| Klause |
 Klause World Chat Champion
 Posted: 14:44 - 25 May 2006 Post subject: DIY Clutch window |
Making a clutch window for my Monster
Been toying the idea for a while and came across a clutch cover at BMF show for £20 bargin, so who cares if it fu*ks up .
I asked for advice in the workshop section for what window material to use and lexan seemed to be the thing to use. Ordered an a4-a3 ish sized sheet 5mm thick for £9.
The sheet arrived today. So armed with some new drill bits and a dremel I set off...
Drilled holes all the way around the inside of the circle, then took the dremel and cut inbetween the gaps, went through 4 bloody cutting discs!
https://img207.imageshack.us/img207/7836/dscf16334dt.jpg
Spent a while filing it all even but I was doing this all by free hand so not perfect.
Doesn't look to bad now...
https://img136.imageshack.us/img136/9273/dscf163618ye.jpg
Just cutting the lexan now and shall hopefully have pictures of it finished later. ____________________ Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie. |
| T1z3R |
 T1z3R World Chat Champion
 Posted: 16:08 - 25 May 2006 Post subject: |
like windows in PC cases but better  ____________________ duck my sick! |
| Klause |
| Klause |
| Deano |
 Deano World Chat Champion
| Wave2k |
 Wave2k G's Stalker
 Posted: 12:24 - 26 May 2006 Post subject: |
ahhh the joy of dry clutches . ____________________ Ducati 1299 Panigale
2009 Corvette C6 z51
RS125->CBR400->RXS100->GSXR750K2->Ducati749S->CBR600RR5->TL1000R->DRz400->RSVR1000->Honda VTR SP1->CBR400->GSXR1000K6->Honda H100->CBR600RR3->Ducati1299 |
| Barry_M2 |
 Barry_M2 World Chat Champion
| trevoriv |
 trevoriv World Chat Champion
 Posted: 14:40 - 26 May 2006 Post subject: |
Is it not going to be under different kinds of pressure when the engine is running though  |
| Jenks |
 Jenks World Chat Champion
| Klause |
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| Zimbo |
 Zimbo World Chat Champion
| Klause |
 Posted: 23:02 - 26 May 2006 Post subject: |
I've considered all this, but after drilling and dremeling the clutch cover I would hardly say that was strong either, it was made of cheese this lexan stuff seems stronger.
| Zimbo wrote: | | wave2k wrote: | ahhh the joy of dry clutches  . |
Seconded!!!
I'm a little worried about this Klause, I fear you may damage your engine, big time. This may seal for a bit, but under running conditions with the pressure and temperature fluctuations etc, plus the possibility of force being exerted accidently from the outside, chances are one day whilst riding it'll become dislodged, possibly catching in the clutch and smashing things up inside, and also allowing all the engine oil to escape and causing catastrophic engine failure.
If it were mine, I'd stop now and go back to using the solid version, if you really want a visible clutch why not buy a 900? |
| McJamweasel |
 McJamweasel BCF Junkie
| Zimbo |
| DaveH |
 DaveH World Chat Champion
 Posted: 00:13 - 27 May 2006 Post subject: |
If the lexan is cut to the full diameter of drilled face of the clucth cover, not just slightly bigger than the hole, it looks as though there will be enough room for a couple of bolts - with the heads on the inside and the nuts loctited on?
good luck
BTW how much clearance is there between the clutch and the housing? |
| Deano |
| DaveH |
| senna_f4 |
 senna_f4 Scooby Slapper
| Zimbo |
| McGee |
 McGee O RLY?
| Zimbo |
| McGee |
 McGee O RLY?
| Zimbo |
| Klause |
 Posted: 13:51 - 29 May 2006 Post subject: |
| Zimbo wrote: | | DaveHogg wrote: |
pop rivets might be better  definitely! |
Don't forget it's still got to seal the oil in as well! Pop rivets don't seal, at all.
I'm sorry Klause but I'm afraid you've ruined a good clutch cover for nothing, can't see this working, and there's a fairly high risk of you turning your bike engine into worthless scrap. As I said, it's your bike, but in my view it's not worth it, no way. |
Hardly, loads of people have clutch windows, don't see them having much problems. Believe me I'm testing this before I use it, some of my tests envolve hitting it with a hammer and still hasn't come loose. It's strong enough but I'm not happy with the sealing.
I'm taking my time making this havn't touched it this weekend mostly being round mates drinking .
And yes It is a wet clutch but no it's not a 600 . ____________________ Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie. |
The last post was made 20 years, 160 days ago. Instead of replying here, would creating a new thread be more useful? |
