problems with the freeby honda melody!
Jenks
PostPosted: 16:43 - 05 Jun 2006    Post subject: problems with the freeby honda melody! Reply with quote
Well, we got a few problems with the "Freeby" Honda melody...
First. When you manage to get it going (Fuel direct into carb) the carb blows? But if you suck the tube that goes towards the fuel tank, then it fuels fine. If you blow... Nothing.
And then if you get it going... It doesnt idol? It revs up up up.. then stays there....
Any help apreciated!
1978 MZ TS 250 1 Supa 5
1992 yamaha fzr1000 exup
1998 aprilia af1 sintesi
Jenks
PostPosted: 17:57 - 05 Jun 2006    Post subject: Reply with quote
Up to the top.
Anybody?
puremagic72
PostPosted: 19:30 - 05 Jun 2006    Post subject: Reply with quote
Youv'e posted this already?
https://www.bikechatforums.com/viewtopic.php?t=85083
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
Jenks
PostPosted: 09:00 - 06 Jun 2006    Post subject: Reply with quote
ah sorry mate, i didn't know how to find my old post :S and i coulden't see it.
mr jamez
PostPosted: 10:13 - 06 Jun 2006    Post subject: Reply with quote
You're not describing things very well dude.
So the bike runs when the float chamber is full, but it is not drawing fuel in from the tank? And what hose are you talking about? it could be a vacuum connection for the fuel tap on the 'prime' postion, if the Honda melody has this. Without the vacuum, it won't draw fuel from the tank and will also be sucking in extra air which my account for the revving itself up.
Jenks
PostPosted: 12:59 - 06 Jun 2006    Post subject: Reply with quote
well it doesnt have a fuel tap or anything...
But yes, if you fill the float chamber, then turn it over, it will start... And rev up.. then when its empty.. it just shuts of..
And yes, it won't draw fuel from the tank.
A quick Paint drawing to show what i mean.
mr jamez
PostPosted: 13:07 - 06 Jun 2006    Post subject: Reply with quote
Then it uses the vacuum to open the tap, sounds like you need to get the tubes hooked up correctly, or perhaps poke the fuel tap a bit.
Jenks
PostPosted: 13:12 - 06 Jun 2006    Post subject: Reply with quote
they are, secure as anything. But if you remove the pipe I said that it blows into.. and blow and look if anything comes out of the other side... it just dribbles...
Yet if you blow.... It flows really welll
And how do you mean poke the fuel tap abit? You mean put something into it??
mr jamez
PostPosted: 13:16 - 06 Jun 2006    Post subject: Reply with quote
Poke is the BCF technical term for pulling something apart and trying to fix it Wink
Jenks
PostPosted: 13:19 - 06 Jun 2006    Post subject: Reply with quote
Oh, I dont know how!
Can't even get it out of the tank! It's got a big metal rod going into the tank, with something attached to the top, too big to get out!!
The little flying saucer object is attached to the rod, so you can't get that out, and it seems like it's a solid object too!
mr jamez
PostPosted: 13:29 - 06 Jun 2006    Post subject: Reply with quote
So let me get this right, the hose at the top lets petrol through when you suck on the bottom hose which means the tap is working. Yet the bottom hose is actualy blowing rather than sucking.
So the problem seems to be that the engine isn't creating a vacuum (for the bottom hose to use) impossible! perhaps someone has put a different carb on without a vacuum take off? or are there any other outlets on the cab and you have the hose on the wrong one?
Seeing as it was a freeby, you could just tap into the vacuum from the inlet manifold if you can't get this sorted.
Jenks
PostPosted: 13:31 - 06 Jun 2006    Post subject: Reply with quote
the hoses are on exactily how they were before it stopped working.
Could the carb be plain nackerd?
mr jamez
PostPosted: 13:39 - 06 Jun 2006    Post subject: Reply with quote
Possibly? sorry but I have no idea why the vacuum outlet would be blowing. As the carb seems to work OK otherwise, may be worth tapping off the inlet manifold (like I said earlier) as it wont cost anything. Or getting a carb off ebay, which is a shame seeing as the bike was free.
The last post was made 19 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 76.64 Kb
