How... [HELP] need to seperate fork sections
Cog Head
PostPosted: 12:10 - 02 Jun 2006    Post subject: How... [HELP] need to seperate fork sections Reply with quote
...do i get the bottom bit of the fork off the shiney bit ? Evil or Very Mad
https://img155.imageshack.us/img155/8371/dscn11312gh.jpg
https://img155.imageshack.us/img155/9623/dscn11301ox.jpg
and how do i get this rod thing out ?
https://img92.imageshack.us/img92/9826/dscn11325qc.jpg
The inside
https://img54.imageshack.us/img54/6010/dscn11332zl.jpg
**EDIT**
a break down of the fors section if this helps
https://img240.imageshack.us/img240/2125/file00016yh.jpg
Rieju RS2 50cc MATRIX Race Replica - Cagiva Mito 125 - VFR400 NC30
LukeVFR: Cog Head is a Karma whore Shifty
McGee: Hence I smell like a gimp
tatters
Exxon Valdez
PostPosted: 12:13 - 02 Jun 2006    Post subject: Reply with quote
Theres etiher a bolt underneth the bottom of the fork or one down the in-side at the bottom.
Cog Head
PostPosted: 12:14 - 02 Jun 2006    Post subject: Reply with quote
there was one in the bottom of the fork and iv removed that, and still cant get it out, at the bottom it looks like kinda sealed :S could it need a good wack ?
edd
PostPosted: 14:38 - 02 Jun 2006    Post subject: Reply with quote
I agree with tatters it should just drop out I think, consider that your forks seem to have had a battering, so they will be more likely to be a bit stuck.
Bluespark Automotive - Diesel Tuning for Performance and Economy
Cog Head
PostPosted: 15:24 - 02 Jun 2006    Post subject: Reply with quote
yeah there a bit bent forn a recent accident which is why there in bits. where the shiney bit meets the grey bit (sorry for the technical terms) there is no clean edge sort of thing, it look s lik the two pices have joined :S but i know that they come apart Evil or Very Mad
mattish
PostPosted: 16:43 - 02 Jun 2006    Post subject: Reply with quote
Im guessing bolt 23 is out ? If so its probably just stuck Confused
Cog Head
PostPosted: 16:47 - 02 Jun 2006    Post subject: Reply with quote
yeah 23 is out on both legs, iv sprayed some WD40 on it and given it a fair few slaps against the floor on different angles, iv tryed to knock the grey bit down too but nothing Crying or Very sad
Ichy
PostPosted: 23:33 - 02 Jun 2006    Post subject: Reply with quote
Try putting bolt 23 back in a few turns and giving it a tap with a soft hammer, you might need a drift. Sometimes the damper rod seal can stick a bit.
code guru
PostPosted: 00:24 - 03 Jun 2006    Post subject: Reply with quote
ok this is wot i done on my rs1, whould be the same as the rs2
taken the bolt from the bottom, took the black bit out from the top. took the circlip out ( then everythink pops out lol) and then thats it i think. the crome part just comes out if i rememeber right.
sickpup
Old Timer
PostPosted: 00:40 - 03 Jun 2006    Post subject: Reply with quote
USD forks I believe.
If soi follow Sickpups guide.
There are 2 types. The grub screw and the threaded.
A lot of Italian bikes have the Stanchions held into the knuckle using a 5mm grub screw in the knuckle which cuts into the stanchion. Any sticky out screws or allen heads that you can see?
Japanese bikes tend to take the threaded approach. The bottom of the stanchion will be threaded with eith a 1.25 or 1.5 thread but it's also glued in place.
I recommend weld some kind of handle to the old stanchion and cooking in a preheated oven at 50degrees or so for 20 minutes then remove, stick the knuckle in a vice and twist using the handles you welded on earlier.
You'll then have the prepared ingredients ready to reassemble.
Cog Head
PostPosted: 19:53 - 03 Jun 2006    Post subject: Reply with quote
rite there ok to be straitened with the bottom bit attatched, there in a bike shop in atherstone, they are charging me £15 per leg so £30, i was expecting a lot more to be honest, the guy said that because they are upside down forks they cant guarantee them cus the machine could crush them, which im quietly worried about.
thanks to you all for the help and advice, karma on the way Thumbs Up Mr. Green
sickpup
Old Timer
PostPosted: 23:42 - 04 Jun 2006    Post subject: Reply with quote
Thanks for the karma.
The last post was made 19 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 73.72 Kb
