Very sooty plugs.
DukeRed
PostPosted: 22:30 - 27 May 2006    Post subject: Very sooty plugs. Reply with quote
Hi,
The bike suddenly went from running ok to having to put on full throttle and limp away from lights, stalling, top speed about 60 in 5th.
The plugs where nasty and black. However these where new about 3/4 months ago so I think it's another problem but don't know what.
Also noticed the plug already in there was DR8EA and the one proper one is DPR9EA-9.
Putting new ones in has sorted the problem but worried this is a symptom of something else.
Enjoy Life There's Plenty of Time to be Dead
https://www.janoner.com
Walloper
PostPosted: 22:54 - 27 May 2006    Post subject: Reply with quote
Could be a number of things.
But it is a symptom.
Plugs have different heat ratings. The heat burns off any stuff that sticks to the plug electrodes.
The fouled plug may have been running too cold to self-clean.
If the problems clears then wrong plugs was the problem.
https://www.boschautoparts.co.uk/pcPlug1.asp?c=2&d=1
Zimbo
PostPosted: 00:46 - 28 May 2006    Post subject: Reply with quote
I take it that it's an air cooled 2 valve Ducati then? Injected or carbed?
Sooty plugs is usually an indication of running over rich, having the proper plugs in may cure it, if not a previous owner may have jetted the bike for an open airbox and cans, and put it back to standard when he sold it on.
DukeRed
PostPosted: 01:20 - 28 May 2006    Post subject: Reply with quote
It's a TRX. Just standard jetting but emulsion tubes might be worn + K&N, Harris exhausts and dodgy exhaust gaskets with no clamps.
I imagined this would make it run lean but the symptoms are that of running too rich Confused . Will leave it for a while and see if the plugs screw up again.
Finglonga
PostPosted: 11:08 - 28 May 2006    Post subject: Re: Very sooty plugs. Reply with quote
Have you put the correct plugs in?
Andy Sez....
F.Y.Y.F.F.
The last post was made 20 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 44.39 Kb
