Rear wheel nuts - torque wrench or guess?
Do you use a ...
torque wrench
34%
 34%  [ 22 ]
guess
41%
 41%  [ 26 ]
tight as I can
22%
 22%  [ 14 ]
Other method - and I've told you what it is below
1%
 1%  [ 1 ]
Total Votes : 63
FreshAL
Sir Crashalot
PostPosted: 12:11 - 08 Feb 2006    Post subject: Rear wheel nuts - torque wrench or guess? Reply with quote
When you're tightening rear wheel bolts do you...
I'm just interested what everyone else does really.
www.125power.com
PostPosted: 12:18 - 08 Feb 2006    Post subject: Reply with quote
When i tighten a rear wheel nut, i get a the heftiest looking spanner that will fit, slide a length of stainles steel tube over it and yank it and then if you can stand on it too. Keep an eye on the spanner for it rounding off the nut, and also for it coming off the nut as you will injure your self when it pops off and you have your weight on it.
This works really really well, but if you have poor quality nuts will round them off or strip the inner threads. Kwik-fit have a hard time getting them off with their impact wenches too.
My eBay Items
Suzuki
Roger
PostPosted: 12:19 - 08 Feb 2006    Post subject: Reply with quote
You're an idiot. Laughing
<Simple> no I'm shaven Jon Razz
<Simple> it is a big enough hole.. I'll leave it now
Ride: 1999 Suzuki GSXR600 (yellow/black) IRC: Stats - Relationship Map
www.125power.com
PostPosted: 12:29 - 08 Feb 2006    Post subject: Reply with quote
You're an idiot.
Why Is that? My wheels have spacers in so i can tighten them as much as i please, and wheel wont go stiff....
My eBay Items
Suzuki
Roger
PostPosted: 12:31 - 08 Feb 2006    Post subject: Reply with quote
Because you'll be damaging the thread on your axle for one, and potentially damaging a lot of other things by overtightening the nut, especially if you don't get things perfectly aligned when you do it.
Why do you think things have torque settings? It isn't good to have things too tight! Wink
zaknafien
PostPosted: 12:34 - 08 Feb 2006    Post subject: Reply with quote
I've always just tightened it until I can't move it anymore.
02 Firestorm.
Whosthedaddy
PostPosted: 12:35 - 08 Feb 2006    Post subject: Reply with quote
Bit of guess work, usually as tight as can.
Lesson was learned when I sheared off a wheel stud on a car once Embarassed Theres tight and theres too tight Shifty
LustyLew
PostPosted: 12:46 - 08 Feb 2006    Post subject: Reply with quote
Before I got my torque wrench, I just guessed. Usually until It was tough to tighten any more and then another 1/4 turn.
Now it's torque wrench all the way.
numark1
Scared of girls
PostPosted: 13:03 - 08 Feb 2006    Post subject: Reply with quote
T-Bar and a rubber mallet, hit it a few times until it's fairly tight, not uber tight though. Thumbs Up
Haven't had a wheel fall of yet. Shifty
Absolute_Kwackers
PostPosted: 13:12 - 08 Feb 2006    Post subject: Reply with quote
my god im the only one who uses a torque wrench lol! Laughing
anyway cant really go wrong if i have it tightened to how the manual says!
Barry_M2
PostPosted: 13:21 - 08 Feb 2006    Post subject: Reply with quote
No, I do too. I torque everything that has a setting listed. I also copper slip all threads before I refit, stops your nuts seizing!! Confused Shocked
Laughing Thumbs Up
fuzz
PostPosted: 13:24 - 08 Feb 2006    Post subject: Reply with quote
Suzuki wrote:
You're an idiot.
You stand on it. I have injured my hands before when a spanner has slipped off a nut when I'm using a lot of force, and you stand on the thing and ask why you're an idiot. I think it speaks for itself. Breaker bars were invented for a reason.
https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800
BlackSheep
You are destroying your wheel bearings !
GSXR 1100 StreetFighter
fuzz
PostPosted: 13:27 - 08 Feb 2006    Post subject: Reply with quote
I was told by someone in the trade that you can tighten bolts without specific torque values if there are no bearings behind them, just get them as tight as you can by hand. If they have bearings, you should apply the correct torque as to not damage them.
PostPosted: 13:29 - 08 Feb 2006    Post subject: Reply with quote
Feel free to pop down and use my torque wrench to check your nuts Exclamation.
FreshAL
Sir Crashalot
I've been told it depends if they are taper bearings or not?
any mechanics what to correct that?
