Life savers
sunbear
PostPosted: 12:33 - 02 Jun 2006    Post subject: Life savers Reply with quote
Bit confused over when to use life savers at a rounabout. Where and when on a single lane, double lane, tripple lane etc? Any advice would be great so i can get in to the habbit before my test in two months time. Cheers Thumbs Up
Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT !
Groove
PostPosted: 12:41 - 02 Jun 2006    Post subject: Reply with quote
When you leaving mainly and over the shoulder of the direction your heading.
Thumbs Up HTH
EDIT: Also when changing lanes etc or changing direction in any way...
JBurrows88
PostPosted: 12:53 - 02 Jun 2006    Post subject: Reply with quote
Lifesavers should be done whenever necessary. Exclamation Laughing
When turning right always look over your right shoulder.
You must have a clear picture of what is going on behind you.
Remember rear observations include using lifesavers to get a view of your blind spots (areas not visible in your mirrors). A common mistake is performing a life-saver without knowing what you are looking for.
You should perform rear observations:
Before you change speed (e.g. going from a 30 mph limit to a National)
Before you change direction (e.g. turning left or right).
Before you stop or pull over except when performing an emergency stop.
Before you change position in the road (e.g. moving into the centre when approach a junction, to improve your visibility).
I cant really explain what ur ment to do when on a rounderbout all i know is this!!
I remember the OSMPSL on my CBT
https://www.motorcycle-training.f2s.com/tips.html
That site has quite a few tips! Thumbs Up
Dave
XJR400 Kenney Roberts Paint Job
sunbear
PostPosted: 12:57 - 02 Jun 2006    Post subject: Reply with quote
Yeah i know all that. But which side do you look over before going around a roundabout? As you have to curve left before going right around the bloody thing ! Shocked
krebsy
PostPosted: 13:23 - 02 Jun 2006    Post subject: Reply with quote
Stopped at roundabout - Going left.
Right check before pulling onto roundabout (to make sure no-one is coming or cutting past you) , left LS to make sure no-one is stepping out or cutting up the inside.
Straight on:
L+R checks to make sure no one is coming, cutting round you or up the inside, Right check on exit to make sure no-one is trying to squeeze into the lane with you.
Right turn.:
Right check before pulling off to make sure it's clear.
Left check passing each turn off to ensure no-one is pulling out on you.
as you signal left (past last exit prior to the one you want), Mirror check (L+R) followed by left LS check to make sure the space to your left is clear as you pull across to the exit, followed by R LS to make sure no-one is cutting round you...
There's probably a few more in there you need to do... Smile...
Just do loads. Smile
Mini roundabouts are odd as well. Same kind of checks but if the Roundabout is Offset to the left from the "main road" then you need to do a further R LS as you go round in case someone behind you has decided to go "straight on over the hump" and will broadside you as you come back over to the right after going round....
Etc..
Lots, often, whenever you are at risk of getting hit by something. Smile
Oh, and everytime you pull out to overtake (guilty of not doing it often enough myself Smile )
K.
1280 x 1024.
sunbear
PostPosted: 14:01 - 02 Jun 2006    Post subject: Reply with quote
Well put that was, easy to understand. Will forget half of them though Laughing
JBurrows88
PostPosted: 14:26 - 02 Jun 2006    Post subject: Reply with quote
wat he said!
Twisted Evil
lol
I got too lazy trying to remember when to check, BUT i think i should get into the habit of doing so!
Dave
sunbear
PostPosted: 14:45 - 02 Jun 2006    Post subject: Reply with quote
Yeah you would have thought me riding for 8 years would stand me in good stead for my das, but in reality i think it has built me up a whole lot of bad habbits. I dont use life savers half as much as i should and i cant remember the last time i practised a u turn or emegency stop Sad So i better get practicing Laughing
h00dwink
PostPosted: 11:54 - 03 Jun 2006    Post subject: Reply with quote
krebsy's got it for day to day riding, but it's a little different if you're wanting to know for a test.
will repeat what my instructor's drummed into me.
-on approach to round about, you do your mirror, signal blindspot, move to lane you need to be in.
-as your able to move onto the roundabout, you do a lifesaver to your LEFT, this is because your first move on the roundabout is always going to be left. so looking to your right to see nothing's coming could prove fruitless if you pull off at the same time as another rider on your left. Thumbs Up
-for whichever turning you come off at (well minus the first one, but you still need a left side life saver), as you've gone around the roundabout, you'll need to take a look over your left at least as you go past the last turning before your one. doing this is to give clear information to people behind you of your intention to do something. then indicate your turning, lifesaver and away you go.
if i remember correctly Razz
sunbear
PostPosted: 12:44 - 03 Jun 2006    Post subject: Reply with quote
So do you have to life saver over your right shoulder as you leave the roundabout?
MikeH
PostPosted: 13:11 - 03 Jun 2006    Post subject: Reply with quote
Yes, you should do a quick look either side, your right is incase someone is cutting round your inside. It should take a split second to do a quick left right look to back up your normal rear mirror observations, you need to be concentrating on whats going on infront too incase someone pulls out or lamps on the brakes so don't spend too long looking around admiring the local councils flower display Wink
I found when doing my DAS that it's easier if you talk to yourself through it until it becomes second nature. (Advice I got from here)
Mike Cool
Busa Junkie
phk6
PostPosted: 18:03 - 03 Jun 2006    Post subject: Reply with quote
ive been talking to myself while doing my a2 lol and i will continue to do so on monday and tuesday and even during my test
Current .. 2008 BMW R 1200 GS Adventure ..
Before .. 2003 Yamaha Fazer 1000 .. 2004 Kawazaki Z1000 .. 2003 Suzuki Sv1000s .. 1999 zx6r Track Bike .. 1999 CB 500 Cup ..
/Phil
sunbear
PostPosted: 11:56 - 04 Jun 2006    Post subject: Reply with quote
cool , cheers Thumbs Up
krebsy
PostPosted: 11:42 - 05 Jun 2006    Post subject: Reply with quote
Said I probably missed a few... Smile
K.
1280 x 1024.
coolfox1
PostPosted: 10:28 - 06 Jun 2006    Post subject: Rear check Reply with quote
I just go over board with them, right check always every chance I get, left when ever turning left either turn or off round about .
One easy one to miss is pulling out when moving out to over take parked bus, car, van etc and pulling back in.
As for mirrors turn your head to the mirror so he can tell your looking, easy ones to miss is after emergency stop, before setting off from lights and when entering a 30/40 zone etc
Ian
The last post was made 20 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 90.23 Kb
