HELP
GSXF
PostPosted: 23:34 - 01 Jun 2006    Post subject: HELP Reply with quote
Hi i have just joined and this is my first post. I own a suzuki gsxf600 and i was wondering if anyone could help me with a problem i am having.
I have just changed the brake pads and discs. I have also stripped both calipers and changed all the seals. After bleeding the system there is still no pressure at the brake lever There is no air left in the system but can not get any pressure on the brake lever.
I would be grateful if any one could offer me any advice . Hope to hear from someone soon, cheers for reading.
edd
PostPosted: 00:05 - 02 Jun 2006    Post subject: Reply with quote
when you bled the brakes, did you pump all the air out, then hold the lever back to the bar while you tightened the bleed nipple up? Then when you let it go you should have some feel. If you did this then please say what you have tried, or what method you have used to bleed the system. Thumbs Up
Bluespark Automotive - Diesel Tuning for Performance and Economy
veeeffarr
PostPosted: 00:06 - 02 Jun 2006    Post subject: Reply with quote
How did you get 1 and a 1/2 karma on your first post? :S
Vin
PostPosted: 00:10 - 02 Jun 2006    Post subject: Reply with quote
The same way you got 1.5 gold for >6000 posts. Laughing
GSXF
PostPosted: 10:42 - 02 Jun 2006    Post subject: Reply with quote
Cheers Edd for your post.
First of all i had a noise and vibration from the front of my bike. This is the second winter i have been thru so i decided t change the front brake pads.
I have, stripped calipers and replaced seals.
I changed the pads and could get very little pressure on the front lever. I took it to Sherwoods, Birmingham who charged me £50 to tell me there was no air in the system and told me it would be best to change the discs, which i have done. This has made no difference to the pressure on the front brake lever and am stuck as what to do next.
Some one told me it could be the caliper mounting bracket, but have just bin told it does not come separate from the caliper at a cost of £400+vat.
Any advice would be fantastic Thumbs Up as im getting DESPERATE Shocked
fuzz
PostPosted: 12:15 - 02 Jun 2006    Post subject: Reply with quote
Where abouts are you? I live real close to Sherwoods. I might be able to come and see for myself? I can't understand how you could have no pressure if there is no air in the system Confused
https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800
Bezzer
PostPosted: 12:20 - 02 Jun 2006    Post subject: Reply with quote
Could be the master cylinder seal knackered, letting fluid past as you pull the lever so you don't get the pressure, when you are bleeding there is less resistance as you open the nipple so it will pump some fluid through but shut the nipple and the resistance is enough to blow the fluid past the master cylinder seals.
But what a load of bollocks that changing a disc helps brake pressure Confused if they are that good I also wouldn't accept that they are happy there is no air in the system. To make sure start again by using a syringe of fluid to fill the calipers through the nipple forcing it up the brake pipes to the reservoir, that is pushing the air up and out in the way it naturally wants to go, angle the reservoir so the banjo is the lowest point to make sure no air get traps round it as you are doing it. When you've got fluid in the reservoir and done both sides just bleed as normal to make sure. That way you're really guaranteeing there is no air and can then go to the master cylinder.
GSXF
PostPosted: 00:36 - 03 Jun 2006    Post subject: Reply with quote
Very Happy Hi just thought i'd let you know about the latest developments.I tried one last time to bleed the breaks but could still get no air out of the system.So i took it down to Sheldon motorcycles.They were very helpful and told me that the breaks just needed to bed in.Run them in for about 50 miles then they should be ok.But if i didnt feel they were ok to take it back and he would have it in and get the mechanics to have a look free of charge Very Happy oh and recomended braided lines witch i will fit when i get some more of the green stuff Confused But i am much happier with the service i got from him rather than the 50 quid sherwoods charged me for just bleeding the breaks Evil or Very Mad I hate it when you get bullshited by people that think they know more than you do.Anyway i wownt be recomending sherwoods to anybody soon.Thanks for listening Thumbs Up
fuzz
PostPosted: 18:53 - 03 Jun 2006    Post subject: Reply with quote
Is there pressure at the lever, or is there just not much stoppping power? From your first post it seemed that there was no pressure at the lever, which would not get better after bedding in the brakes because it would mean the brakes are useless (and therefore you can't bed them in!) If there is pressure at the lever but the brakes aren't as strong as they used to be then it would indicate needing to break in new pads.
GSXF
PostPosted: 00:26 - 04 Jun 2006    Post subject: Reply with quote
Very Happy HI what a great day for biking Cool .Well it would have been if i wernt stuck under the misses car putting it through the mot Thumbs Down .Any way i digress yes there is preesure some pressure at the lever just not as good as it used to b.Am going to have a last bleeding session tomoz after i have the car put back together.Hope the breaks do bed in but will be putting some braided lines on soon. Happy biking to ya allllllllllllllllllllll tmany thanks 4 all the help full tips Thumbs Up keep em comin Very Happy
GSXF
PostPosted: 00:27 - 04 Jun 2006    Post subject: Reply with quote
WHAT A LOAD OF SPELLING MISTAKES SOZ Confused
proximity
PostPosted: 01:05 - 04 Jun 2006    Post subject: Reply with quote
A tip i find good for bleeding is to connect a pipe from the bleed nipple up to the reservoir, then just keep pumping, you will see little bubbles of air in the fluid that never got out when you just bled the brakes till fluid came out.
When this is done, tighten the nipple when the lever is pulled in.
This made my brakes solid. Hope it works.
I hope your old disc was fucked, otherwise you have been ripped.
2004 Aprilia Tuono
Finglonga
PostPosted: 12:21 - 04 Jun 2006    Post subject: Reply with quote
Don't worry about it,Wink you know the difference between a PC and a Bloody mobile phone unlike some on most the other threads!! Thumbs Up Feckin txt talk gets on my tits! Thumbs Down
Andy Sez....
F.Y.Y.F.F.
edd
PostPosted: 16:00 - 04 Jun 2006    Post subject: Reply with quote
A half decent trick for getting more pressure at the lever is to hold your brake lever under pressure. Get something like and old inner tube out of a push bike tyre, a belt, or something like. Wrap it around the lever while you have the lever as compressed as possible. Leave the lever strapped to the bar for a while (an hour or so), come back and repeat the process. Leave it again, perhaps overnight. This should return some feel to the lever. Dont overdo this as it can make your brakes bind.
GSXF
PostPosted: 21:43 - 04 Jun 2006    Post subject: Reply with quote
Cool Hi ya alllllllllllllllllllllllllllllllll Thumbs Up Thanx for the tip edd will go and tie my lever up an leave it over nite. Just finished fixin my misses car for the mot an just chillin with a beer Wink Bloody work again tomorrow Middle Finger Veeva las holidays Have a good week ya allllllllll Thumbs Up
The last post was made 19 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 87.07 Kb
