Yam FZS600 Fazer Cylinder Head Replacement and General Clean
0l0dom0l0
PostPosted: 21:31 - 23 Oct 2010    Post subject: Yam FZS600 Fazer Cylinder Head Replacement and General Clean Reply with quote
Well since I first got my bike its been pissing oil everywhere, because some Dick has managed to snap on of the cooling fins off. When I bought the bike it was covered in gum gum, so I had no idea as to how badly the engine was damaged. Anyway after tapping the gum gum off, I was greeted with this Thumbs Up
Turns out the same Dick welded it up, and did a very bad job of it:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05543.jpg
Anyways, all is not lost, and for the £900 I paid for her, shes not that bad really Smile:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05564.jpg
After many failed attempts to plug the leak, with epoxy and what not I came to the conclusion that I was going to have to get it welded again, or get a new head. So, I searched the net and found a head that had come off a bike that had done a total of 8 thousand miles. Couldn't say no really. It was skimmed today, was a tiny bit off in the middle. A grand total of 4 thou was taken off. It really has made a hudge difference to the surface though. I should have got some pictures before it was done, but here it is after the skimming Very Happy
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05567.jpg
I had work this morning, I got home around 2. Went straight out and got a few bits that I needed. Greases etc. Anyways, started stripping the bike this afternoon. Has gone well so far.
Here is before:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05574.jpg
And after an afternoons work! :
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05575.jpg
Anways, tomorrow we will be taking the old head off, and inspecting everything. Hopefully it should go well Smile.
I have on order:
Exhaust system
Exhaust gaskets
Head Gasket
Stuff I need:
Exhaust nuts.
Stuff to do:
Sort out forks,
Clean everything in sight
soak all rusted parts in vinegar
Stuff must not do:
Look at bank statement.
CHR15
Turbo nutter bastard
PostPosted: 21:59 - 23 Oct 2010    Post subject: Reply with quote
when your taking off the head oil feed line ( rusty one that runs up the front of the block) make sure you do it with a very well fitting socket, or you'll round it off.
also, give it a good tap first, to break the rust a bit.
0l0dom0l0
PostPosted: 09:16 - 24 Oct 2010    Post subject: Reply with quote
Thanks Chris. It the only bolt that is properly rusted up. If this feeds engine oil to the head, where does it then go after that? I cant see an oil return anywhere?
CHR15
PostPosted: 09:20 - 24 Oct 2010    Post subject: Reply with quote
return is more than likely through the cam chain tunnel.
also, when you've finished, flush the engine / radiator through with a hosepipe.
the stuff that came out mine was a horrible colour.
woll
PostPosted: 09:31 - 24 Oct 2010    Post subject: Reply with quote
Chris i hope you mean the cooling system? Not the actual engine lol, don't want him filling the cylinders full of water.
CHR15
PostPosted: 09:34 - 24 Oct 2010    Post subject: Reply with quote
ahh yeh, better put that in big letters
THROUGH THE COOLING SYSTEM
DON'T RUN WATER THROUGH YOUR ENGINE
0l0dom0l0
PostPosted: 18:05 - 24 Oct 2010    Post subject: Reply with quote
Yeah, that seems sensible.
An update of today's work:
Started off by removing anything that was in the way, the coils, fuel pump etc and the radiator had to come off.
Then took the valve cover off and started removing the camshafts:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05578.jpg
I didn't manage to get any in between photos, so we just have the bike as t stands now:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05584.jpg
I was surprised to find that both cams were well within the service limit though, not even 50% worn, so that's good news. Anyway here they are all layed out:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05583.jpg
Old cylinder head:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05581.jpg
A few things have popped up. When we were removing the cylinder head, we accidentally disturbed the barrels, and the barrel gasket. I am trying to decide if its worth replacing that too, but time is limited, and the only place I can find that stocks the gasket is Wemoto. I'm hoping it will be okay, but not really sure at the mo.
The most frustrating thing of all though, is trying to source the oil leak. There is nowhere obvious that its coming out from, and there was a fair bit coming out. It probably hasn't helped that the head gasket was installed the wrong way up, and I don't think the head bolts were torqued down correctly either. To top things up, when i turned the head upside down, a shim fell out. All of the followers had shims in though, so they had obviously decided to just leave one knocking around in the head. Overall whoever last fiddled with it, just made things worse.
