Washing machine not spinning
Easy-X
PostPosted: 18:05 - 01 Aug 2023    Post subject: Washing machine not spinning Reply with quote
Dunno whether anyone else has had similar problems and can chip in...
My daughter's Zanussi has stopped working. It powers up, you can choose a program, the drain gurgles but it doesn't spin. Loads of YouTube videos suggest replacing the door switch Thinking
Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter
WD Forte
PostPosted: 18:24 - 01 Aug 2023    Post subject: Reply with quote
bent sub frame?
sorry, thats all I got
Wouldn't a bad door switch just stop the machine?
( Edit: just had a quick gurgle out of curiosity and apparently
it can have an effect of preventing the spin cycle whilst allowing other cycles)
level sensor ? faulty pump not draining the feelthy water out?
I would assume it checks the level is low before starting the spin stage
I'd check/clean the pump and filter first they clog up easily
and check it actually pumps/drains properly
bikers smell of wee
MCN
PostPosted: 19:10 - 01 Aug 2023    Post subject: Reply with quote
Pump can be tamperfered with usually via a wee door in the lower front.
They are not as complicated as motorbikes.
Kawasaki Jimbo
PostPosted: 19:59 - 01 Aug 2023    Post subject: Reply with quote
If it’s overloaded or unbalanced it won’t turn, although you’d expect it to rotate once before stopping.
Islander
PostPosted: 20:38 - 01 Aug 2023    Post subject: Reply with quote
Check the filter.
Easy-X
PostPosted: 20:40 - 01 Aug 2023    Post subject: Reply with quote
"Not draining" sounds promising. Now I think on it I reset the machine so we could open the door... and of course my daughter bagged up the clothes for me to wash Rolling Eyes Anyhoo, she said there was still water in the machine so it makes sense if it's not draining it won't move onto the next step.
The bad new is there's no fluff filter on the front like my Bosch has. Apparently the design is such that it doesn't need one. Given I still hear it gurgling I might take a look at where the waste pipe goes in case the route is blocked. I shall investigate...
<edit> Tomorrow I'm gonna disconnect the waste pipe and stretch it over to the sink, run a drain cycle and see what the flow rate's like.
PostPosted: 20:42 - 01 Aug 2023    Post subject: Reply with quote
Bobby pin in the pump is the usual one on ours, you have to open the hatch at the bottom right, unscrew the plug, pull out the wee filter then fish the foreign object out of the pump impellar. Have towels on standby because there is usually a reasonable amount of water hanging about in the bottom when you undo the plug.
Also a blocked outflow pipe will do similar. There can just be a wad of lint stuck in there. There's usually a one way valve somewhere in the corrugated pipe running out of the back or in the drain pipe it flows into. It's usually disgusting and stinky but can generally be taken apart and cleaned out.
Easy-X
PostPosted: 20:54 - 01 Aug 2023    Post subject: Reply with quote
NEWER ZANUSSI WASHING MACHINES NO LONGER HAVE FILTERS ON THE FRONT OF THE MACHINE
There is no longer a filter that needs cleaning in the Zanussi washing machines.
This appliance is designed with a self-cleaning draining system, allowing light fluff fibres that fall off the clothes to be drained out with the water, so there is no need to access this area for regular maintenance and cleaning.
hellkat
PostPosted: 20:55 - 01 Aug 2023    Post subject: Reply with quote
Do people still use bobby pins?
virus
PostPosted: 21:20 - 01 Aug 2023    Post subject: Reply with quote
He didnt specify they were Mrs Stinkwheels. I reckon he keeps a handful in his beard incase he needs to pick a lock.
own: 81 xs1100g...
to v or not to v
PostPosted: 21:24 - 01 Aug 2023    Post subject: Reply with quote
i do for removing ear wax Embarassed
its old and fat, but its a damned good ride. the bikes not bad either.
hellkat
PostPosted: 21:27 - 01 Aug 2023    Post subject: Reply with quote
I mostly use ribbons and those alice-band sort of things to keep my hair at bay.
