Rectifier cooked my connector block
ram_doom
PostPosted: 19:18 - 28 May 2006    Post subject: Rectifier cooked my connector block Reply with quote
Did something rather thick t'other day, battery was flat so quickly borrowed one out of a mates 400, and let it run for a bit. All of a sudden smoke started pouring from the rec, so switched the bike off. Realised then that must've been the amp difference Neutral
Now I've removed the rectifier, I can see that part of the connector block that goes into the loom is fried black and melted can I just plug in a new one somewhere or should it be ok to cut the connector and fit a new one. I have a spare rectifier ready to go :">
TL1000s, KDX200
sickpup
Old Timer
PostPosted: 19:36 - 28 May 2006    Post subject: Reply with quote
Amp difference?
Think you may have a wiring problem as well as a fubared reg/rec.
Sephiroth
PostPosted: 23:36 - 28 May 2006    Post subject: Reply with quote
I think your bike is fucked.
ram_doom
PostPosted: 00:21 - 29 May 2006    Post subject: Reply with quote
At least its not a bandit Wink fucked was an optional extra on mine, standard on yours!
TL1000s, KDX200
edd
PostPosted: 22:18 - 29 May 2006    Post subject: Reply with quote
the different battery shouldnt have made a single bit of difference, Kawasaki reg/recs.....GRRR. Wire your new one in and check that everything is sweet.
Bluespark Automotive - Diesel Tuning for Performance and Economy
ram_doom
PostPosted: 23:25 - 29 May 2006    Post subject: Reply with quote
Thanks chaps, gonna need to cut out, and replace the connector block as half of it crumbled away in my hand Neutral will let ye know how I get on. Would it be worth checking the stator coils too?
TL1000s, KDX200
sickpup
Old Timer
PostPosted: 23:47 - 29 May 2006    Post subject: Reply with quote
Yes.
Sephiroth
PostPosted: 01:07 - 30 May 2006    Post subject: Reply with quote
At least when mine works it wont need fixing every 20 minutes Wink.
NC30UK
PostPosted: 01:27 - 30 May 2006    Post subject: Reply with quote
Not a VFR by any chance is it? Razz
Get a new reg/rec off ebay for £35 (same as cbr600 one) and replace the wiring.
PostPosted: 01:35 - 30 May 2006    Post subject: Reply with quote
Just connect it using bullet connectors. Cut back the burned stuff on the loom and the terminal on the new one and fit bullets to the ends of them.
You might want to look into why that happened a bit more thoroughly though, before you just plug in your new (expensive) rectifier in case that happens again.
ram_doom
PostPosted: 16:16 - 30 May 2006    Post subject: Reply with quote
Its the zxr400 in my bikepics link Embarassed got a rec off ebay for £12 quid Thumbs Up the old one melted all the rubbery stuff in the bottom Shocked
Thanks for the advice people! Will let know if it runs when I've fiddled with it...
TL1000s, KDX200
The last post was made 20 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.28 - MySQL Queries: 13 - Page Size: 67.5 Kb