PostPosted: 13:34 - 08 Feb 2006    Post subject: Reply with quote
As mentioned, they have spacers so shouldn't be /too/ much of a problem for non taper bearings, which bikes ones usually are.
If I tightened stuff up to the point that it was as hard as I cound turn it with an extended spanenr there would be a lot of knackered threads Confused.
PostPosted: 15:31 - 08 Feb 2006    Post subject: Reply with quote
I do them up 'till they are as tight as I would reasonably expect to be able to remove again at the side of the road with the bike tool-kit. Really enough to feel it 'nip' then another 1/4 turn
If you check with a torque wrench, they don't really need to be all that tight. You certainly shouldn't be bursting a blood vessel over it or having to stand on the spanner. It is a big, fine pitch, castellated nut with an R-clip, they can't come undone.
akaDAVE
PostPosted: 16:50 - 08 Feb 2006    Post subject: Reply with quote
Usually I push it until my thumb starts to hurt, then just to be safe I put a tea-towel over the bolt and give it another good twist. Thumbs Up
GSXR600
WildGoose
White Van Man
PostPosted: 17:06 - 08 Feb 2006    Post subject: Reply with quote
for gods sake dont use an open ended spanner, ring spanner minimum
torque wrench Exclamation
experienced spannner twiddlers will tell you all about feeling how tight a nut needs to be, but this has always felt a bit wishy washy to me
ive fucked an equal amount of fasteners both by trying to 'feel' and by using a torque wrench
remember torque wrenches are damn sensitive pieces of equipment and would wager than most people who own them dont treat them with the respect they need to hold their accuracy, most are fairly innaccurate anyway
you cant win in this respect, without a device for measuring the applied torque, such as an indicating torque wrench or a wall mounted device (such as an Acratork) that you plug your torque wrench into to measure the applied force and breaking point, but again these need to be calibrated as well, and realistically if you arent a business you arent going to call someone out to calibrate them every 6 months
there seems to be no way around it, to make it an exact science
generally.
-dont drop your torque wrench
-wind it fully off after each use but not past the end of the range, wind it to its minimum value
-dont continue turning after its passed its breaking point
-dont use it for undoing anything that is past its maximum torque value
-dont use it as a hammer
make sure youve got the torque correct, i.e. when haynes give diameter of fasteners they are usually talking about the thread diameter not the bolt head
sounds simple but thats taken my bike off the road before
PostPosted: 17:46 - 08 Feb 2006    Post subject: Reply with quote
Angular tensioning is a more accurate way of doing the job and removes the need for a torque wrench. It is how the cylinder head bolts on most cars are done these days. (ie put the nut on by hand so the nut is on the bottom thread then give it six turns clockwise, back it off four then tighten two kind of thing.)
This tightens the bolt by a fixed distance (because you already know the pitch of the thread) and means that 'sticky vs oiled threads and inaccuracies in the torque wrench don't come into play.
To be honest, I know more peole who have stripped threads because they either didn't notice the torque wrench break or because it didn't break for some reason than by overtightning by hand.
Come to think of it, the only people I have ever heard of loosing the back wheel out of their bike are 1960's Lambretta owners (Which had a badly designed wheel spindle).
True Blue
PostPosted: 18:31 - 08 Feb 2006    Post subject: Reply with quote
I borrowed a torque wrench once and tightened it up. When I done this I was able to gauge how tight it should be when doing it by hand.
Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>>
PostPosted: 18:33 - 08 Feb 2006    Post subject: Reply with quote
Freshal Exclamation Exclamation
The SV650 has one of them Suzuki flexible swingarms, where if you do the rear wheel nut up too tight then it can put extra tension on the chain and make the swingarm flex inward.
This is very bad.
Please please please use a torque wrench. As G said, he is in Reading, as am I. In fact I got two Halfords torque wrenches (of different ranges) for Christmas.
The Tot
PostPosted: 19:11 - 08 Feb 2006    Post subject: Reply with quote
Just did mine today. I finger tightened it as close as it goes, then torqued it up to the approximate value - it's bloody hard to read the scales once the light goes. Most bikes have cotter pins on their bolts to stop the bolt coming off the axle nut so either way, there's a sure fire warning if you haven't torqued it up properly.
Also torquing things up too tightly will reliably ensure that you get a cross threaded bolt. Doing things too tight can also limit the free play of the wheels.
Never argue with autism
www.125power.com
PostPosted: 19:22 - 08 Feb 2006    Post subject: Reply with quote
Think i gunna buy a torque wrench then, seem to better than standing on a "breakers" bar........
My eBay Items
The last post was made 20 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.01 - MySQL Queries: 15 - Page Size: 139.17 Kb
