| Star La |
 Star La Renault 5 Driver
 Posted: 21:11 - 15 May 2006 Post subject: NSR 125 Tomorrow - How to ride it? |
Hi.
I regret not taking a geared bike when i had my CBT last year because now it's come to a situation where I'm going to need to know how to ride a gear bike. (I've only got experience on automatics)
I'm expecting delivery for my NSR tomorrow so I would be very grateful if someone could advise how it works.
I know how to drive a manual car and I've been told it's easier on a bike but I would rather play it safe and erm..cool (incase anyone is watching)
So far I know to have it on Neutral then pull in the clutch and then hit either down or up, ?? -
I've used the search function and read that you can ignore the clutch for going down gears when on 4th gear for example. I don't think I'll do that just yet..
Thanks! |
| SilvaRizla |
 SilvaRizla Spanner Monkey
| Makaveli_Rydah |
 Makaveli_Rydah Could Be A Chat Bot
| butterob |
 butterob Spanner Monkey
| Star La |
| Smithy |
 Smithy Two Stroke Sniffer
| Star La |
 Posted: 22:53 - 15 May 2006 Post subject: |
Alright, Thanks for that - I'm confident I can teach myself - I know a very quite road so I'll be giving it a go around there.
I'll update this thread tomorrow.  |
| tokarev |
 tokarev World Chat Champion
 Posted: 23:07 - 15 May 2006 Post subject: |
Hi,
Pretty sure that it is 6 gears. Here is some quick tips to get you started (practice in an open space or somthing, you should pick it up after about 30 minutes to an hour).
Turn on ignition and make sure the green neutral light is on
If on then click down the gear lever to put bike into first whilst holding in the clutch (make sure sidestand is up before you do this or the safety mechanism will cut the bike off if you try and engage a gear whilst sidestand is down)
Give the bike some revs (say about 4000rpm) with clutch still held in
Start slowly releasing the clutch until you feel the 'biting point' - (where you can feel the bike just starting to pull)
You should then start moving off slowly, keep releasing the clutch slowly (otherwise it will jerk you forward) unitil it is fully out and you will be riding around in first gear.
To change into second let off the throttle, pull the clutch all the way in and click up on the gear lever once. Just release clutch and then continue to use the throttle.
To get back into neutral, pull in clutch and click down through the gears until cant go down any more. Then do a very slight upwards push on the gear lever to get into neutral (can be tricky as the movement has to be a light tap up)
Couple more tips, so you don't make the same mistakes I did!
Fuel Tap. OFF: Horizontal position means it is off and no fuel will pass. ON: Twist fuel tap clockwise until it is left ridge is vertical and then fuel is on and can pass. RES: Twist fuel tap anti clockwise until right ridge is vertical and you will now be on reserve. (There are markings on the fuel tap at the positions mentioned above; On, Off and Res).
Starting bike from a long stand. Make sure fuel tap is on and bike in neutral. Pull out the choke (on the left just under the tank) and then press ignition. Bike should start and revs will rise. Adjust choke to half way and the bike revs will be around 2-3k, then let the revs die down a little and put choke in/off. Blip the throttle a little to about 2k/3k to make sure bike doesn't die.
If you have just got off the bike and want to start up again then you wont need to use the choke, just use ignition and a few revs to start it.
Good luck!  |
| code guru |
 code guru Brolly Dolly
| code guru |
| jay_666 |
 jay_666 World Chat Champion
 Posted: 23:44 - 15 May 2006 Post subject: |
Code guru - its like this:
6
5
4
3
2
N
1
As its 1 down, 5 up but yeh, i know what you ment, just saves confusion. ____________________ CBT - Done | Theory - Passed | Test - 4th Oct [PASSED!]
https://www.bikepics.com/members/jay666/ |
| code guru |
 Posted: 00:06 - 16 May 2006 Post subject: |
| jay_666 wrote: | Code guru - its like this:
6
5
4
3
2
N
1
As its 1 down, 5 up  but yeh, i know what you ment, just saves confusion. |
yer soz 1 down 5 up lol |
| Star La |
 Posted: 12:56 - 16 May 2006 Post subject: |
thanks Tokarev, jay666 & code guru.
Well, I recieved my bike this morning at 7.30 - I was quite nervous as i sat on the bike having a look over the controls and such - I took the bike around back roads and practised slowing down, stopping and going off again.
I then proceeded to go on to the main roads during busy times - I stalled it about 4/5 times on my way to the physio but on the way back I didn't stall it which was okay.
