Test Safety check questions
newbiekid
PostPosted: 23:19 - 29 May 2006    Post subject: Test Safety check questions Reply with quote
One of the examiners questions is about brake fluid,
I have a 1996 Honda CG125, i can't see any fluid resevior, Does it have one and if so where?
Am I blind or do some bikes not have this
Thanx in advance
Trip
PostPosted: 23:48 - 29 May 2006    Post subject: Reply with quote
If its the same as mine and has drum brakes then no there is no resivoir. Im pretty sure if you use that bike they wont ask you that question. There are different combinations of questions they can ask you.
Bike: Yamaha XJ600N Mileage: 28500 Miles Rider Mileage: Many Miles
CBT: PASSED Theory: PASSED Test: PASSED
Past-CG125 Present - Yamaha XJ600N Future - WHO KNOWS?
Lawnie
PostPosted: 23:50 - 29 May 2006    Post subject: Reply with quote
I'm pretty sure a '96 CG125 would have drums.
veeeffarr
PostPosted: 02:22 - 30 May 2006    Post subject: Reply with quote
There's no discs.
Only fluids you need to check before you set off are
Oil.
Your bladder.
That's it.
The procedure for checking oil is:
Unscrew dipstick
Wipe with a rag
Put back into engine case but do not screw it in
Remove dipstick
Check oil level on the hash marked part at the bottom of the stick
Put back in (I usually wipe the filler port too).
Cheers,
T
The last post was made 20 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.6 - MySQL Queries: 13 - Page Size: 38.77 Kb