To make things even better for me, I think one of my forks is slightly bent. Funnily enough its on the same side as the engine damage so me thinks something might have happened previously.
On the list for tomorrow (providing the stuff I have ordered arrives) is to install the cams in the new head outside the bike, so I can measure the valve clearances and get any new shims I need. Make a final decision as to weather the barrels are coming off and we are replacing that gasket, and start putting stuff back together. I just hope I can remember how it all went. *sigh*.
Any encouragement would be appreciated. I am a bit disheartened at the moment. My main worry being this base gasket.
Also any advice to that would be appreciated.
If I get a spare 5 mins, the fronts of the forks could do with a clean:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05585.jpg
But that isn't on my priorities list at the moment!
CHR15
PostPosted: 19:02 - 24 Oct 2010    Post subject: Reply with quote
get a close up of the 'repaired' bit.
if the loose shim rocking around in there is an example of the previous owners work I would be very surprised if the h/b were torqued down properly.
0l0dom0l0
PostPosted: 19:35 - 24 Oct 2010    Post subject: Reply with quote
Right, I have decided to do the base gasket. For the extra few quid now, and the hour or so it will take us to do it, I think its worth it.
Wemoto can get them, but it will take at least a week to get here. The head gasket I ordered from them a last Monday, hasn't arrived yet, and I need the bike for college.
I will get a close up of the repaired bit tomorrow when I am down the garage, its a pretty shoddy repair, but I'm really confused as to where it was coming from. The cooling fin would have taken a lot of force to break off like that. The oil leak must have just been a combination of everything. The new head was well worth the money though, and its not going to hurt sticking it on there.
The build quality on these bikes is pretty darn good to be honest, especially in the engine. The barrels are in very good condition, and the pistons are too. It will be interesting to see how worn the rings are, but I doubt if there is much wear. Not bad for 30k miles.
Anyone know where I am most likely to be able to find a new base gasket? I need it asap. I have already checked with my local Yamaha dealer to no avail.
Oh btw Chris, the banjo bolt came off without to much trouble, I had given a fair few sprays of wd40, and it took a couple of hit on the spanner to free it, but it came out not to bad Smile.
CHR15
PostPosted: 19:39 - 24 Oct 2010    Post subject: Reply with quote
what? its a yamaha gasket.
ring k2 01782 415768
there very good.
ill see if i can find you a part number.
0l0dom0l0
PostPosted: 19:43 - 24 Oct 2010    Post subject: Reply with quote
there very good.
Will ring them first thing tomorrow morning Thumbs Up
If you can get me a part number, that would be fantastic.
CHR15
PostPosted: 20:26 - 24 Oct 2010    Post subject: Reply with quote
i cant find my parts manual anywhere. fail.
anyway, it should be about 25 quid.
0l0dom0l0
PostPosted: 22:28 - 24 Oct 2010    Post subject: Reply with quote
FOUND ONE Very Happy
Am going to ring them tomorrow and see if they have it in stock and can get it to me by Tuesday.
Listen on the website at £15.
Awsome Smile.
0l0dom0l0
PostPosted: 18:32 - 25 Oct 2010    Post subject: Reply with quote
Have ordered myself a base gasket, Oil sump gasket and a cam chain tensioner gasket too. Should all be here Wednesday.
The barrels came off without to much trouble, a couple of the screws that hold the coolant return on the front were pretty stiff, but they came off after a few squirts of WD40.
The gasket underneath wasn't to bad. At least it had been installed the correct way up!!
Here is the bike atm:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05593.jpg
The barrels are in fantastic condition, no scoring, and you can't even feel any wear lines either. The rings looked a little worn, but were still very springy. A couple of photos:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05589.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05588.jpg
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05590.jpg
I was pretty sure that the sump was leaking a little bit around the edges. I had ordered myself a new sump gasket and started cleaning up the sump. Its not perfect, but I figured on the first wet ride it was going to get all shitty anyway. Then I was interrupted by a large box arriving, containing this Very Happy
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05592.jpg
And the clean sump:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05591.jpg
I then wanted to test the fan and thermo switch. I have never heard the fan come on and so was concerned they were broken. A quick test revealed that they both were working correctly, so we just put it down to corroded connections.
