Speedo glass front smashed [UPDATE - Bodged it for now!]
Asharin
PostPosted: 17:51 - 24 Jun 2010    Post subject: Speedo glass front smashed [UPDATE - Bodged it for now!] Reply with quote
I came back to my bike today (was my Dads house) to find the glass front to the speedo clock smashed Sad
No other damage so might have been unlucky stone flung from road, or possibly pikey kids out to be a**eholes.
Either way the clocks/speedo still work fine (after I hoovered out the glass) but they're a mess lookswise. At the moment I have a clear plastic sandwich bag over the top to keep rain out, but that's hardly an ideal solution...
Is it possible to replace the glass front (and is there an idiots guide to..) or am I looking at replacing the whole damn unit?
Bike is a Hyosung Rt125 (aka Hyosung Karion)
DrDonnyBrago
PostPosted: 18:02 - 24 Jun 2010    Post subject: Re: Speedometer glass front smashed :( Fixable? Reply with quote
What bike are we talking about here buddy?
If it is listed on the link below then find your bike, find the fiche containing the speedometer and see if the clock glass is listed as a separate part number... if it is then write down the part number and order it from a UK site, if not then give a stealership/davidsilverspares(Honda only)/Fowlers in Bristol a phone and hope they can source it. Thumbs Up .
https://fiche.ronayers.com/
Asharin
PostPosted: 18:04 - 24 Jun 2010    Post subject: Reply with quote
Oh yeah, whoops! Bike is a Hyosung Rt125 (aka Hyosung Karion) Korean bike
Editing original post to say so too Smile Cheers for pointing that out!
kt
PostPosted: 18:10 - 24 Jun 2010    Post subject: Reply with quote
Measure what you need and get the local glazier to cut it for you
The Artist
PostPosted: 18:17 - 24 Jun 2010    Post subject: Reply with quote
Probably cheaper to buy some second hand clocks off egay or something.
Asharin
PostPosted: 18:18 - 24 Jun 2010    Post subject: Reply with quote
Cool plan! How hard is it to take the cap off the speedo to put new glass in? Never done this kind of thing before Smile
Asharin
PostPosted: 18:19 - 24 Jun 2010    Post subject: Reply with quote
No clocks for mine on ebay or similar. There's some for a Hyosung Comet at startright for £25 but not sure if the fittings are even remotely similar Smile
kt
PostPosted: 19:07 - 24 Jun 2010    Post subject: Reply with quote
Op the speedo must come apart reasonably easily, I had a 250 comet with the same problem a few years back and the speedo came apart easily on it although it probably has differnet clocks, my local glazier cut the circular glass for 4 quid. I beleive your speedo is electronic and not cable operated so should be an easy job. They generally have screws on the underside but best remove the whole unit as it will be easier to work on.
Teflon-Mike
tl;dr
PostPosted: 19:22 - 24 Jun 2010    Post subject: Reply with quote
Unfortunate timing; haven't sorted the pics for this one yet. I have been snapping pics for a 'how to renovate clocks' How-To, using the clocks on the CB125TD as illustration.
It IS very do-able, BUT!
You have to be careful. Lots of clocks are 'sealed' a) to make them tamper-proof, so people are discouraged from 'clocking' the mileage, and to make them weather-proof.
BUT with care, some decent hobby-craft tools, particularly small craft knives and files, a soldering iron, you can get spare bits for, or a cheap one you dont mind getting jukky with plastic, welding the stuff....... can be done!
The 'Glass' IS the snagger, though. It usually IS glass, and suggestion you can use picture glass from your local glaziers, is unfortunately NOT the greatest advice.
You CAN use the stuff....... but its plain glass, and easily broken again. (most likely when you try fitting the damn stuff!)
Stuff in clocks SHOULD be propper automotive grade glass, either toughened or laminated, so that a) its stronger, b) it doesn't brake in stabbing sized shards like picture glass will.
Better, if you can get it, is the proprietry part from propper supplier. Some-times though you have to buy a whole case, OR a whole clock, making it rather expensive.
HOWEVER, if thats the case, you CAN get perspex sheet in variouse thinkness's at most DIY shops, and THAT is what I'd advise trying, rather than picture glass.
Stuff ISN'T as 'good' as propper glass. After a few years it does go yellow, and it does scratch.
BUT it is tougher than picture glass and wont break in the same way, and its reasonably easy to shape for round or more awkward shaped clocks with a junior hack-saw, and files.
Basics are, you need to remove the clocks from the bike. Disconnect speedo-cable, tacho cable if its a mechanical tach, and disconnect the wiring from the main loom.
Then, you can have a look and see what screws and fastenings you have.
Most clocks have an outer or back-case, that comes off with a few screws. Then inside there's a frame that takes all the back-lights and the actual dials.
SOMETIMES these are glued to the frontage, with the glass in it. Some-times they are screwed, OFTEN they are 'pegged'... towers of plastic from the facia surround pass through the whole lot, and are then heated and metled over to seal the whole thing together.
At this point you need to assess what you have, how BEST to split it, and HOW to do it so you stand a chance of putting it back together again.
Patience, imagination & a little common sence needs to be applied.
Once apart, you can get at where the old glass was, and with a bit of luck, buy, fasion and fit new glass (or perspex substitute)...
