LED indicators?
Webstercon
PostPosted: 20:30 - 07 Feb 2010    Post subject: LED indicators? Reply with quote
Sorry to post a common question but have looked through the forum and found no answers...
I have a Honda XR 125 and have recently replaced the standard indicators with 4 LED indicators. I have fitted a generic 3 pin LED relay (Not sure if I need the 3 pin, but there are 3 wires). I have tried disconnecting the dashboard light, but still doesn't work properly any ideas?
Blue_SV650S
PostPosted: 20:55 - 07 Feb 2010    Post subject: Reply with quote
What do you mean by 'doesn't work properly' ... do you mean the indicators don't work at all or flashing too fast/too slow, or something else entierly?
Webstercon
PostPosted: 21:00 - 07 Feb 2010    Post subject: Reply with quote
Yes they do light up but they don't flash they just stay on. I have had all of them flashing at the correct speed but all were flashing like hazards on a car, I then removed the dash bulb and each side worked without flashing, replaced the dash bulb and they all just stayed on with no flashing
chip
PostPosted: 21:10 - 07 Feb 2010    Post subject: Reply with quote
i have a cbr125 , when i had this problem it was because a wire had become diconnected from a front indicator and the indicators just came on and didnt flash
Webstercon
PostPosted: 21:16 - 07 Feb 2010    Post subject: Reply with quote
Thanks but I have checked all connections and fairly sure its not that however I will double check Smile. I'm thinking I may have the wrong relay but cant be sure, I don't know much about electrics
finpos
PostPosted: 09:35 - 08 Feb 2010    Post subject: Reply with quote
You can't have looked that hard, there's plenty of threads on here about this Smile
The flasher relay you have uses the electrical resistance of the indicators as part of it's timing circuit. LED bulbs essentially have zero resistance so that all goes to pot.
You need to either fit additional resistors into the wiring or buy a flasher relay which is designed to drive the LEDs (look on ebay for cheap ones)
f.
Webstercon
PostPosted: 10:17 - 08 Feb 2010    Post subject: Reply with quote
Thanks for the reply. I have looked on the forum and found plenty of the threads and tried some of the common solutions. I have already got a relay designed for LED indicators however they are still not functioning correctly, because they used to flash like hazards and no longer do so (even though everything is wired as before) I'm thinking I have possibly broke my new relay? Thumbs Down Anyone know how I can check this?
Carl_steveo
PostPosted: 11:32 - 08 Feb 2010    Post subject: Reply with quote
I had this problem when I changed my Indicators over after a slide. When I indicated left it worked fine, When I indicated right It all went to hell and just stayed on.
Turns out electrics don't appreciate being put together with sellotape. Just rewired it better and it worked fine.
Current: Honda Nsr 125
Live: Sunderland
Webstercon
PostPosted: 16:42 - 08 Feb 2010    Post subject: Reply with quote
Cheers for the reply. I'm changing the indicators to mine due to a minor spill as well. I will double check all the connections, although I haven't used sellotape lol
Carl_steveo
PostPosted: 18:28 - 08 Feb 2010    Post subject: Reply with quote
Haha it's all I had to hand at the time and I had to use the bike so didn't really have much choice. It works though and if it isn't broke don't fix it lol.
Live: Sunderland
Webstercon
PostPosted: 21:03 - 08 Feb 2010    Post subject: Reply with quote
Lol fair play then. Hopefully I'll get mine going soon or its hand signals for a while Thumbs Down
Webstercon
PostPosted: 21:39 - 13 Feb 2010    Post subject: Reply with quote
Just to say that I have now returned the LED flasher relay and popped in four 21 Watt resistors (as suggested by finpos) which I got from Hein Gericke this works brilliant and saves faffing about with relays, cheers for your help everyone Very Happy
The last post was made 14 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 68.82 Kb
