Chain gave up on me
ukdiceman
PostPosted: 14:02 - 10 Jun 2013    Post subject: Chain gave up on me Reply with quote
Hi All,
Anyone spot a problem here...... apart from the obvious bent frame!
https://i1117.photobucket.com/albums/k589/ukdiceman/null_zps56944b8b.jpg
Does anyone have any ideas on a repair for this, it only happened last night and after it was recovered I went to the pub! I've not taken the sprocket cover off yet and I'm not back home now until the weekend, so no idea of the real damage. Just thought I'd see what you guys recon.
FZ6 Fazer
Atomic Punk
PostPosted: 14:10 - 10 Jun 2013    Post subject: Reply with quote
Was it a tad loose?
I may have lost my way but I'm way ahead of schedule.
ukdiceman
PostPosted: 14:15 - 10 Jun 2013    Post subject: Reply with quote
Atomic Punk wrote:
Was it a tad loose?
I checked it Saturday, and did think It would need doing next time I lubed....... hindsight is a wonderfiul thing!
FZ6 Fazer
Islander
PostPosted: 14:30 - 10 Jun 2013    Post subject: Reply with quote
Chain looks a bit slack. You've already spotted the twisted subframe. Thumbs Up Laughing
RhynoCZ
PostPosted: 14:35 - 10 Jun 2013    Post subject: Reply with quote
Well, that looks nice Smile
What's next, a new crankcase? Laughing
Musketeer
PostPosted: 14:38 - 10 Jun 2013    Post subject: Reply with quote
What bike is it? Anyway it's f00ked now!
EDIT: Just saw the sig.. if it's XJ600 then burn it Laughing
https://www.banyanbranch.com/social-blog/wordpress/wp-content/uploads/2011/04/haha1.gif
ukdiceman
PostPosted: 14:42 - 10 Jun 2013    Post subject: Reply with quote
600N Diversion..... I was thinking a hammer and some filler! Shocked
FZ6 Fazer
Snorty
PostPosted: 14:46 - 10 Jun 2013    Post subject: Reply with quote
Cracked your crank case. Wounder.
Aff
PostPosted: 14:51 - 10 Jun 2013    Post subject: Reply with quote
It's a shame it killed the crankcase and not the sprocket cover.
Electric Bike Project
Atomic Punk
PostPosted: 14:54 - 10 Jun 2013    Post subject: Reply with quote
Looks like it's doubled up on the front sprocket.
Take the cover off and see if you can loosen the chain.
If the is no damage apart from the cover you might just get away with it.
PostPosted: 14:55 - 10 Jun 2013    Post subject: Reply with quote
I'd risk that... remove the chain and its cover, check for holes and leaks.
Atomic Punk
PostPosted: 14:56 - 10 Jun 2013    Post subject: Reply with quote
Ooops, thats the crank case not the cover, you may still be alright.
Snorty
PostPosted: 14:57 - 10 Jun 2013    Post subject: Reply with quote
Bit of gaffer tape should see it right?
ukdiceman
PostPosted: 15:00 - 10 Jun 2013    Post subject: Reply with quote
Yeah, I'm hoping there's no leaks and I might be able to get it back on the road...... I knew I'd get words of encouragement from Paddy Very Happy
FZ6 Fazer
Shinigami
PostPosted: 15:22 - 10 Jun 2013    Post subject: Reply with quote
if it's just the fringe of the cover thats broke you might just get away with it, barely, give everything in there a proper clean and check for any other cracks or leaks
Snorty
Threads like this make me want to put a rivet link on my GSXR...
_mjs_
PostPosted: 17:12 - 10 Jun 2013    Post subject: Reply with quote
That was caused by a stiff link... the big rear sprocket straightens it out, the small front sprocket leaves it kinked so it smashes into the sprocket cover / engine case.
The good news is that if you're not leaking oil, a bit of JB Weld and new chain and sprockets will make an effective if rather ugly repair Thumbs Up
ukdiceman
PostPosted: 17:36 - 10 Jun 2013    Post subject: Reply with quote
Thats what I'm hoping, I won't be stripping it until the weekend, I'll post an update when I do.
FZ6 Fazer
trevor saxe-coburg-gotha
PostPosted: 18:06 - 10 Jun 2013    Post subject: Reply with quote
Was it an O ring job? Just skimmed t'thread so don't thrape if already covered cheers dude.
sidewinder
PostPosted: 18:18 - 10 Jun 2013    Post subject: Reply with quote
it's a divvy will take more than that to kill it Very Happy .maybe you could get it welded up?
ukdiceman
PostPosted: 12:12 - 15 Jun 2013    Post subject: Reply with quote
Well I've taken the sprocket cover off and....
https://i1117.photobucket.com/albums/k589/ukdiceman/4faf7f46-fd8f-4eb5-8236-f32a48882e67_zps42ccd99e.jpg
https://i1117.photobucket.com/albums/k589/ukdiceman/chainfail3_zps268852be.jpg
The damage at the top of the casing is much worse than I expected, with the cover mount broken off. Will take alot more bodging than I anticipated! It might be a "spares or repair project" on ebay!
It looks like the split link has failed as I found the c clip in the bottom of the housing.
FZ6 Fazer
stickybackbob
PostPosted: 12:39 - 15 Jun 2013    Post subject: Reply with quote
Take the chain and sprocket off. If it's not pissing oil out then bodge it up.
Was going to suggest getting it welded but saw it was an XJ600....so gaffer tape it over. If you want to go posh, warm the metal up, tap it back carefully and add a bit of chemical metal Smile
Alpha-9
PostPosted: 12:46 - 15 Jun 2013    Post subject: Reply with quote
Pfff it's fine, front sprocket covers are overrated anyway, just ride without Wink Thumbs Up
- Your friendly neighbourhood bad advice man
Fzr-600 1999
RhynoCZ
PostPosted: 12:59 - 15 Jun 2013    Post subject: Reply with quote
That's the way to go, next topic would be, how to shift gears with no thumb or how to get the gear lever on the left Laughing
EDIT: right side, I'm with out a motorcycle about 2 months and I've already forgot how those things work Smile
The last post was made 12 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 129.86 Kb
