nowhere.elysium |
nowhere.elysium The Pork Lord
nowhere.elysium |
Posted: 16:02 - 29 Jul 2014 Post subject: |
I've hit a minor roadblock.
Having pulled the carbs off the bike, I got them up to my flat, to be disassembled and fiddled with in a position of relative comfort. Hurrah for kitchen worktops:
https://farm4.staticflickr.com/3841/14589736029_54e1a6fc46_b.jpg
I'd already done some minor cleaning of the carb set at this point, so they're not quite as hideous as they were when I originally got them off the bike.
https://farm3.staticflickr.com/2909/14776532672_52ae7fa082_b.jpg
Of course, I hadn't managed to remove the remnants of the brambles that had been growing through it yet.
I was a little concerned that the carbs would have thoroughly gummed up internals, having been sat for a decade and all that. So, I started pulling one apart, just to have a look:
https://farm3.staticflickr.com/2920/14774529704_db04baa3a3_b.jpg
Float bowl is a bit minging, but nothing irretrievable. Having squirted a bit of 3-in-1 through the jets, I'm satisfied that they're not blocked.
I also decided that it'd be best to take a look at at least one needle, just to check that there wasn't any insane wear:
https://farm4.staticflickr.com/3919/14776891785_078d5181cc_b.jpg
The diaphragm's in very nice condition, too:
https://farm4.staticflickr.com/3888/14590168940_9e7095428e_b.jpg
https://farm4.staticflickr.com/3870/14776531642_af3377c445_b.jpg
Remarkably clean in there - a bit of grit has migrated in, but that's largely down to me moving the carbs about a lot.
I've discovered where the seizure appears to be - on the main rail, from the left: between the pulley and the first spring and there's also some impediment to free movement under the third spring, too.
https://farm4.staticflickr.com/3874/14590169750_7f822bbdf4_b.jpg
Anyway - I'm hoping that the penetrating oil that I've saturated the areas involved with has soaked in now. I'm going to go agitate a throttle linkage. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
nowhere.elysium |
Robby |
Robby Dirty Old Man
nowhere.elysium |
Posted: 14:20 - 03 Aug 2014 Post subject: |
Right. Got as far as removing the airbox plate, and separating the carbs.
https://farm6.staticflickr.com/5566/14630908209_3b1b31096e_b.jpg
The main culprit for stiffness is this carb: the one with the throttle cable pulley on it.
https://farm3.staticflickr.com/2928/14631027467_0292784a6f_b.jpg
As it stands, I've gone and removed the circlip and nylon washer on the throttle shaft that leads into the carb body, and I've gone and sprayed some 3-in-1 under the fibre washer (at least, I presume it's a fibre washer, it's too compressible to be a bush). The movement of the throttle shaft is a little easier now, but only a little. It's looking like I'll have to take the shaft out, which does lead to the question - is there anything special about the screws that hold the butterfly on, or are they just bog-standard countersunk machine screws that have had the ends flared? ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
CHR15 |
CHR15 Turbo nutter bastard
Posted: 15:14 - 03 Aug 2014 Post subject: |
they have jis heads.
there probably loctited in.
trololol ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
There is a gap of 218 days between these two posts... |
nowhere.elysium |
Posted: 13:40 - 10 Mar 2015 Post subject: |
dydey90 |
dydey90 World Chat Champion
nowhere.elysium |
The last post was made 9 years, 89 days ago. Instead of replying here, would creating a new thread be more useful? |