I found it much easier to keep it at Gear 1 when I'm at the lights rather than kicking into N then back to 1 as it seems there is a thin line between 2 and N. - I still don't see why they couldn't of just put N at the bottom of the system. ? maybe i'll see why in a few months time.
I'm gonna ride it more later - The bike looks good and I feel comfortable on it - much better than the DNA.
Thanks for the help people, really appreciate it. |
| Bendy |
 Bendy Mrs Sensible
| Jamie. |
 Jamie. World Chat Champion
 Posted: 13:24 - 16 May 2006 Post subject: |
Just make sure when changing from first gear into second that you pull the gear lever right the way up so you dont go into neutral by accident, when I was learning to drive a motocross bike when I was around 10 that was my biggest mistake, and you DONT want to do that while going round a bend as its easy to topple over  |
| code guru |
 Posted: 15:26 - 16 May 2006 Post subject: |
i whent from a dna 2 an nsr. lol my dna woz a 125 and it woz heavy as fook nothink like the nsr. i love my nsr its much better in every way. yer when i picked my nsr from b'ham i had 2 drive all the way back 2 romford in essex 120 mil and i never been on a geared 125 before well i had but it woz a 4t a/c 125 crap thing and iv been out for like 5min on my rieju rs1. so it woz a big step doing 120 miles home but lucky my cuz lives half way in MK so i stayed there the night. and didnt even stall it once on the way 2 mk but i did on the way home  |
| StottyB |
 StottyB Trackday Trickster
 Posted: 12:00 - 04 Jun 2006 Post subject: |
I'm in the same situation as the fella who started this thread so thoguht it wasn't worth starting a new thread. Say i've put it into 3rd and i'm going 50 but i want to drop down to 20. What do you do?
When i drop it down the revs go way up, confusing!
My dads friend trains police riders so he's giving me a few lessons soon but i'd like to be comfortable with the basics first!
Thanks  ____________________ 2005 Gilera Stalker 50DT ---> 2003 NSR125R ---> **1999 Honda Hornet 600** |
| sunbear |
 sunbear Could Be A Chat Bot
 Posted: 12:35 - 04 Jun 2006 Post subject: |
50-20mph? I think it depends on the revs you have going. If you are in high revs and you drop down a gear the bike will slow down but the engine will not like it (will rev the eff out of it!) . Just tap the brake a little to let the engine slow down, then knock down a gear and let clutch out slowly  ____________________ Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT ! |
| StottyB |
| sunbear |
 Posted: 12:57 - 04 Jun 2006 Post subject: |
So the back wheel doesnt do anything stupid . If you suddenly drop a gear and let out the clutch immediately in high revs, the engine will scream its lovely little head off. I have had the back wheel lock up for a split second when i first started riding geared bikes through letting out the clutch too soon. Let the engine revs match the speed you are going  ____________________ Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT ! |
| StottyB |
| h00dwink |
 h00dwink World Chat Champion
 Posted: 14:26 - 04 Jun 2006 Post subject: |
using the engine break isn't totally the same as using it on a car. like, you're used to just being able to drop from 3rd to 2nd in a car, and little will come of it. you do that on a 125 at a fair speed, and you'll lock the back wheel, which if you're turning at the same time. will scare the shiz out of ya
when i first got on a geared bike, i didn't like it. having no prior experience. then i got a TAG 125, and got used to how the accelerator worked. then with knowing how cars gears worked, i managed to apply that to a geared bike. got one in january this year, took a few stalls but managed it fine within an hour and a half. ____________________ Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly |
| StottyB |
| sunbear |
 Posted: 18:13 - 04 Jun 2006 Post subject: |
You will get to know your bike . Give it time and take it easy untill you are totally confident  ____________________ Bikes had : BMW F650, suzuki tr50, gt125, SV400, GSXR600 SRAD. Honda CBR900RRP, CBR600FX, CBR1000F, VT600, Transalp 600, mtx125, nsr125r, CB500T, Yamaha fy50, tzr125, tdr125, XV535, Diversion 600, Fazer 600, TDM850 MK1 & MK2, Majesty 400, XV 1100. Cagiva mito evolution, Aprilia rs125, Piaggio x9 125. DNA 125 . Suzuki Bandit 600, GZ125 Marauder, RF600 , RF900RS2, Kawasaki ZZR400, ZX6R Ninja, ZZR600 . Ducati 750 Sport . Triumph Tiger 955i. CURRENT : 2004 Kawasaki Z750 and LOVIN IT ! |
| kn76cbr |
 kn76cbr Nitrous Nuisance
 Posted: 18:31 - 04 Jun 2006 Post subject: |
get that rear locking and wot good fun you will have round town! |
The last post was made 20 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
