Yammy Headlights
DaddyStu
PostPosted: 00:16 - 23 Sep 2023    Post subject: Yammy Headlights Reply with quote
Got my 1st bike coming - Tracer 700. Age old question coming up for you guys probably.
Is there an easy way to get both headlights to come on instead of just the one?
Best advice i've seen so far is adjust the angle down and run full beam all the time - but then you got no actual full beam.
Daddystu
Zontes 125-G1 (part-ex'd). Yamaha Tracer 700.
Easy-X
PostPosted: 01:17 - 23 Sep 2023    Post subject: Reply with quote
The "best" solution would be to run dual-element bulbs in parallel* but that might also mean beefing up the wiring, fuses and switching relay (if present.)
How are your electrical skills?
*Not sure if the glass/reflectors are slightly different between the left & right headlights.
Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter
DaddyStu
PostPosted: 02:02 - 23 Sep 2023    Post subject: Reply with quote
Not bad but I usually take about 10 times longer to do such jobs than I plan for.
I'm thinking of a much simpler form-over-function solution here. I dont need the 'off' lamp to function as a headlight, but merely give the appearance of one. While retaining full beam capability.
Just an aesthetics thing but it'll also stop the, "Oi mate, you got a light out" that i'm very likely to get.
Daddystu
MCN
PostPosted: 07:15 - 23 Sep 2023    Post subject: Reply with quote
I had a Yamaha Thundercunt. I almost remember they have a diode/jumper somewhere under the instrument clusterfuck that could be swapped between pins to bring both lights on.
I could be talking shite though. It was before the war.
weasley
PostPosted: 09:15 - 23 Sep 2023    Post subject: Reply with quote
Assume you mean a Thunderace rather than Thundercat, since the latter only has one headlight?
To OP, the main beam light will not have a beam pattern cut off so will always be dazzling when on, regardless of aim.
MCN
PostPosted: 10:52 - 23 Sep 2023    Post subject: Reply with quote
Cum to think of it, it wasn't the Thundercunt it was the Triumph Sprint that had the option to change.
And it wasn't even a diode or a jumper.
It only needed another miniature relay plugged into a spare lighting receptacle under the instrument cluster.
It was accessible with ones sleeve rolled up and watch removed.
grr666
PostPosted: 12:17 - 23 Sep 2023    Post subject: Reply with quote
Ah c'mon, a ride isn't a ride unless someone comes up and tells you you have a bulb out. Laughing I always say "cheers mate"
even though it isn't true just so I don't have to have a conversation with a non bike type person.
PostPosted: 13:03 - 23 Sep 2023    Post subject: Re: Yammy Headlights Reply with quote
More to the point you don't have the beam pattern cutoff that's required to make it legal. Dip beam is more than just a lamp pointed lower.
DaddyStu
PostPosted: 14:15 - 23 Sep 2023    Post subject: Re: Yammy Headlights Reply with quote
Yes, forumite said to raise them back to normal for MOT. Not an ideal solution.
Daddystu
PostPosted: 14:27 - 23 Sep 2023    Post subject: Re: Yammy Headlights Reply with quote
Stupid solution TBH especially coming into winter. Dark and wet roads, oncoming riders with spray-soaked visors could do without some fool with high beams wiping out their vision as it glares off the wet road.
A100man
PostPosted: 18:31 - 23 Sep 2023    Post subject: Reply with quote
Original Fazer 600.. just a wire link so both H4s main beamed at teh same time IIRC. Nothing ever go hot.
Easy-X
PostPosted: 19:28 - 23 Sep 2023    Post subject: Reply with quote
Even with the R125 I was rebuilding "only one side's working!" It is fucking tiresome.
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.46 - MySQL Queries: 15 - Page Size: 76.51 Kb
