Fork Seals, the bodgers way.. A how to :D
hmmmnz
PostPosted: 21:50 - 30 Aug 2007    Post subject: Fork Seals, the bodgers way.. A how to :D Reply with quote
well after a leaky fork thats been bugging me for a while, i decided i'd do it Very Happy
so he we go, bear in mind, that this isn't how the manual tells you to do it, but who the hell has a "kawazaki/honda/susuki/yamaha fork tool" ?? i certainly don't.
step 1.
put the bike on the center stand/jack ect, or make do with what you have about Very Happy no harm in being creative Very Happy
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0619Small.jpg
step 2.
remove the brake calipers from the forks
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0620Small.jpg
step 3.
remove the wheel and the mudguard (if you have one Very Happy)
remember where the spacers go Very Happy
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0621Small.jpg
step 4.
undo the bolts ect that hold the forks in the yokes, (you can unbolt the top of the fork at this stage) i prefer to slide the forks down and unscrew it using the bottom for clamp to hold the fork in place
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0622Small.jpg
step 5.
remove the forks completely from the bike, drain them into a bucket,
then, grab a flat blade screwdriver and ply off the dust seal.
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0623Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0624Small.jpg
step 6.
remove the little metal oil seal holding clip (again with flat bladed driver)
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0625Small.jpg
step 7.
the tricky bit Very Happy this is where the real bodging begins.
get a self tapping wood screw, yep you heard right Very Happy
and a small hammer and tap the screw into the center of the oil seal, trying to penetrate the metal that the seal is made of under the rubber. when you have pierced the metal then with som weight screw in the screw just enough that it bites Very Happy
try not to scratch your fork!!! (its made of tough stuff, but still be careful)
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0626Small.jpg
step 8.
pull the seal out with a set of pliers, and slide off the forks
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0627Small.jpg
and here are 2 i prepared earlier :d
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0628Small.jpg
step 9.
put the new seals in, replace the spring/seal holder, dust seal,
step 10.
slide the fork into place,
step 11.
put the wheel, brakes ect back on.
step 12.
fill with the recomended amount of oil
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0629Small.jpg
step 13.
screw the top back on the forks,
you are done!!
one perfectly functioning non diving rat fighter Very Happy
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0630Small.jpg
and i bid you adieu
the humans are dead
I kick arse for the lord
Evo
PostPosted: 22:16 - 30 Aug 2007    Post subject: Reply with quote
Good Guide There. Kudo's to you Very Happy
Bikes owned
1989 VFR 400 RR NC30
teabag
PostPosted: 22:58 - 30 Aug 2007    Post subject: Reply with quote
........and to get the new seal to go in straight get a length of 40mm waste pipe from your local DIY shop, slide it over the fork leg ont the seal then bash it with a hammer. Pressure is applied evenly to the seal and down it goes!! Need a bigger pipe for fat forks, of course.
NS125R = 2 years > GSX600F = 7 years > XR125L = 3.5 years > SV650S........and a Citroen Synergie HDI for the kids.
hmmmnz
PostPosted: 23:12 - 30 Aug 2007    Post subject: Reply with quote
i just use a screw driver Very Happy and gently press it down, never had any bother Very Happy but a pipe is better Very Happy Thumbs Up
the humans are dead
Ichy
PostPosted: 00:20 - 31 Aug 2007    Post subject: Reply with quote
Then three weeks later, when it starts leaking again, you can do it properly and changes the bushes at the same time Twisted Evil
Sorry mate, nice bodge, but I can't imagine everyone who decides to give it a go would be as careful as you with the woodscrew.
For the sake of one extra bolt a special tool can be made out of a bolt and a metal bar.
hmmmnz
PostPosted: 07:04 - 31 Aug 2007    Post subject: Reply with quote
ive never had a leak doing it this way,
it is a "bodge" though, if i had a decent set up over here, its not how i would do it, (im on holiday here in the uk Very Happy)
as for the bushes, there was no play, so i didnt bother Mr. Green Thumbs Up
just a leaky fork seal Mr. Green
if any one does this bodge. be careful! its a bodge, and not how its saposed to be done Thumbs Up
the humans are dead
MementoMori
PostPosted: 07:39 - 31 Aug 2007    Post subject: Reply with quote
Good old kiwi ingenuity! Thumbs Up
The tiger who came for a pint
hmmmnz
PostPosted: 09:00 - 31 Aug 2007    Post subject: Reply with quote
yep Mr. Green Thumbs Up gotta make do with what you got Mr. Green
the humans are dead
iloveriding
PostPosted: 09:25 - 31 Aug 2007    Post subject: Reply with quote
I think we should rename HMMMNZ to the GURU, keep the usefull info comming mate, Tony
Ride Safe, Stay Safe, Be Safe, Be Seen And See All Other Idiots on the road
ZRX61
Victor Meldrew
PostPosted: 22:58 - 31 Aug 2007    Post subject: Re: Fork Seals, the bodgers way.. A how to :D Reply with quote
hmmmnz wrote:
step 9.
Congratulations, you forgot to use a bit of clingfilm over the top end of the forks when you slid the seal over it.... so the inside edge will already have been mullared... Rolling Eyes
The last post was made 18 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.7 - MySQL Queries: 13 - Page Size: 76.16 Kb
