engine problems!!!!!!!!!!!!!!!!!!!
shager
PostPosted: 14:06 - 18 Feb 2006    Post subject: engine problems!!!!!!!!!!!!!!!!!!! Reply with quote
iv got a phantom f12 scooter 50cc, it run fine for the first day
come to it to day and when i full throttol it the engine starts to die and goes to very low revs, i checked the air filter an there was a strong smell of petrol coming from it pluss the air filter was wet so i cleaned and dryed it but that made no difference, there is also a drops of liquid comeing out of the exhaust when its running. please any suqestions Thumbs Up
Method
PostPosted: 15:00 - 18 Feb 2006    Post subject: Reply with quote
I dont know anything about scoots at all realy,
But by the sounds of it you are running very rich. Does it smell funny when its idling? Either a petrol or eggy kind of smell?
Check that your choke isnt stuck on... I know some have auto chokes but somehow check that it isnt on constantly?
Hope this is some help, dont realy have a great knowlege base about scoot engines at all, but its a start Thumbs Up
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
meooo
PostPosted: 16:55 - 18 Feb 2006    Post subject: Reply with quote
is it air or water cooled............could be water from a head gasket.
If its fuel coming through the exhaust, possible broken reed valves. ive had this on a yamaha jogrr........wouldnt start, ran poorly.....the reeds were snapped.
shager
PostPosted: 19:08 - 18 Feb 2006    Post subject: Reply with quote
iv just bought carb cleaner and going to put that in now if this doesnt work il have a look at the choke
thax
shager
PostPosted: 19:12 - 18 Feb 2006    Post subject: Reply with quote
this may sound stupid but what is a reed valve.
rpg
PostPosted: 19:36 - 18 Feb 2006    Post subject: Reply with quote
dont worry its not a stupid question Smile A reed valve controls the flow of mixture from the carburettor. It usually gives better fuel economy as it only delivers the mixture to the barrell when its needed, theye give good throttle response and thats basically a reed valve!
veeeffarr
PostPosted: 19:37 - 18 Feb 2006    Post subject: Reply with quote
This another bike you've stolen then?
shager
PostPosted: 21:12 - 18 Feb 2006    Post subject: Reply with quote
no i dont steel bikes thank you very much
shager
PostPosted: 21:22 - 18 Feb 2006    Post subject: Reply with quote
i tryed the carb cleaner but did not make a differene,well at least iv got a clean carb, i think that it is running to rich as there is a strong smell of petrol and the exhurst has drops of petrol coming out of it when it is running.
shager
PostPosted: 21:26 - 18 Feb 2006    Post subject: Reply with quote
i dont think its the reed valves as the bike starts fine and there is good throtle response, the engine runs fine until it is being full throttles and then after a few seconds it cuts out and the revs go right down but the engine never stops
sickpup
Old Timer
PostPosted: 21:33 - 18 Feb 2006    Post subject: Reply with quote
Shager
Look at it like this. You had a CG125 that you wanted to sell that had no ignition. An NSR125 that you asked how to hot-wire, a DT125 with a contradictory story about how you got it that you wanted to know how to hot-wire. You've also advertised that you want a field bike, V5 not needed. Now you have a Firefox.
You've only been on the forum for a little over a month.
If you heard this how would it look to you?
Now I'm not accusing you of being a thief I'm asking you to look at your posts and understand why people may think you are.
shager
PostPosted: 21:41 - 18 Feb 2006    Post subject: Reply with quote
whos got a firefox iv got a phantom f12 50cc do you want to see my v5 or something.
sickpup
Old Timer
PostPosted: 21:43 - 18 Feb 2006    Post subject: Reply with quote
Ok it's a phantom F12 not a Firefox. Now read what I wrote and take heed of why you're getting so much bad karma and sarcastic replies.
Rolling Eyes
meooo
PostPosted: 22:22 - 18 Feb 2006    Post subject: Reply with quote
what air filter is fitted?
the standard one is restrictive and the carb is set up for it, but an after market (sporty type) lets through lots more air, same as if the original was removed, the carb cant cope with that much air (too lean) and wont rev up.
btw, to clean the carb properly you must remove it and strip it to access the jets, squirting carb cleaner into it wont do the job.
Chiz
PostPosted: 22:38 - 18 Feb 2006    Post subject: Reply with quote
The air filter should be wet (if its a foam filter)- on a 2 stroke you can just get it moist with 2 stroke oil. Unless its a (paper) K&N style one. Then it should be dry.
shager
PostPosted: 17:48 - 19 Feb 2006    Post subject: Reply with quote
i have took my carb apart (i wish i didnt) i took the float off and a little bit came off and i now dont no where to put it back the bit is only very small it is like a cy;inder with a spike on the end.
iff any ones got any diagrams that would help,
shager
PostPosted: 20:47 - 19 Feb 2006    Post subject: Reply with quote
i managed to put the carb back together but now when i start the bike it revs but will not move far it goes about 2mph if that please some one tell me whats wrong
veeeffarr
PostPosted: 23:32 - 19 Feb 2006    Post subject: Reply with quote
CLUTCH
The last post was made 20 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 93.78 Kb
