Cold hands?
Sadie
PostPosted: 16:51 - 07 Feb 2005    Post subject: Cold hands? Reply with quote
I know some of you don't rate Oxford highly but I purchased some "Oxford Hot Grips" for £29.99 at the Ally Pally show on Friday and rode from St Albans to Warrington with them on Saturday and back on Sunday and had toasty paws all the way.
Babyyam will attest that I arrived in good order (i.e. not frozen) and given that she has seen me cold in JULY, this is quite some achievement.
So Thumbs Up to Oxford Hot Grips!
With experience comes age.
Ninja
Caption Abuser
PostPosted: 16:53 - 07 Feb 2005    Post subject: Reply with quote
I reckon heated grips are the single best mod/ addition to a bike - the same way heated mirrors and glass are for cars ...
James
4 wheels transport the Body ... 2 wheels transport the SOUL
map
Mr Calendar
PostPosted: 17:01 - 07 Feb 2005    Post subject: Reply with quote
I have a set of these (filed somewhere in the garage Whistle) and need to get them put on.
Did you just take them off the battery or go to the trouble of switching them through a relay so only on when ignition on?
Interested in what they're like when used as being told problem with heated grips can be thumbs still get cold as well as back of hands.
loply
I would buy some but Im too poor to invest in non-neccessaries =P For the meantime I put my gloves on my exhaust for 5 minutes, and when I can at lights I reach around and grab a handful of downpipe for a few seconds.
Yamaha SZR660 Caution to the wind, the throttle pinned!
Sadie
PostPosted: 17:08 - 07 Feb 2005    Post subject: Reply with quote
The ones on the Bandit are the old type, which have an on/off switch only. These (on my Bandit) are wired to the battery and are OFF when the ignition is off.
The new ones (on the ZX9R) have an on/off switch which is also a temperature control switch. They are also wired to the battery, but need to be switched off when the bike is off, or they will drain the battery. They do, however, have an indicating light to show that they are on.
As regards heat, on the Bandit (no fairing) I find that the grips are fine around town, but on the motorway they are better if you stick to 70(ish) and preferably use with muffs.
I was doing between 90-100 mph on the motorway over the weekend on the ZX9R (with fairings and no muffs). I had toasty hands all the way.
PostPosted: 17:17 - 07 Feb 2005    Post subject: Reply with quote
We got a set of these for Charlottes GPZ500 a couple of months ago. They are very good, too hot to have on full around town.
First week Charlotte had them on the GPZ it snowed on her way home Confused .
I have not yet wired them up through a relay, but will play with the wiring at some point to do this. Standard they are just wired directly to the battery, so I expect at some point some kids will play and turn them on, resulting in a flat battery.
They are certainly better than the ones from Busters that I fitted to the Divvy.
Yes your hands will still get a bit cold, but it is a bike so not much you can do to avoid that.
WildGoose
White Van Man
PostPosted: 09:07 - 08 Feb 2005    Post subject: Reply with quote
Thumbs Up to heated grips
however, maybe not to the oxford ones
mine started playing up a month or so ago, i.e. even if you turned them off, i often came back to find the light on even in the off position, and yes the battery draining or drained, then for some reason when you pressed the button the light went brighter, but was still on in the off position
so i had to resort to pulling out the plug every time i stopped (the one with the black wiring) i thought this was good at the time cos it also stops people pressing the button for you
for performance they were good when they worked, but the switch did have that cheap feeling about it when i bought it, and now i can see why, its the size of a house as well, cant see how it needs to be that big when its just a switch and some kind of variable resistor
and now im back to cold hands, the grips are completely tits up, and im glad i didnt superglue them on Razz
would be interested to hear about how people get on with their oxford ones, maybe i just got a bad pack Confused
cc123
Geez a joab?
PostPosted: 10:21 - 08 Feb 2005    Post subject: Reply with quote
Could have been doing with some last night after getting caught in a downpour...
I find insulated glove inners work well too if you can't be bothered spending the extra cash on heated grips....
