Clutchless gear
Sephiroth
PostPosted: 22:15 - 30 May 2006    Post subject: Clutchless gear Reply with quote
Well, I haven't put the new parts on yet, but the bike goes up through the gears from N without using clutch, I'm guessing that's not normal?
What can I do? Shocked
And no I haven't started it up to check, just turned it on for the lights to come up.
Bike: Suzuki GSF400VVM.
Nath
PostPosted: 22:16 - 30 May 2006    Post subject: Reply with quote
Perfectly normal.
Hard livin', hard luck.
Sephiroth
PostPosted: 22:19 - 30 May 2006    Post subject: Reply with quote
Yay Laughing
Thought I buggered it Very Happy
Quote Me Happy
Luckily for you clutchless upshifts are perfectly normal. I'd only do them from 2nd - 6th though.
They work particularly well if you are hammering it - just preload the gear lever with a bit of pressure and back off the throttle a bit and it should slot into the next gear silky smooth - no clutch needed.
Don't do it going down through the box though.
Sephiroth
PostPosted: 22:22 - 30 May 2006    Post subject: Reply with quote
Nonono, the bike isn't going anywhere, as I came of and buggered it up. But the gear box *while it's on centre stand* allows it to go up through the gears without clutch, but not down to 1st.
Guest
PostPosted: 22:23 - 30 May 2006    Post subject: Reply with quote
You sometimes need to waggle the back wheel to go through the box with the engine off, but not always. Should be alright, depends what you've been doing - "new parts" doesn't really tell us much Wink
Absolutely no problem if done correctly Rolling Eyes
Nath
Try rocking the back wheel back and forth a little and it should drop down into first.
Sephiroth
PostPosted: 22:37 - 30 May 2006    Post subject: Reply with quote
No, I just wanted to know if it's normal for the bike to go up through the gears, when the engine is not running Rolling Eyes.
I know how do to do clutchless upshifts and downshifts when I'm riding but I'm not, it's buggered.
New parts:
New indicators
Headlight
Engine casing
Gear lever
Footpeg
Heel bracket
edd
PostPosted: 23:10 - 30 May 2006    Post subject: Reply with quote
why is it buggered? unless its got a positive neutral system like most kwaks it should be able to go through all the gears. Confused
Bluespark Automotive - Diesel Tuning for Performance and Economy
Sephiroth
PostPosted: 23:23 - 30 May 2006    Post subject: Reply with quote
I didn't know if it was or not Shocked.
Guess no one gets what I mean?
And it's a Suzuki.
Ichy
PostPosted: 00:49 - 31 May 2006    Post subject: Reply with quote
I can do the same on most of my bikes, no problem. And yes I understand what you mean, bikes in the garage not moving, not started Laughing
Sephiroth
PostPosted: 00:52 - 31 May 2006    Post subject: Reply with quote
Thanks Marki, all I wanted to know Smile.
Shall let you know how well of a job I do putting the stuff on!
Oh btw the bike turns more to the left than it does to the right (result of the crash, tank got slightly dented on the left).
the grim reaper
PostPosted: 10:23 - 31 May 2006    Post subject: Reply with quote
Most of mine will go up a couple of gears but then require the rear wheel to be moved to align the dogs. A lot of them wouldn't go into 1st though, mainly because of neutral.
And this was without the engine running Mr. Green
Mind you, even with the engine running, my VFR400 would never go into neutral, bt this wasn't what you were asking, was it? Mr. Green
Grim
Guest
PostPosted: 10:49 - 31 May 2006    Post subject: Reply with quote
Several of the answers would indicate we know exactly what you mean Thumbs Up
tonyyzf
PostPosted: 12:47 - 31 May 2006    Post subject: Reply with quote
You should be able to get it into all the gears, engine running or not, the lower gears, particularly first will be stickier cos they're smaller ratios.
Jenks
PostPosted: 12:50 - 31 May 2006    Post subject: Reply with quote
You'r just not having much luck with bikes recently are you Sephiroph! Sad
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Sephiroth
PostPosted: 13:15 - 31 May 2006    Post subject: Reply with quote
Was just checking incase it was buggered. As you can tell, I don't know much about bikes and if it were buggered I'd have to get it fixed Razz.
Thanks.
The last post was made 20 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.4 - MySQL Queries: 16 - Page Size: 95 Kb
