| Do you use a ... |
| torque wrench |
34% |
[ 22 ] |
| guess |
41% |
[ 26 ] |
| tight as I can |
22% |
[ 14 ] |
| Other method - and I've told you what it is below |
1% |
[ 1 ] |
| Total Votes : 63 |
| FreshAL |
 FreshAL Sir Crashalot
| www.125power.com |
 www.125power.com Crazy Courier
 Posted: 12:18 - 08 Feb 2006 Post subject: |
When i tighten a rear wheel nut, i get a the heftiest looking spanner that will fit, slide a length of stainles steel tube over it and yank it and then if you can stand on it too. Keep an eye on the spanner for it rounding off the nut, and also for it coming off the nut as you will injure your self when it pops off and you have your weight on it.
This works really really well, but if you have poor quality nuts will round them off or strip the inner threads. Kwik-fit have a hard time getting them off with their impact wenches too. ____________________ My eBay Items |
| Suzuki |
 Suzuki Roger
| www.125power.com |
| Suzuki |
 Suzuki Roger
| zaknafien |
 zaknafien
| Whosthedaddy |
 Whosthedaddy Super Spammer
 Posted: 12:35 - 08 Feb 2006 Post subject: |
Bit of guess work, usually as tight as can.
Lesson was learned when I sheared off a wheel stud on a car once Theres tight and theres too tight  ____________________ Current : MSX 125 Past : CBR 900RR Monkeybike : c50 LAC : ZXR750 H2 : FZR600 : ZX7R P3 : YW100 : TRX850: Trophy 900 T309 : GSXR 600 L0: Monkeybike : XJ6S Whosthedaddy |
| LustyLew |
 LustyLew World Chat Champion
 Posted: 12:46 - 08 Feb 2006 Post subject: |
Before I got my torque wrench, I just guessed. Usually until It was tough to tighten any more and then another 1/4 turn.
Now it's torque wrench all the way. ____________________ Like a Yorkie - I'm not for the girls  |
| numark1 |
 numark1 Scared of girls
 Posted: 13:03 - 08 Feb 2006 Post subject: |
T-Bar and a rubber mallet, hit it a few times until it's fairly tight, not uber tight though.
Haven't had a wheel fall of yet.  |
| Absolute_Kwackers |
 Absolute_Kwackers Renault 5 Driver
 Posted: 13:12 - 08 Feb 2006 Post subject: |
my god im the only one who uses a torque wrench lol!
anyway cant really go wrong if i have it tightened to how the manual says! |
| Barry_M2 |
 Barry_M2 World Chat Champion
 Posted: 13:21 - 08 Feb 2006 Post subject: |
| fuzz |
 fuzz World Chat Champion
| BlackSheep |
 BlackSheep Trackday Trickster
| fuzz |
 Posted: 13:27 - 08 Feb 2006 Post subject: |
I was told by someone in the trade that you can tighten bolts without specific torque values if there are no bearings behind them, just get them as tight as you can by hand. If they have bearings, you should apply the correct torque as to not damage them. ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
| G |
 G The Voice of Reason
 Posted: 13:29 - 08 Feb 2006 Post subject: |
Feel free to pop down and use my torque wrench to check your nuts . |
| FreshAL |
| G |
 Posted: 13:34 - 08 Feb 2006 Post subject: |
As mentioned, they have spacers so shouldn't be /too/ much of a problem for non taper bearings, which bikes ones usually are.
If I tightened stuff up to the point that it was as hard as I cound turn it with an extended spanenr there would be a lot of knackered threads . |
| stinkwheel |
 Posted: 15:31 - 08 Feb 2006 Post subject: |
I do them up 'till they are as tight as I would reasonably expect to be able to remove again at the side of the road with the bike tool-kit. Really enough to feel it 'nip' then another 1/4 turn
If you check with a torque wrench, they don't really need to be all that tight. You certainly shouldn't be bursting a blood vessel over it or having to stand on the spanner. It is a big, fine pitch, castellated nut with an R-clip, they can't come undone. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| akaDAVE |
 akaDAVE World Chat Champion
 Posted: 16:50 - 08 Feb 2006 Post subject: |
Usually I push it until my thumb starts to hurt, then just to be safe I put a tea-towel over the bolt and give it another good twist.  ____________________ GSXR600 |
| WildGoose |
 WildGoose White Van Man
 Posted: 17:06 - 08 Feb 2006 Post subject: |
for gods sake dont use an open ended spanner, ring spanner minimum
torque wrench
experienced spannner twiddlers will tell you all about feeling how tight a nut needs to be, but this has always felt a bit wishy washy to me
ive fucked an equal amount of fasteners both by trying to 'feel' and by using a torque wrench
remember torque wrenches are damn sensitive pieces of equipment and would wager than most people who own them dont treat them with the respect they need to hold their accuracy, most are fairly innaccurate anyway
you cant win in this respect, without a device for measuring the applied torque, such as an indicating torque wrench or a wall mounted device (such as an Acratork) that you plug your torque wrench into to measure the applied force and breaking point, but again these need to be calibrated as well, and realistically if you arent a business you arent going to call someone out to calibrate them every 6 months
there seems to be no way around it, to make it an exact science
generally.
-dont drop your torque wrench
-wind it fully off after each use but not past the end of the range, wind it to its minimum value
-dont continue turning after its passed its breaking point
-dont use it for undoing anything that is past its maximum torque value
-dont use it as a hammer
make sure youve got the torque correct, i.e. when haynes give diameter of fasteners they are usually talking about the thread diameter not the bolt head
sounds simple but thats taken my bike off the road before ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| stinkwheel |
 Posted: 17:46 - 08 Feb 2006 Post subject: |
Angular tensioning is a more accurate way of doing the job and removes the need for a torque wrench. It is how the cylinder head bolts on most cars are done these days. (ie put the nut on by hand so the nut is on the bottom thread then give it six turns clockwise, back it off four then tighten two kind of thing.)
This tightens the bolt by a fixed distance (because you already know the pitch of the thread) and means that 'sticky vs oiled threads and inaccuracies in the torque wrench don't come into play.
To be honest, I know more peole who have stripped threads because they either didn't notice the torque wrench break or because it didn't break for some reason than by overtightning by hand.
Come to think of it, the only people I have ever heard of loosing the back wheel out of their bike are 1960's Lambretta owners (Which had a badly designed wheel spindle). ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| True Blue |
 True Blue World Chat Champion
 Posted: 18:31 - 08 Feb 2006 Post subject: |
I borrowed a torque wrench once and tightened it up. When I done this I was able to gauge how tight it should be when doing it by hand. ____________________ Past >>>> Honda NSR 125 >>>> Suzuki GSXR 600 K1 >>>> Suzuki GSXR 600 K4 >>>>Kawasaki Z1000 DAF >>>>Suzuki RMZ 250 >>>> Current >>>> KTM Superduke R 1290 >>>> |
| MarJay |
 MarJay But it's British!
| The Tot |
 The Tot World Chat Champion
| www.125power.com |
 Posted: 19:22 - 08 Feb 2006 Post subject: |
Think i gunna buy a torque wrench then, seem to better than standing on a "breakers" bar........ ____________________ My eBay Items |
The last post was made 20 years, 158 days ago. Instead of replying here, would creating a new thread be more useful? |