But hey, summer is coming, who needs heated grips!? Laughing
Old bikes >>> https://www.bikepics.com/members/cc123/
houlsby
PostPosted: 11:01 - 08 Feb 2005    Post subject: Reply with quote
how do you fit them?
mchaggis
PostPosted: 11:06 - 08 Feb 2005    Post subject: Reply with quote
See the attached from MCN for fixed heated grips. If they're wrap around ones, it's simple a case of velcro as far as I am aware.
I must not be a troll...
Mmmm, Guinness
kaillum
PostPosted: 11:13 - 08 Feb 2005    Post subject: Reply with quote
i got some Oxford Hot Grips fitted to my wifes RS125 to try and tempt her out in some of the colder weather.. and she loves them.. only problem is that the variable temprature isnt variable on hers.. there either Off or Bloody Warm! so warm in fact that after a ride from Blackpool to Penrith and back again she took her gloves off and had scorch marks on her hands from the heat...
but at least she wasnt cold.. she not regulates the heat by turning them off until she gets cold then turning them on til she's warm then turning them off repeat repeat repeat..
but a bargain for £30 notes!
mr.z
PostPosted: 11:22 - 08 Feb 2005    Post subject: Reply with quote
Had some heated grips on my last bike, in the minor cold they are very good, so good in allot of the winter i'd ride with my summer gloves on!
Problem is in the really cold i'd just have burning hot palms and frozen knuckles, not much fun at all...
They are good but dont expect it to completely finish off your cold hand problems Sad
Heated gloves are next on my list to try out...
cc123
Geez a joab?
PostPosted: 11:24 - 08 Feb 2005    Post subject: Reply with quote
Heated grips are for puffs!! Bowl of porridge in the moring and away you goes!! Laughing
izzi81
PostPosted: 11:29 - 08 Feb 2005    Post subject: Reply with quote
I *always* end up with freezing cold hands, so if these are being recommended I shall have to keep my eyes open for some!
"The problem with the French is they have no word for 'entrepreneur' " George W Bush
Age doesn't matter unless you're a cheese
https://www.bikepics.com/members/izzi81
Gracie Jones
PostPosted: 12:20 - 08 Feb 2005    Post subject: Reply with quote
Mine are the budget wrap around ones. This makes them very easy to fit, but they are also non-temp variable.
I often end up with hands that are both hot and cold at the same time, i.e. palms hot, but fingers and tops of hands cold. Still better than nothing, but not as good as I'd imagined.
L
Major_Grooves
The Doctor
PostPosted: 13:25 - 08 Feb 2005    Post subject: Reply with quote
We had a look at the heated stuff at Ally Pally at the weekend. I can't remember the manufacturer, but I thought at the time that the grips would leave you with cold fingers and the heated gloves were too bulky. What seemed best to me were the heated glove liners.
About me|@Major_Grooves|My company|Digg|Flickr
MikeyC
PostPosted: 13:28 - 08 Feb 2005    Post subject: Reply with quote
Out of curiousity, I find the outside of my fingers get the coldest, as its facing the wind, would the heated grips help with this?
map
Mr Calendar
PostPosted: 13:38 - 08 Feb 2005    Post subject: Reply with quote
mikec106 wrote:
...I find the outside of my fingers get the coldest, ...facing the wind, would the heated grips help...?
Err, no.
That's sort of what I asked in my post above.
To help out your fingers in addition to heated grips use hand-guards (as on off-road type bikes) or handlebar muffs. These reduce the chill factor caused by the wind. I see on the Biking on a Budget thread zero mentioned milk bottles for this (I assume he meant the plastic ones Rolling Eyes).
If you've loadsa spare cash and can justify the cost you could invest in some heated gloves from the likes of Giali. The heating elements in these cover the front and back of the hands and the fingers.
HTH Smile
The last post was made 21 years, 296 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.65 - MySQL Queries: 16 - Page Size: 107.5 Kb
