What? Another VFR
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
suzukirider19...
PostPosted: 23:54 - 09 Mar 2013    Post subject: Reply with quote
Very nice build! TBH if it was mine i would never ride it just too god dam nice. as many have said the detailing is excellent.
husky sm610
Tim..
PostPosted: 00:16 - 31 Mar 2013    Post subject: Reply with quote
Cheers Thumbs Up
Nah, want to ride this one in anger.
Update:
Although not much has happened recently these turned up, protective sleeve for the bare braided brake lines and a temporary filter for the cam cover. The plan is to run a catch tank later (and would be needed for race regs).
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2576_zps695bb490.jpg
There we go
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_25771_zpsfb55fa40.jpg
But as the rubbers, clips and cables are all here now today I managed to get the almost impossible task of fitting the carbs with a HRC airtray getting in the way done. Had to take the grill out as it was going rusty. That'll not be made from stainless then but it will get a coat of zinc (as will the top rad grill).
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/0065A582-493B-4C37-90EE-7C35381432C9-395-00000039842FABC6_zps908dff30.jpg
www.marshallracing.co.uk
Tim..
PostPosted: 07:03 - 15 Apr 2013    Post subject: Reply with quote
Got the grills back form the zinc coater which meant I could get the rads on now as well as the HRC overflow bottle.
Carb top
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2702_zpseb83159c.jpg
Bottle
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2686_zps5c106118.jpg
All fitted and piped up
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2688_zps7e3972bd.jpg
Bottle mount
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2694_zps219470df.jpg
Tim..
PostPosted: 09:15 - 19 May 2013    Post subject: Reply with quote
Managed to get the billet 6 pots back together and on the bike this weekend.
Here they both are after I repainted the lines with black caliper paint.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2811_zpsef9396a0.jpg
Nice and clean now
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2813_zps1b60cc01.jpg
Pushed the pistons back out, applied some grease then pushed them back in again.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2816_zpsa4e1b2ee.jpg
Copper slipped pads and zinc'd retaining pins
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2814_zps01b9d6bf.jpg
All on the bike with the protective wrap on the brake lines
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2829_zps1941133e.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2831_zps07ad9872.jpg
And finally a bit of tart factor
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_2832_zps8ed9dbbe.jpg
P.
PostPosted: 09:50 - 19 May 2013    Post subject: Reply with quote
So many brake pads...
https://img.mu.cdn.li/Ao/xqefEH.jpg
Looking very nice mate, what carbon bits have you actually got on there?
Tim..
PostPosted: 10:28 - 19 May 2013    Post subject: Reply with quote
Cheers Thumbs Up . Makes the callipers a mare to fit
Just the air tray and front fender
Tim..
PostPosted: 16:24 - 13 Jul 2013    Post subject: Reply with quote
Got a bit done to the fairing today.
Painted the white to the lowers
https://i475.photobucket.com/albums/rr119/Timon1983/Honda%20VFR%20Race%20fairing/null_zps5d630f3d.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/Honda%20VFR%20Race%20fairing/null_zps5d4b1773.jpg
Also put the number boards on the seat unit. Will paint the red and blue around them.
https://i475.photobucket.com/albums/rr119/Timon1983/Honda%20VFR%20Race%20fairing/null_zps772cc195.jpg
Tim..
PostPosted: 18:38 - 20 Jul 2013    Post subject: Reply with quote
Got the gold pin strip done on the lowers.
https://i475.photobucket.com/albums/rr119/Timon1983/Honda%20VFR%20Race%20fairing/null_zps263e4ff1.jpg
Thought I'd do a trail fit. Glad I did because there were loads of little mods to be done.
Slowly getting there.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/null_zps93f3a2b3.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/null_zps2a082abf.jpg
Tim..
PostPosted: 15:19 - 21 Jul 2013    Post subject: Reply with quote
Found this modified Harris front ally mount.
Few more mods and I'll get it to fit properly.
Stock item on the left
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/null_zpsb394590e.jpg
Timmeh
PostPosted: 16:37 - 31 Jul 2013    Post subject: Reply with quote
fucking fap fap fap fap fap fap fap fap.
et1
PostPosted: 18:59 - 05 Aug 2013    Post subject: Reply with quote
et1
Tim..
PostPosted: 20:55 - 13 Aug 2013    Post subject: Reply with quote
Been working on the clocks mount at the moment.
