Author |
pdg |
pdg World Chat Champion
Posted: 13:01 - 14 May 2024 Post subject: Honda CB250K something - very very long term project... |
Part 1.
Will it run?
https://i.imgur.com/1GA2FHp.jpeg
Might need a bit of redex.
That beautiful hunk of scrap formerly identified as a 1970-'72 CB250 engine.
It was actually worse than that, I'd already 'cleaned' some of it before I thought to take a pic.
Unfortunately for it, I'm sometimes a twat and I left it out in the rain for approximately one decade, give or take 0.2 decades or so. In my defence (not that I deserve it) it really wasn't that much better beforehand.
I did however have the foresight to put the head, rocker box and other associated gubbins in a box in the shed, so they've got nothing more than patchy surface rust in a few places. Pretty sure I even have a camshaft somewhere too.
I got the block off after draining a few litres of water out of the cases and that's as far as I've got...
I also have the bottom end and gearbox of a slightly later one, it was sat outside next to this one. It's even less complete, but some internals may or may not be interchangeable.
So yeah, I have no idea when or even if any progress will be made, but I thought I'd bung it in here anyway - it might be fun to see what happens. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
Back to top |
stinkwheel |
Posted: 13:48 - 14 May 2024 Post subject: |
I suppose it'll mainly come down to if you have a viable crank and cam. I'd imagine most of the other bits are available out there because they are raced a lot in classic racing on account of them being flying machines. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Back to top |
WD Forte |
WD Forte World Chat Champion
Back to top |
pdg |
Back to top |
pdg |
Back to top |
pdg |
Back to top |
blurredman |
Posted: 13:23 - 16 May 2024 Post subject: |
Looking forward to it. I like rags to riches stories on bikes! ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Past: 1991 Honda CG125BR-J, 1992 (1980) Honda XL125S, 1996 Kawasaki GPZ500S.
Current: 1973 MZ ES250/2 - 17k, 1979 Suzuki TS185ER - 9k, 1979 MZ TS150 - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 50k. |
Back to top |
jeremyr62 |
jeremyr62 Borekit Bruiser
Back to top |
pdg |
Back to top |
A100man |
A100man World Chat Champion
Posted: 12:50 - 17 May 2024 Post subject: |
I'm an optimist and love a phoenix story but that is scrap..
..it has been screwed by water induced corrosion... any rescues will involve £100s (£1000s?) on new parts - pistons shells,balls, rebore crank grind etc.etc..
by all means try and rescue a forlorn motor but give yourself a fighting chance.
PS its not a Vincent after all. ____________________ Now: A100, GT250A, XJ598, FZ750
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600 |
Back to top |
WD Forte |
Back to top |
jeremyr62 |
Posted: 13:44 - 17 May 2024 Post subject: |
It wasn't my intention to goad you into action
I agree with the naysayers. It will cost serious money to get that going again. There are much better better ways of spending your hard earned.
Sometimes, you just have to let go. |
Back to top |
pdg |
Posted: 15:23 - 17 May 2024 Post subject: |
Ok, so let's discuss...
If someone brought that to me and asked me to fix it I'd offer them a fiver for weighbridge value. If they were insistent, I would quote based on replacing and/or machining all of the internals and consider it a bonus if I could reuse the clutch pushrod.
However, that's not the case.
There are levels of survival I am prepared to accept
When I had my 2 stroke 50 the oil injection pump failed and the engine heat seized - I took off the head, made sure the piston was on the down stroke and dumped the clutch in 2nd while rolling downhill, then ran it on premix for the last 4 months of it's life (with me).
Would I build a daily use commuter out of it? No. I could, but that would not be financially viable.
Would I build a show bike out of it? Yes. Show bikes don't have to run...
How about something in between - say a bike that is built to maybe look reasonable to me and maybe do a couple of hundred miles a year pottering around for entertainment, where if it stops working (with variable levels of enthusiasm if/when said stop occurs) it's really not the end of the world because I'm not relying on it?
So yeah. It might be scrap. It might be an exercise in futility. It may not happen quickly but even if it never runs it won't be as expensive as an evening in the pub and it'll be more fun than watching tv. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
Back to top |
jeremyr62 |
Back to top |
pdg |
Back to top |
pdg |
Posted: 19:22 - 17 May 2024 Post subject: |
Undeterred by his own stupidity and fuelled with belligerence, our hero bravely battles on and undoes some screws.
Firstly, the left side generator cover comes off to reveal:
https://i.imgur.com/iw5MfCa.jpeg
Then the clutch cover succumbed to his will, as did these 4 bolts
https://i.imgur.com/EVd6TA1.jpeg
This liberated the clutch pack from it's bonds and allowed further inspection confirming that they are indeed clutch plates and that they kept their living quarters remarkably tidy
https://i.imgur.com/mQ4EPyQ.jpeg
https://i.imgur.com/uK2IOop.jpeg
Oh, and then he sprayed some penetrating oil in some places. ____________________ Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you. |
Back to top |
jeremyr62 |
Back to top |
Easy-X |
Easy-X Super Spammer
Posted: 21:49 - 17 May 2024 Post subject: |
The Motorcycle of Theseus ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Back to top |
WD Forte |
Back to top |
Howling Terror |
Howling Terror Super Spammer
Posted: 01:21 - 18 May 2024 Post subject: |
Allen Millyard can be heard sucking through his teeth.
I did hear him say that anything can be repaired...maybe that's a thought you can cling to.
I want you to succeed yet from the few photos it looks like a big ask..then again I've never spilt the cases on anything and certainly haven't the equipment to fit new liners or machine replacement parts.
Keep us posted. During my time here I've learned that there are still some key members that are willing to help, if required.
Just give them the right information. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
Back to top |
UncleFester |
Posted: 07:07 - 18 May 2024 Post subject: |
That looks like way more effort than reasonable return.
Wife rebuilt an NC50 which was in way better nick than that and it ran into 4 figures, not including the time involved. She's also got a 94 CB400SF that's headed the same way). It's the stupid little stuff like replacement bolts / washers / gaskets / bearings or things like rechroming etc etc. Then there's what you break along the way or just can't find at all then you're too far down the rabbit hole and you end up spending daft money on some unobtnamium (looking at you CB400SF carbs and parts) part because you're already daft money in and can't leave it unfinished.
Scabs should be left well alone, not picked at ____________________ 2017 Z1000SX |
Back to top |
A100man |
Posted: 09:19 - 18 May 2024 Post subject: |
pdg wrote: |
Cost me (preferably less than) about £100 (slightly flexible if it's properly interesting to me)
So there we go, with those requirements and considerations, like what? |
Rebore and pistons alone will be double that. Then there a fuckton of other corroded engine parts to consider. £500 IF everything goes right..
still.. 'À chacun son goût ' ____________________ Now: A100, GT250A, XJ598, FZ750
Back to top |
pdg |
Back to top |
to v or not to v |
to v or not to v World Chat Champion
Back to top |
UncleFester |
Posted: 13:17 - 18 May 2024 Post subject: |
If it's just playtime tinkering then carry on as you were
It read like you had desires of making it a 'runner' ____________________ 2017 Z1000SX |
Back to top |
