| hmmmnz |
 hmmmnz Super Spammer
 Posted: 21:50 - 30 Aug 2007 Post subject: Fork Seals, the bodgers way.. A how to :D |
well after a leaky fork thats been bugging me for a while, i decided i'd do it
so he we go, bear in mind, that this isn't how the manual tells you to do it, but who the hell has a "kawazaki/honda/susuki/yamaha fork tool" ?? i certainly don't.
step 1.
put the bike on the center stand/jack ect, or make do with what you have about no harm in being creative
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0619Small.jpg
step 2.
remove the brake calipers from the forks
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0620Small.jpg
step 3.
remove the wheel and the mudguard (if you have one )
remember where the spacers go
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0621Small.jpg
step 4.
undo the bolts ect that hold the forks in the yokes, (you can unbolt the top of the fork at this stage) i prefer to slide the forks down and unscrew it using the bottom for clamp to hold the fork in place
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0622Small.jpg
step 5.
remove the forks completely from the bike, drain them into a bucket,
then, grab a flat blade screwdriver and ply off the dust seal.
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0623Small.jpg
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0624Small.jpg
step 6.
remove the little metal oil seal holding clip (again with flat bladed driver)
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0625Small.jpg
step 7.
the tricky bit this is where the real bodging begins.
get a self tapping wood screw, yep you heard right
and a small hammer and tap the screw into the center of the oil seal, trying to penetrate the metal that the seal is made of under the rubber. when you have pierced the metal then with som weight screw in the screw just enough that it bites
try not to scratch your fork!!! (its made of tough stuff, but still be careful)
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0626Small.jpg
step 8.
pull the seal out with a set of pliers, and slide off the forks
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0627Small.jpg
and here are 2 i prepared earlier :d
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0628Small.jpg
step 9.
put the new seals in, replace the spring/seal holder, dust seal,
step 10.
slide the fork into place,
step 11.
put the wheel, brakes ect back on.
step 12.
fill with the recomended amount of oil
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0629Small.jpg
step 13.
screw the top back on the forks,
you are done!!
one perfectly functioning non diving rat fighter
https://i58.photobucket.com/albums/g257/hmmmnz/DSCF0630Small.jpg
and i bid you adieu ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Evo |
 Evo Trackday Trickster
 Posted: 22:16 - 30 Aug 2007 Post subject: |
Good Guide There. Kudo's to you  ____________________ Bikes owned
1989 VFR 400 RR NC30 |
| teabag |
 teabag Renault 5 Driver
| hmmmnz |
| Ichy |
 Ichy World Chat Champion
 Posted: 00:20 - 31 Aug 2007 Post subject: |
Then three weeks later, when it starts leaking again, you can do it properly and changes the bushes at the same time
Sorry mate, nice bodge, but I can't imagine everyone who decides to give it a go would be as careful as you with the woodscrew.
For the sake of one extra bolt a special tool can be made out of a bolt and a metal bar. |
| hmmmnz |
 Posted: 07:04 - 31 Aug 2007 Post subject: |
| Ichy wrote: | Then three weeks later, when it starts leaking again, you can do it properly and changes the bushes at the same time
ive never had a leak doing it this way,
it is a "bodge" though, if i had a decent set up over here, its not how i would do it, (im on holiday here in the uk )
as for the bushes, there was no play, so i didnt bother
just a leaky fork seal
if any one does this bodge. be careful! its a bodge, and not how its saposed to be done  ____________________ the humans are dead
| MementoMori |
 MementoMori World Chat Champion
 Posted: 07:39 - 31 Aug 2007 Post subject: |
Good old kiwi ingenuity!  ____________________ The tiger who came for a pint |
| hmmmnz |
 Posted: 09:00 - 31 Aug 2007 Post subject: |
| iloveriding |
 iloveriding Trackday Trickster
| ZRX61 |
 ZRX61 Victor Meldrew
| Vincent |
 Vincent Banned
 Posted: 23:41 - 31 Aug 2007 Post subject: |
Also best to rub a bit of fork oil on the inside of the seal and make sure you bleed the forks too  |
The last post was made 18 years, 343 days ago. Instead of replying here, would creating a new thread be more useful? |
