EFI revs hanging
scotto75
PostPosted: 18:20 - 05 Oct 2023    Post subject: EFI revs hanging Reply with quote
Hi everyone,
My neighbour has a 2020 125cc Mutt and the revs are hanging for 2 seconds after the throttles returned. It starts and idles perfectly. No backfiring. There’s a slight hesitation when accelerating, but nothing untoward. It’s just that whether you return the throttle or put in the clutch, the revs stay at that rev range for 2 - 3 secs before dropping down to idle.
Don’t know much about Mutt’s except it’s a GN125 engine. I’m a carb and points type of a guy and this is all electronic, fuel injection and ECU type nonsense.
My thoughts were that it is running lean so I removed the spark plug. The ceramic was clean and the ground electrode was white, so I’m pretty confident that’s the issue.
I’ve sprayed easy-start around the manifold where the injector and throttle body are mounted, but no signs of air leaks. There’s no warning lights or the speedo and, as mentioned above, it idles and runs really nice.
Could the injector need a clean? It’s been sat around for a few months so suggested sticking a bottle of fuel treatment in the tank maybe?
Any other ideas would be most useful! Thanks!
Honda ‘73 CB350, ‘80 CG125, ‘88 CG125, '73 Triumph T140V
Nobby the Bastard
Harley Gaydar
PostPosted: 19:26 - 05 Oct 2023    Post subject: Reply with quote
Probably a sticky cable or outside chance it's an air leak on the intake between the throttlebody and the barrel.
Sprint ST 1050
scotto75
PostPosted: 21:01 - 05 Oct 2023    Post subject: Reply with quote
Thanks for the reply. Checked the throttle cable and how clean the return is and watched the lever on the throttle body and there’s no problems there. As I say, sprayed easy-start and brake cleaner between the throttle body and the barrel with no change in idle. Seems pretty air tight there.
I will remove the throttle body and check inside for any stickiness.
Plug is white and the revs consistently hang for 2 secs. Seems lean to me, but the idle is good and the bike accelerates fine. Don’t know enough about EFI and why the ECU would lean the mixture. Think it maybe a generic lexmoto Chinese setup, but has plenty of sensors. TPS, Lamda etc. don’t know if one of those would affect the mixture?
Nobby the Bastard
Harley Gaydar
PostPosted: 09:38 - 06 Oct 2023    Post subject: Reply with quote
Typically,the lambda sensor has the greatest effect on mixture but if it fails it registers in the efi as lots of oxygen so it makes the mixture too rich rather than lean.
Sprint ST 1050
Robby
Dirty Old Man
PostPosted: 11:20 - 06 Oct 2023    Post subject: Reply with quote
If it has an kind of separate idle air circuit then it would be worth looking at, a stuck open valve there could cause the problem.
It probably also has a PAIR system, which feeds air into the exhaust to reduce emissions. These typically require a vacuum feed, so if that vacuum feed line is broken you will have an air leak.
WD Forte
PostPosted: 20:44 - 09 Oct 2023    Post subject: Reply with quote
check the resistance of the tps from off to full throttle a few times
If the track is damaged or dirty or the contacts are poor you could get
erroneous signals to the ECU.
the tps is basically a voltage divider so I'd also check the voltages between the tps and ecu change smoothly in response to throttle movement.
It's a Chinese bike and we all know how variable the quality can be on them so 3-4 years may end of life for some parts
As it's EFI it probably has a diagnostic connector somewhere so reading fault codes could give some clues
bikers smell of wee
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 48.03 Kb
