Tool List
Gbaker369
PostPosted: 20:25 - 19 May 2011    Post subject: Tool List Reply with quote
Hi there,
I am new to biking and have just got my first 125 Cruiser.
I am slowly starting to repaint and do it up etc as the previous owner didnt really look after her.
If someone could please supply me with a list of tools I will need in the future to build up a good set so that I can maintain, tinker, and do up my current and future bikes it would me much appreciated.
Thank you in advance.
Handsome
PostPosted: 20:33 - 19 May 2011    Post subject: Reply with quote
A hammer...
Cable Ties...
Gaffer Tape, 1 black 1 silver...
A bigger back up hammer...
Tea, milk and sugar...
Cigarettes...
GSTEEL32
PostPosted: 20:38 - 19 May 2011    Post subject: Reply with quote
ADAM79 wrote:
A hammer...
Cable Ties...
Cigarettes...
jaffa cakes.
WD40.
Handsome
PostPosted: 20:40 - 19 May 2011    Post subject: Reply with quote
GSTEEL32 wrote:
ADAM79 wrote:
A hammer...
Cable Ties...
Cigarettes...
jaffa cakes.
WD40.
Dammit...Yeah, those two aswell...
Nufkamp
PostPosted: 20:41 - 19 May 2011    Post subject: Reply with quote
Planet Rock.
As seen on Google Street View https://tinyurl.com/yfdvojc
whitedevil
PostPosted: 21:06 - 19 May 2011    Post subject: Reply with quote
after which you will need plasters which you make from duct tape and rags.
Beer
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
Nexus Icon
PostPosted: 21:07 - 19 May 2011    Post subject: Reply with quote
CHR15 wrote:
a big flat blade screwdriver to use as a chisel, scraper, lever, oil filter remover, drift or punch. In fact, just about anything other than a screwdriver.
EFA Thumbs Up
Greetings from Shitsville!
Gazdaman
I did a trackday!!!
PostPosted: 13:42 - 20 May 2011    Post subject: Reply with quote
All good answers.
In seriousness, buy a good quality socket set and ratchet, and a set of ring/open spanners.
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_173083_langId_-1_categoryId_165572
That tool kit is used by home mechanics all over the place. And it's half price again (I'm not sure it's ever full price).
But that will tick off both sockets, ratchets, extension bars, and spanners.
Then you'll need a set of various sized screwdrivers (Halfords were giving away a set of their professional ones when you bought a bottle of their oil).
And a hammer, a little delicate one, and a big one to smash stuff with.
Then pliers, one set of fairly tough stubby nosed ones, and a set of more delicate long nose ones. Then a pair of wire cutters (fairly tough ones so you can cut cable ties and things too).
Maybe a big pair of grips, and a pair of mole grips.
Clearly you don't need all of those from the word go, but those are the tools I use day in day out.
Gaz
heehaw
PostPosted: 01:46 - 22 May 2011    Post subject: Reply with quote
CHR15 wrote:
a big flat blade screwdriver to use as a chisel.
And a knife to use as a screwdriver
Its important, otherwise it wouldn't be there.
Retro Rider Bicycles: CB125TDC, CBR400RR, BSA Bantam.
Killer Rat
PostPosted: 05:32 - 22 May 2011    Post subject: Reply with quote
wire brush for combing hair.
Blow torch for lighting ciggies with.
No! No more talk! We go in! We kill! Kill! We kill 'em! They kill us, we kill them! Kill 'em! Kill 'em! Kill! Kill!
_______________________________________________________
cbf125 09', cbt passed 4/6/2010 - 28k miles - 1 major breakdown (stator)
PostPosted: 09:24 - 22 May 2011    Post subject: Reply with quote
I'll second what Gaz says, that Halfords kit is pretty comprehensive.
If you were doing it a bit at a time, you'd be looking for:
Combination spanners between 8 and 22mm ideally.
A 3/8" drive socket set, 8-22mm.
A big spanner or socket appropriate for removing the rear wheel nut (if it's not in the combination set already).
Some good screwdrivers.
A set of allen keys.
Sparkplug socket.
Feeler guages.
Mole grips (shouldn't really need them but often do).
A deadblow hammer.
A washing up basin for draining oil into.
A basic digital multimeter that can read volts and resistance. A 20A input is desirable but not always possible.
A big syringe with some clear hose attached is surprisingly handy.
Also a selection of sprays, lubes and solvents:
Big tub of paraffin.
Light oil (eg. 3 in 1)
WD40
Penetrating oil spray.
High flashpoint solvent (brake/carb cleaner).
Molybdenum disulphide grease.
LM grease.
Copper grease.
As you start to do more, you land up needing more specialist tools such as:
Torque wrench. (a lower range is more useful)
Circlip pliers.
C-spanner.
Impact driver.
A 1/4" and/or 1/2" socket set, bigger sockets for certain nuts/bolts.
Electric drill (variable speed) and good quality HSS drill bits.
Drifts.
Wiring terminal crimps.
Then you get specialist stuff that you tend to buy as and when you need it such as:
Compression tester.
Flywheel puller.
"Special tools" (eg castle nut socket).
Dial guage
Valve spring compressor.
The last post was made 15 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.8 - MySQL Queries: 13 - Page Size: 70.96 Kb