And put it all back together, neatly. Using a 'LITTLE' silicon sealant around the glass and fasia and other joints, and or glue (Araldite is a good one) and or plastic welding with aforementioned soldering iron..... (and strips cut from an old washing up bottle, pop-bottle, milk-bottle.... or whatever other plastic rubbish is in the bin, with a similar consistency to the cases, to use as 'filler-rod')
For a newbie...... how brave are you?
Check the prices & availabilityof the parts, of new clocks & see if there are any in breakers.
Then Give it a go!
End of the day, if what you got cant be fixed, its scrapped, and its not much good as it is, so what do you have to loose?
At some point I will get a How-To up on the tpic, becouse it is a good one. Clocks can often be fixed, reclaimed, salvaged or 'customised' for penies, and if you want to get a bit creative, as we are with Donna's 'Pup' project, you can often make custom fasias for them..... in her case, to make them look pretty and personalise the bike...... but on 'imports' the same principle can be used to 'recalibrate' the speedo to MPH from clicks!
(Her old Chinese 'Raptor' used to do my head in; was duel calibrated, but with the major marks in KPH... and a mated Jap-Imp 400 with calender dots on the glass was just useless, ugly and in constant need of re-doing!)
Asharin
PostPosted: 20:21 - 24 Jun 2010    Post subject: Reply with quote
Thanks very much for the advice guys, especially the last post Very Happy
I shall give it a go on weds after I finish my night shifts. Worst comes to worst I shall just replace it but lets see if I can fix first Smile
kt
PostPosted: 20:46 - 24 Jun 2010    Post subject: Reply with quote
Teflon, with respect I never mentioned anything about picture glass, the hyosung clock which I repaired came apart with the use of a screwdriver and a couple of spanners and contained a reusable rubber seal. I didnt find it necessary to buy anything other than the glass which was toughened glass which all Glaziers worth their salt will have in stock.
Teflon-Mike
tl;dr
PostPosted: 21:07 - 24 Jun 2010    Post subject: Reply with quote
No... but you didn't mention 'Toughened' either, though.
Now you HAVE, that's good advice.
I haven't taken a Hyosung clock apart, I dont know what the construction is. Hence covering bases, that IF its an awkward one, then some basic craft tools and a bit of crafti-ness can be applied to get round stuff thats not designed to come apart. If its NOT needed, then bonus!
IF you can get toughenedglass thats thin enough, and the roght shape, that IS preferable to perspex, too.
BUT if its an awkward one, or local glaziers dont have suitable toughened glass or wont cut to shape / size for you, then its a 'good' substitute, and is pretty easy to work with.
kt
PostPosted: 21:15 - 24 Jun 2010    Post subject: Reply with quote
Fair enough, and yes the perspex is fine for a while but fades and cracks after the suns got to it . Thumbs Up
Asharin
PostPosted: 21:19 - 24 Jun 2010    Post subject: Reply with quote
Like I said thanks for the advice, all of you, appropriate Karma has been given Smile I'll be having a mess with it on my next days off, It'll have to live with a sandwich bag until then!
DrDonnyBrago
PostPosted: 23:14 - 24 Jun 2010    Post subject: Reply with quote
I've used a johnny to waterproof my phone before - in retrospect a sandwhich bag would have looked a LOT less dodgy...
Pete.
PostPosted: 06:59 - 25 Jun 2010    Post subject: Reply with quote
I've seen a few smashed clocks and they were all broke with long sharp shards like regular glass - never seen anything that broke like toughened glass does.
Glaziers might not have a glass thin enough to replace your clock one - but a picture framer very likely would. If you are worried about flying glass from the clocks in an accident Rolling Eyes then cut a circle from some clear self-adhesive plastic from the craft shop and stick that on the face, that will hold the glass together if it breaks. If it happens to fade in the sun then pull it off and fit another.
a.k.a 'Geri'
stigger
PostPosted: 07:17 - 25 Jun 2010    Post subject: Reply with quote
Forty Squid + Postage...
https://www.hyosungsource.com/hyosungsource/karion-rt125/speedometer-assembly-rt125
Asharin
PostPosted: 15:55 - 25 Jun 2010    Post subject: Reply with quote
So until I have time to sort out new glass, I have bodged it....
Take the lid from this:
https://i285.photobucket.com/albums/ll68/asmodeanv/Bike/20100625_089.jpg
Place over the speedo and add some tape:D
https://i285.photobucket.com/albums/ll68/asmodeanv/Bike/20100625_086.jpg
https://i285.photobucket.com/albums/ll68/asmodeanv/Bike/20100625_087.jpg
https://i285.photobucket.com/albums/ll68/asmodeanv/Bike/20100625_088.jpg
Bit better than the sandwich bag! Should do until I have time/money to fix properly.
ian789
PostPosted: 16:02 - 25 Jun 2010    Post subject: Reply with quote
It's genius Very Happy
Pete.
PostPosted: 19:55 - 25 Jun 2010    Post subject: Reply with quote
That'll be on there forever Very Happy
a.k.a 'Geri'
PostPosted: 20:03 - 25 Jun 2010    Post subject: Reply with quote
Nice bit of bodgery Thumbs Up
I forget whose sig it is, but it goes along the lines of "you can tell the sign of poor workmanship by the wrinkles in the gaffa tape" Smile
There is a gap of 207 days between these two posts...
The last post was made 15 years, 118 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.31 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 122.49 Kb
