Nobby the Bastard |
CHR15 |
CHR15 Turbo nutter bastard
Pete. |
Pete. Super Spammer
Posted: 22:42 - 30 Mar 2014 Post subject: |
Integrate it into a throttle cable housing for extra cool-points ____________________ a.k.a 'Geri'
bladerunner |
Souleh |
Souleh Trackday Trickster
Irn-Bru |
Irn-Bru World Chat Champion
Posted: 12:43 - 31 Mar 2014 Post subject: |
What do all them buttons do? Take it the red one is the kill switch? I like buttons. ____________________ KTM 990 SMT & Suzuki DR-Z 400 SM |
CHR15 |
Posted: 19:45 - 31 Mar 2014 Post subject: |
lllN30lll |
lllN30lll World Chat Champion
CHR15 |
Posted: 18:41 - 01 Apr 2014 Post subject: |
wow.
those buttons are £5.71 each from rs.
that thing took me under an hour to program and machine.
if i was making another one it would take me under half an hour to do as a one off.
if i was knocking them out in batches it would be about 13 minutes each.
they must be making like 57000% markup. ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
lllN30lll |
CHR15 |
Posted: 18:57 - 01 Apr 2014 Post subject: |
bmw's run 22mm bars? ____________________ Turbocharged drag thing / project death weapon / GK73A
lllN30lll |
CHR15 |
Posted: 16:03 - 20 Apr 2014 Post subject: |
G |
G The Voice of Reason
CHR15 |
Posted: 16:25 - 21 Apr 2014 Post subject: |
Souleh |
Posted: 10:36 - 23 Apr 2014 Post subject: |
Ive seen them going for 150-200 before. That link is ridiculous.
Looks to be a standard OEM Honda killswitch being used too.
Is the 1000RR not reknown for dodgy switches because theyre all PCB's and over-engineered? |
stevo as b4 |
CHR15 |
Pete. |
Pete. Super Spammer
Posted: 20:54 - 23 Apr 2014 Post subject: |
That collection point to bring all the four headers together is a beggar to cut isn't it? I put hours into getting mine right, and afterwards decided that if I ever did it again I would start with the collector and work my way back to the ports. Mine moved about all over the place when the collector was welded and it was whilst fixing that I found that it is actually very easy to shift and adjust things as you go. For instance, where you have the outlet below the four-way join it's binocular-shaped but it would be very easy to shape that to match the hole in your flange plate. How thick is the plate you're going to use by the way? Anything less than 12mm is very likely to dish badly when you weld it. Mine did and I had to spend probably an hour filing it flat again.
Nice welding there BTW Chris - you do all that yourself? ____________________ a.k.a 'Geri'
CHR15 |
Posted: 21:30 - 23 Apr 2014 Post subject: |
i know what you mean.
nibble a bit out, see if it fits, nibble a bit out, see if it fits.
flange is 10mm. the last one i did, i tacked it, got it proper hot with the bottles and then welded it. still went a bit but wasnt too bad. i can always set it up on the mill and just take a lick off.
yeah weldings all me. hands are too shaky to make it really good but its not too bad. ____________________ Turbocharged drag thing / project death weapon / GK73A
Pete. |
Pete. Super Spammer
Posted: 21:41 - 23 Apr 2014 Post subject: |
Look good to me, but welding isn't my strong point (sic).
Autogenous or using filler? My first headers were autogenous welded and I had to have them gone-over with filler as I had bumped into a welding inspector who said they would fail. I was lucky as I had no idea there was trouble loomin' ____________________ a.k.a 'Geri'
CHR15 |
Posted: 21:50 - 23 Apr 2014 Post subject: |
autogenous on header spigots and pipe joints where the fit was perfect.
filler on the 4 merged pipes cos there was like .5/1mm gaps where the die grinder got a bit happy.
the last set were also autogenous, the only place i had failure was where i branched off for the wastegate, but i did have the weight of the wastegate hanging off the joint at 90 degrees. should have braced it really.
the turbo is going to be hung off the frame anyway with some little turnbuckle tie rods. probably with urethane bushes on the frame end otherwise i imagine it might crack from vibration. ____________________ Turbocharged drag thing / project death weapon / GK73A
Pete. |
Pete. Super Spammer
Posted: 21:12 - 24 Apr 2014 Post subject: |
I'd think about relieving that wastegate hole Chris if I were you cos little turbos love to creep on bikes. If you do it by hand I'd suggest you ovalise it with well-rounded edges and take some off the inside top edge and outside bottom edge. I turned mine on my lathe - same housing as yours, but in hindsight I think hand-profiling would have been better. Still got the jig somewhere. ____________________ a.k.a 'Geri'
CHR15 |
Posted: 19:28 - 28 Apr 2014 Post subject: |
Howling Terror |
Howling Terror Super Spammer
The last post was made 10 years ago. Instead of replying here, would creating a new thread be more useful? |
