2t rebuilds
SilvaRizla
PostPosted: 20:10 - 04 Jun 2006    Post subject: 2t rebuilds Reply with quote
Hi,
Why is it that 2t engines need to be rebuilt every now and again? Also, at what point would a rebuild be due?
Thanks
I'm Ivan Dobski the Meatsafe Murderer only I never done it, I only said that I done it so they'd take the truncheon out of my bottom
PostPosted: 20:16 - 04 Jun 2006    Post subject: Reply with quote
Any engine needs rebuild occasionally.
2 strokes suffer more because they have a worse lubrication system (crank bearings) and have dirty great holes in the bore (increases wear on the pistons and rings).
SilvaRizla
PostPosted: 20:21 - 04 Jun 2006    Post subject: Reply with quote
Thanks
I'll be buying a used one soon so are there any tell tale signs to look out for that might indicate a rebuild is needed?
PostPosted: 20:26 - 04 Jun 2006    Post subject: Reply with quote
Whine from the bottom end for the main bearings. Piston slap for the top end (or do a compression check).
The older lower powered 2 strokes (TZR125 / 250, RD350YPVS, etc) are far less prone to needing rebuilds often, until someone decides to tune the nuts off them.
SilvaRizla
PostPosted: 20:28 - 04 Jun 2006    Post subject: Reply with quote
StottyB
PostPosted: 21:05 - 04 Jun 2006    Post subject: Reply with quote
How do you do a compression check?
2005 Gilera Stalker 50DT ---> 2003 NSR125R ---> **1999 Honda Hornet 600**
PostPosted: 21:11 - 04 Jun 2006    Post subject: Reply with quote
Wait for it. The speaking the obvious answer. A compression tester.
Basically a gauge that connects up to the spark plug hole and you crank the engine over, with the gauge recording the compression.
StottyB
PostPosted: 21:53 - 04 Jun 2006    Post subject: Reply with quote
Finglonga
PostPosted: 22:11 - 04 Jun 2006    Post subject: Reply with quote
Eh Shocked
Andy Sez....
F.Y.Y.F.F.
NSR Mick
PostPosted: 22:14 - 04 Jun 2006    Post subject: Reply with quote
You replace the spark plug with the compression tester then kick / spin the engine over, the tester has a guage on it that will show you the psi achieved. Thumbs Up
RI_HA
PostPosted: 22:25 - 04 Jun 2006    Post subject: Reply with quote
So going on that theory then,
Is there a table or a guide on what to look for once the readings from the compression tester have been attained?
the lower the compression, a rebuild probably needs done?
rich
NSR Mick
PostPosted: 22:26 - 04 Jun 2006    Post subject: Reply with quote
Off the top of my head i think about 120psi is good.
RI_HA
PostPosted: 22:50 - 04 Jun 2006    Post subject: Reply with quote
Hmmm.
When i bought my bike, the chap said it not long had its 8k rebuild, probably be worth buying a little tester and seeing what the reading is, just to see if he was fibbing or not.
Rich
colin1
Captain Safety
PostPosted: 16:39 - 05 Jun 2006    Post subject: Reply with quote
it might be worth posting in the regional section on here, to find out if someone in your area has a compression tester
or see if there is someone near you on www.125ccsportsbikes.com
people who have a compression tester, dont get to use them very often, and love to get the chance to use it Smile
The last post was made 20 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 81.84 Kb
