Improving front light on a 125?
Fullers1845
PostPosted: 16:39 - 05 Feb 2024    Post subject: Improving front light on a 125? Reply with quote
As title really, using a cb125f for commuting and as it seems with pretty much all 125's, the front light is complete guff.
The high beam is fine for dark lanes, just would like more light on the road when riding with dipped beam.
I've 'upgraded' to an Osram bulb which did actually help quite a bit but still pants.
I'm limited by the 35w limit as the housing is only designed for the heat of CS1 type bulbs.
Other options I'm considering is an LED bulb or additional spot lights.
Honda CB125F, Kawasaki ZX6R J1, 1922 Sheffield-Henderson Blackburne grasstrack/sprint
PostPosted: 17:10 - 05 Feb 2024    Post subject: Reply with quote
Yes, good quality LED bulbs are the way forwards.
I use these ones.
https://www.classiccarleds.co.uk/products/compact-led-headlight-h4-p43t-472-motorcycle-hi-lo-beam-conversion-9-32v
MCN
PostPosted: 17:25 - 05 Feb 2024    Post subject: Reply with quote
LED is the way.
You need to get one that the reflector can focus properly.
If not focused, much of the useable light can be wasted or produce flare which can affect other road users.
There are laws to be aware of relating to vehicle lighting.
HID was a big thing a few years ago. The HID bulbs rarely were a legal replacement for standard bulbs. But many people don't care about that detail. Laughing
Fullers1845
PostPosted: 09:46 - 06 Feb 2024    Post subject: Reply with quote
Cheers, I'll look into an LED setup.
DaddyStu
PostPosted: 18:41 - 06 Feb 2024    Post subject: Reply with quote
stinkwheel wrote:
Those fit a Tracer 700?
Daddystu
Zontes 125-G1 (part-ex'd). Yamaha Tracer 700.
PostPosted: 21:35 - 06 Feb 2024    Post subject: Reply with quote
DaddyStu wrote:
If it has an H4 headlamp, then yes. You need to find somewhere to fit a small electronics box too. Looks like they have a fairing so you're golden, I cable tied mine to the forks in the headlamp casquette of my enfield bullet.
A word of warning, I know nothing about canbus wiring and I don't know if your bike has it. Giving canbus different bulbs than expected might precipitate a tantrum if it does. I was at the Dragon rally last year and one guys BMW landed up immobalised in the middle of the field because he'd fitted a trailer and wired up a single LED stop and tail light to it. Computer said no and continued to say no even after he disconnected it. Because this is progress obviously.
WD Forte
PostPosted: 22:40 - 06 Feb 2024    Post subject: Reply with quote
Canbus uses a +2V/-2V signal bus and this can get the hump if summat
non Canbus interferes with it, but as with most things
there's a workaround using a resistor IIRC
Never had a Canbus vehicle to play with so I cant speak from personal experience though
bikers smell of wee
DaddyStu
PostPosted: 00:37 - 07 Feb 2024    Post subject: Reply with quote
Have seen a youtube guy fit a set on a newer model Tracer but couldn't find his exact bulbs on the bay. He didn't have an extra box but the base of the bulbs was fat so it might've been in there. They were H7s iirc.
Daddystu
MCN
PostPosted: 01:38 - 07 Feb 2024    Post subject: Reply with quote
The simplest workaround for canbus is a bypass the canbus and install an 'analogue' system (Hooked up to the battery post.)
Or the online resistor thing.
BMW enthusiasts can even fit a fuse box retrofitted to their 'adventure chariots' (some of those fuse boxes are 'intelligent' too. Rolling Eyes )
BMW canbus will reset when the alien load has been removed.
The presence of canbus in BMWs bikes means that they do not have a fuse box. Over load is monitored by the canbus, which cuts power to any overloaded circuit.
My 110dB air horn shuts down the canbus if connected to the canbus horn circuit. The workaround is to fit a relay system controlled by the canbus horn circuit.
BMWs have a non-canbus 'Jack' thingy which allows one to plug in heated clothing or an air pump. So they did think of their owners.
A100man
PostPosted: 11:08 - 07 Feb 2024    Post subject: Reply with quote
My Bro's 1987 (?) R100 doesn't have a fuse-box eiher, well not really.
When the headlight feed wore through and shorted on the headstock. the switch gear and cables caught fire - 80 years on and 'Ze Germans' are still trying to sabotage us..
jeffyjeff
PostPosted: 15:53 - 08 Feb 2024    Post subject: Reply with quote
A100man wrote:
...When the headlight feed wore through and shorted on the headstock. the switch gear and cables caught fire - 80 years on and 'Ze Germans' are still trying to sabotage us..
It's quite simple, really. The conductor wire doubles as the fuse. Overcurrent conditions are readily ascertained by the presence of fire. When that happens, your friendly BMW dealer will gladly effect the repair for a modest charge. Don't worry, be happy Very Happy
MCN
PostPosted: 18:19 - 08 Feb 2024    Post subject: Reply with quote
Aww Naw.... the Beemir Haters have stirred. Rolling Eyes
Very Happy
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.24 - MySQL Queries: 15 - Page Size: 77.02 Kb
