
Joined: 22 Mar 2002 Karma : ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_6.gif)
Back to top |
You must be logged in to rate posts![](images/spacer.gif) |
![](templates/standard/images/spacer.gif) |
Easy-X |
![](images/spacer.gif) Easy-X Super Spammer
![](images/avatars/1682206356567bfbe6b584.jpg)
Joined: 08 Mar 2019 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_3.gif)
Back to top |
MarJay |
![](images/spacer.gif) MarJay But it's British!
![](images/avatars/19046982246598b4e87cf3.jpg)
Joined: 15 Sep 2003 Karma : ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_9.gif) ![Excellent Karma (Level 4)](/images/karma/gold_4.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 09:30 - 13 Mar 2023 Post subject: |
This kind of thing is always drivers. Sadly if you can't get a driver that prevents it then it's just incompatible with your system. As Easy-X suggested, taking a video and showing CEX might get you some play, but to be honest buying something like this from CEX? I wouldn't do it, put it that way.
Hi McJam BTW, great to see you back on the forum! ![Smile](images/smiles/icon_smile.gif) ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Back to top |
to v or not to v |
![](images/spacer.gif) to v or not to v World Chat Champion
![](images/avatars/17955481096015a63139fe8.jpg)
Joined: 24 Nov 2020 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_2.gif)
Back to top |
RhynoCZ |
![](images/spacer.gif) RhynoCZ Super Spammer
![](images/avatars/123078954154c623ae61d26.jpg)
Joined: 09 Mar 2012 Karma : ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif) ![Outstanding Karma (Capped)](/images/karma/capped_9.gif)
Back to top |
CaNsA |
![](images/spacer.gif) CaNsA Super Spammer
![](images/avatars/77232429858a8777404b86.jpg)
Joined: 02 Jan 2008 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_8.gif)
Back to top |
MarJay |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 12:28 - 14 Mar 2023 Post subject: |
CaNsA wrote: | Which 5700xt is it?
What is the full spec of your pc?
What power supply do you have?
What driver version are you using?
Which version of windows?
Are you using DDU when switching gpus?
MarJay wrote: | This kind of thing is always drivers. |
Lol, nopes |
Ok... It's pretty much always drivers. What OS? Needs compatible drivers whichever.
The only other things it could be are overheating and a weak sauce PSU, but I'm assuming our good friend McJam is tech savvy enough to know that he needs the right PSU and cooling. ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F
Back to top |
to v or not to v |
Back to top |
CaNsA |
Back to top |
McJamweasel |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 23:22 - 14 Mar 2023 Post subject: |
Thanks for the suggestions.
OS is Winblows 10, fully updated.
Mobo is Asus B450M-K. Latest BIOS.
Ram is 16gb Crucial something-or-other off the mobo QVL. It checks out fine in stress tests, and gives no errors with the 1050ti.
PSU Corsair 650w. Calculated load of the system is about 380w.
I've tried a couple of driver versions, the latest WHQL from a week ago. I did use DDU.
GPU is a Powercolor Red Devil 8gb. I haven't checked the BIOS on there yet, that is a good shout. It has double BIOS - OC and silent. Issue is present with both.
Temps are fine, even in sustained Furmark stress test with a CPU test running as well it doesn't get over mid-70s. Gaming I've seen mid-60s. CPU temp is also fine.
I've tried the latest ASUS chipset drivers, but not AMDs, so I'll give that a go. I'm also going to try a fresh Windows install, but I'm not too hopeful.
MarJay wrote: | Hi McJam BTW, great to see you back on the forum! ![Smile](images/smiles/icon_smile.gif) |
Howdy. Long time since I've posted, but I've been lurking around the place still. I've just realised that it's been 21 years next week... [/list] ____________________ BCF: Be yourself, just don't be an arse. |
Back to top |
CaNsA |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 02:20 - 15 Mar 2023 Post subject: |
Ta for the report o7
Min rec psu for that card is 700w, but I doubt the psu wattage is the cause.
However, I see that the gpu does need 2 x 8pin feeds, are you using the same feed for both or 2 independent feeds from the psu?