It so resembles a sheeps-arse in its curly rambunctious intensity that bobby pins just don't hold anything in place for much more than five minutes. Laughing
[EDIT] : I know fuck all about washing machines. I used to have to call out the guy to fix them all the bloody time when I worked in the knocking shop, always washing fucking towels and bed linen (obvs) and I was NOT prodding about in the fucking lint lobby for god knows what might be blocking the pipes. Couldnt afford to have the w.m. out of use for a single day in that place Rolling Eyes So now, with my own machine, there's only me ... so maybe one or two washes a fortnight (one whites, one or two of colours) If mine do ^^that^^ I just give up and buy another one.
MCN
PostPosted: 01:51 - 02 Aug 2023    Post subject: Reply with quote
If its a Zanusi (An Appliance of Science Rolling Eyes ) then there's a fancy door seal that stops any accoutrements reaching the pump.
Could be simply that the pump motor is phuked.
duhawkz
PostPosted: 10:14 - 02 Aug 2023    Post subject: Reply with quote
My hoover washer was doing a similar thing this morning.
There was a filter on the front of it, like a big drain plug.
I took that out and it was full of muck, once I'd cleaned it the washer started working again
blurredman
PostPosted: 11:57 - 02 Aug 2023    Post subject: Reply with quote
My dryer breaks a belt almost once a year.
Past: 1991 Honda CG125BR-J, 1992 (1980) Honda XL125S, 1996 Kawasaki GPZ500S.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, MZ TS150 - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k.
Easy-X
PostPosted: 12:28 - 02 Aug 2023    Post subject: Reply with quote
Usually from people (who shall remain nameless) overloading the thing with too many wet towels Sad
MCN
PostPosted: 16:04 - 02 Aug 2023    Post subject: Reply with quote
You are the Utilities Doctor and I claim my 5 Free dryer sheets.
WD Forte
PostPosted: 17:31 - 02 Aug 2023    Post subject: Reply with quote
If its a frequently used family machine its well worth checking the motor
brushes and commutator while yer in there.
A lot of these machines use what's often called a 'universal motor'
so brushes are easily sourced.
Hard worked machines can sometimes have the commutator pads start to lift off
the rotor due to heat and this can chew away at the the brushes as it self destructs.
Mine did that a few years ago, it started with a ticking sound as it spun the drum over
bikers smell of wee
MCN
PostPosted: 02:57 - 03 Aug 2023    Post subject: Reply with quote
Spun or Span? Thinking
WD Forte
PostPosted: 13:23 - 03 Aug 2023    Post subject: Reply with quote
Spun
bikers smell of wee
sickpup
Old Timer
PostPosted: 11:27 - 07 Aug 2023    Post subject: Reply with quote
Ask her if she is missing the underwire from a bra, it's in the pump.
Easy-X
PostPosted: 12:59 - 07 Aug 2023    Post subject: Reply with quote
I had a look to see if the drain pipe was blocked but no, not enough sludge in it to make a difference. It sounds like the pump makes an attempt then gives up.
If I had the time I'd strip it down but my brother-in-law works for a company that delivers white-goods and he's cut her a nice deal to drop off a new one and drag away the old. Not the right deal in terms of repair and reuse but probably the best in terms of time, money and convenience.
Kawasaki Jimbo
PostPosted: 19:13 - 07 Aug 2023    Post subject: Reply with quote
So now we’ll never know. Sad
PostPosted: 20:48 - 07 Aug 2023    Post subject: Reply with quote
Their wizard wheeze of not putting in an inspection cover to allow foreign bodies to be removed from the pump worked then.
I'd have replaced my current machine three times by now if it was similar.
Nobby the Bastard
Harley Gaydar
PostPosted: 21:15 - 07 Aug 2023    Post subject: Reply with quote
You mean the one which isn't at the front near the bottom and absolutely doesn't have have a flap without a rotary cover behind it?
Sprint ST 1050
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 128.32 Kb