Got a section welded on the the end and then cut it down to length
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/null_zps57c5efdd.jpg
Then shaped it down, drilled and tapped it.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/null_zps4fb95198.jpg
This has been easy to say but has taken an age to get right with the fairing etc coming off and on many times to make sure everything fits properly.
Next thing is to get it bolted on with the clocks so I can make a template for another catch tank bottle mount
Tim..
PostPosted: 12:59 - 14 Aug 2013    Post subject: Reply with quote
All mounted and wired up
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/null_zps3fb203ad.jpg
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/null_zpsbf7ac0f8.jpg
moppy
PostPosted: 13:14 - 14 Aug 2013    Post subject: Reply with quote
I wish I had just a fraction of the leet skillz you have Laughing
Awesome work, always like reading through your threads.
Tim..
PostPosted: 14:08 - 23 Aug 2013    Post subject: Reply with quote
Cheers buddy
Got the template made for the fuel tank catch bottle. Will bolt up to the clocks mount.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/null_zpsc6f54db5.jpg
prawny1
PostPosted: 23:16 - 25 Aug 2013    Post subject: Reply with quote
I use a bit of rod to hold all the pads in place when sliding those type of callipers on, they like them on Harleys but the pads are stupid money when doing a twin disc front end takes six sets of pads (nine if you have a matching rear calliper too).
hellkat wrote:
Some people are only alive cos its against the law to kill them.
Tim..
PostPosted: 19:07 - 14 Sep 2013    Post subject: Reply with quote
Yep I've made some tooling now to make servicing calipers easier now.
Got the catch tank bottle mount for the fuel tank made in stainless.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/IMG_3321_zps65f7831d.jpg
And all bolted up.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/null_zpsa8aad502.jpg
Tim..
PostPosted: 17:40 - 08 Feb 2014    Post subject: Reply with quote
Package from Japan arrived.
Breather catch tank and stainless R clip for the rear wheel.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/99D3E625-36EF-4965-ACF8-A8B28AC5F040_zpsu2p4leqs.jpg
And a template for its mount on the subframe.
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/4FF0F84D-B6A7-4CBB-B8A6-0CD961F4D543_zpsokmcdiwu.jpg
atg90
PostPosted: 23:50 - 08 Feb 2014    Post subject: Reply with quote
Nice to see an update on this. Look forward to seeing this bike and your other finished Thumbs Up
anthony_r6
PostPosted: 11:01 - 09 Feb 2014    Post subject: Reply with quote
Your bikes are beautiful. Seriously.
I am well jelly.
Fizzer Thou
PostPosted: 19:58 - 09 Feb 2014    Post subject: Reply with quote
Dare I dangle temptation in Tim's way Question
https://www.ebay.co.uk/itm/Honda-NC30-VFR400-Rolling-chassis-and-engine/131109013000?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D74%26meid%3D4719770779055484946%26pid%3D100005%26prg%3D1048%26rk%3D4%26rkt%3D4%26sd%3D191065044848%26
Always have a 'Plan B'
Tim..
PostPosted: 18:32 - 12 Feb 2014    Post subject: Reply with quote
lol saw that but decided I have enough to be getting on with atm.
Bit more progress made
https://i475.photobucket.com/albums/rr119/Timon1983/VFR%20nc30%20trackbike/32115879-C9E0-4087-8D45-78F093B4480C_zpsz0delm0y.jpg
fozzym
PostPosted: 00:11 - 13 Feb 2014    Post subject: Reply with quote
Was having a bit of a debate with a chap about the theory behind greasing up the brake caliper piston (as described in your earlier post)
I thought it sounded a good idea as bike brakes seem notorious for seizing up.
He however thought the grease would attract muck that may possibly get past the seals and cause problems.
What's your take on it TIM ?
Tim..
PostPosted: 07:58 - 13 Feb 2014    Post subject: Reply with quote
Hi fozzym. Like with most things I consider it a trade off.
These cailpers had not been used in a while and the reason I used the red rubber grease was to just help free up the pistons and get them 'gliding' a tad better.
Yes its true that the grease will attract a bit more dirt but that is what the caliper dust seal is there for. Hopefully the little barrier of grease would stop any salt/water/grit getting to the seals.
I certainly dont intend on letting the calipers get so dirty that they start to seize up. Cleaning and maintenance is a motorcycles best friend
The last post was made 10 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Page 7 of 9
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.51 - MySQL Queries: 17 - Page Size: 151.22 Kb