The AMD chipset drivers are stable for me, I've got them installed on my asus b550-f / 5800x / 6700xt - gpu driver 23.3.1
Have you got Smart Access Memory (SAM) / Resizable BAR enabled?
Test with the opposite.
Disable any integrated graphics.
Motherboard bios - Check you have the PCIE type set to auto
How many monitors do you have?
If only 1, try using the primary graphics output on the card.
If more than 1, the primary output is the one which displays the bios/post.
Do you know if the GPU has been opened?
Worth checking the pads on the VRMs/GDDR etc are actually contacting the heatsink.
Possible to test in another nerds computer?
It's a fucking long shot, but have you got a decent cable that is capable the res and refresh you are rocking?
Deffo worth a swap out to test.
When I bought a Sapphire Pulse 5600xt a few years back it would crash at driver install regardless of version, got it replaced within a week because it was a hardware fault. OCUK really came through for me.
Only worth mentioning because HW issues are a thing.
If all that guff above doesnt help, and you still have a sketchy GPU then I would return it to CEX.
Shameless plug time.
I have a 5600xt for sale, it's been rock solid for me.
Buy my wares |
Back to top |
Easy-X |
Back to top |
blurredman |
![](images/spacer.gif) blurredman World Chat Champion
![](images/avatars/11603991474d22800c5d83d.jpg)
Joined: 18 Sep 2010 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_2.gif)
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 10:34 - 15 Mar 2023 Post subject: |
Have you applied the jumpers correctly and assigned free IRQ and DMA designations? ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Past: 1991 Honda CG125BR-J, 1992 (1980) Honda XL125S, 1996 Kawasaki GPZ500S.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, 1979 MZ TS150 - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 50k. |
Back to top |
P. |
![](images/spacer.gif) P. Red Rocket
Joined: 14 Feb 2008 Karma : ![Excellent Karma (Level 1)](/images/karma/gold_9.gif) ![Excellent Karma (Level 1)](/images/karma/gold_9.gif)
Back to top |
Easy-X |
Back to top |
DaddyStu |
![](images/spacer.gif) DaddyStu Spanner Monkey
![](images/avatars/24389628564132f3f6cc0a.gif)
Joined: 19 Jan 2023 Karma : ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_6.gif)
Back to top |
Easy-X |
Back to top |
Fat Angry Scotsman |
![](images/spacer.gif) Fat Angry Scotsman World Chat Champion
![](images/avatars/141153768660096d6e5506d.png)
Joined: 12 Jan 2021 Karma : ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif) ![Good Karma (Level 4)](/images/karma/green_9.gif)
Back to top |
Easy-X |
Back to top |
Back to top |
McJamweasel |
Back to top |
P. |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 14:59 - 22 Mar 2023 Post subject: |
Could just buy my whole rig and upgrade yourself for like £800?
i9 9900k, all water cooled, 2080 Super, 32GB RAM etc... ![Wink](images/smiles/icon_wink.gif) |
Back to top |
xX-Alex-Xx |
![](images/spacer.gif) xX-Alex-Xx World Chat Champion
Joined: 12 Sep 2019 Karma : ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_9.gif) ![Excellent Karma (Level 2)](/images/karma/gold_1.gif)
Back to top |
Back to top |
P. |
![Post Post](templates/standard/images/icon_minipost.gif) Posted: 17:20 - 22 Mar 2023 Post subject: |
Fat Angry Scotsman wrote: | |
His board is old, I don't even know if that chipset has PCI-E 4.0... hence the suggestion if hes looking to upgrade, he might want something outside of what he currently has at the core.
Can't see a processor mentioned, but I am guessing at a ryzen 2600/2700x? You'd want a decent Ryzen to not bottleneck the 3070, even though the ZOTAC one isn't amazing, a bottleneck is a bottleneck. Add on the power at max juice, its recommended to run 650w, it won't draw close to that maybe 250w at cap, but low rated PSUs and high demand cards = short term life. |
Back to top |
![](/images/spider_left.gif) |
The last post was made 1 year, 80 days ago. Instead of replying here, would creating a new thread be more useful? |
![](/images/spider_right.gif) |