Dads taking Friday off by which time everything should be here we need to put it all back together again. There isn't really a lot more I can do in the mean time apart from clean a few bits up.
69.9mph
PostPosted: 18:54 - 25 Oct 2010    Post subject: Reply with quote
Good job so far, I think changing the base gasket was a good decision if it been disturbed.
What make are the downpipes?
0l0dom0l0
PostPosted: 19:05 - 25 Oct 2010    Post subject: Reply with quote
I agree. For the 15 quid its cost, well worth it in my opinion!
Pipes are Motad Venom ones. They are the best around, as most of the other Chinese ones don't have the balance pipes for the mid range. Look good. The welds are a little messy in places, but overall I am very happy with them!
Noxious89123
PostPosted: 19:20 - 25 Oct 2010    Post subject: Reply with quote
Looking good. Are the bits of foam on the levers to stop you impaling your head on them? Laughing
0l0dom0l0
PostPosted: 19:38 - 25 Oct 2010    Post subject: Reply with quote
My dad hit is head on them 3 times, so in his massive strop he found them and put them on. it was quite entertaining lol.
Noxious89123
PostPosted: 21:36 - 25 Oct 2010    Post subject: Reply with quote
Ha, been there, done that.
L4Isoside
PostPosted: 22:29 - 25 Oct 2010    Post subject: Reply with quote
Laughing When working on my bike today I noticed I instinctively move slightly out of the way every time I stand up, because I've hit my head/back so many times on pillion pegs/ handle bars/ levers/ indicators etc.
Bloody hurts sometimes too.
0l0dom0l0
PostPosted: 22:50 - 25 Oct 2010    Post subject: Reply with quote
It wont be long until my dad does the same Smile.
It was also quite funny watching him pick up the fan switch that we had been cooking on the stove to test it. That looked rather painful Thumbs Up
blurredman
PostPosted: 08:23 - 26 Oct 2010    Post subject: Reply with quote
Hope you're not going to eat that pot noodle. It has oil in it Laughing
0l0dom0l0
PostPosted: 09:29 - 26 Oct 2010    Post subject: Reply with quote
You can see how healthy my brother is. We have about 20 pot noodle tubs scattered around lol. He is so lazy!
0l0dom0l0
PostPosted: 19:25 - 27 Oct 2010    Post subject: Reply with quote
Right, I managed to get a little done today. I had work this morning, came home to a parcel for moi. Was a bit annoyed as all the gaskets should have arrived today, but I only have the head gasket from wemoto. I am a bit dissapointed, after waiting 10 days for it to arrive, its not even a genuine Yamaha one. Any ways, its written in Italian, so its probably from the same factory.
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05595.jpg
Then went down the garage, cleaned up the residue from the knackered sump gasket on the bottom of the engine. Didn't manage to get a photo, but when the sump gasket hopefully comes tomorrow, I can put it back on.
I then had a look at the state of my swing arm. I was there when I got my rear tyre done, and knew it was disgusting, so I decided to clean it. I had never taken a rear wheel off before, but I watched my tyre get changed and it didn't look to bad. Got the rear wheel off, and set about cleaning it. I would like to thank the person that created GUNK. It has to be the best stuff in the world for removing shit as I found out today. Anyways, here is a picture of my very shiny swing arm Smile.
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05596.jpg
And a very nice clean shock Smile:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05597.jpg
I had ago at the front forks the other day. I used one of those green scourer pad things, and a bit of 3 in one. It smoothed them out, but they need a proper polish.
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05598.jpg
I have left some of the bolts in vinegar to soak over night to get rid of the surface rust. Seems to be working well, but my god it smells horrible!
Random pic:
https://i1183.photobucket.com/albums/x474/0l0dom0l0/DSC05599.jpg
If the other gaskets don't come tomorrow we are pretty screwed. I'm desperately waiting for the base gasket to come as we can't do anything until it does.
The last post was made 15 years, 14 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 143.54 Kb
