fuel pressure
idahos_dirty_d
PostPosted: 05:16 - 24 May 2006    Post subject: fuel pressure Reply with quote
hey everyone hows it going? alrite my question is i have a 94 suzuki RF600r and im getthing really bad fuel flow everthing is clean now it brings me to the fuel pump. what psi should i be running. that is my question. thanks guys
Barry_M2
PostPosted: 10:22 - 24 May 2006    Post subject: Reply with quote
If it runs carbs, then I believe about 2 or 3 psi. For fuel injection it would be alot more, but I'm not sure what.
edd
PostPosted: 14:16 - 26 May 2006    Post subject: Reply with quote
EFI is about 45 psi usually, as Barry said carbs are usually fed at 2-3 psi, sometimes a little more.
Bluespark Automotive - Diesel Tuning for Performance and Economy
Finglonga
PostPosted: 18:14 - 26 May 2006    Post subject: Reply with quote
Would a 94 bike have a fuel pump with carbs? Thought it would be gravity fed. Confused
Andy Sez....
F.Y.Y.F.F.
Barry_M2
PostPosted: 20:05 - 26 May 2006    Post subject: Reply with quote
Depends on the bike to be honest.
If your feeding a single carb, or maybe two, then gravity fed is usually sufficient, but depends on the bike really.
But feeding a bank of 4 will require a fuel pump, gravity feed will never supply enough fuel, especially at full throttle.
edd
PostPosted: 01:11 - 27 May 2006    Post subject: Reply with quote
My Zephyr and GPz are both gravity feed 4 cylinder 750's with vacuum fuel taps. You can supply as much fuel as you like by gravity, just depends on the bore of the pipe, where the fuel tank is, and where the carbs are as to whether a pump is needed. Bikes have had fuel pumps since long before 1994. Also the RF 600 98 model has a fuel pump, so i would suspect yours does too. if you want to replace your pump id put money on this: https://cgi.ebay.co.uk/SUZUKI-RF900R-RF-900-R-RF900-R-FUEL-PUMP_W0QQitemZ8067367794QQcategoryZ10534QQssPageNameZWDVWQQrdZ1QQcmdZViewItem being suitable for your bike, it looks the same as the 98 rf 600 one and at a fiver its not really too pricey. Good luck with it mate.
The last post was made 20 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 47.2 Kb
