ZX7R Wheelie's
killa
Won't Shut Up
PostPosted: 09:51 - 06 Jun 2006    Post subject: ZX7R Wheelie's Reply with quote
First I must mention that through my biking years I haven’t tried a lot of stunts, I’ve done stoppies on my scramblers and had to repair rear shocks, I’ve wheelied my Aprilia Rx50 until the front seals went, I must admit they weren’t that impressive, probably due to the power.
I’m no good at stunting, I find that when I did manage to wheelie the VFR, it came down like a ton of bricks, I shat a brick because I didn’t like the feeling of going backwards and it worried me that I might have to repair something again.
Yesterday I was in town on the Kwak, it was very warm and she was running very sweet. Off of some lights I took it to about 15mph and dipped the clutch for a second with some hard throttle, the front came up but only very little. It felt good and the power kind of settled it down, I wanted to do it again because I thought I might have the hang of it, but when I tried either it was nerves or the technique, I couldn’t lift it.
I had the feeling that if it did come up I’d panic and smack the front down with the rear brake, or that the bike didn’t have enough power.
I guess I don’t know what the margin is for doing it right and holding the throttle steady once airborne, I think about losing the technique and giving it too much, resulting in me coming off the back of it.
Any advice?
Killa
www.125power.com
PostPosted: 10:15 - 06 Jun 2006    Post subject: Reply with quote
Sit further back on the seat than normal and lean back so your arms are perfectly straight, pull off as normal to save the clutch plates. As you get to 10-15mph accelarate hard. This should bring the front up pretty gently and you wont "fall back over yanking the bars as your already at arms length. If you get scared twist right hand forwards bike will drop straight back down. Also just before it hits the floor put about 1/2 to 3/4 throttle on this should give it a smoother landing.
My eBay Items
Dark
PostPosted: 10:27 - 06 Jun 2006    Post subject: Reply with quote
A standard ZX7R will not lift on power alone at any speed no matter where you sit, even yanking on the bars won't get her to lift more than a few inches.
The only way i could get my old one to wheelie was too get her up to 5,000 rpm in first, dip the clutch and rev her to 7,500 rpm, jab the back brake and dump the clutch. She would come up like a good un then. Then as the bike reaches the balance point back the throttle off to the 5,000 rpm position again and she will just sit there all day.
The balance point on the 7R for me was easier to percieve visually. I sat fairly upright and i knew i'd reached the balance point when i was looking through the screen at the horizon.
The throttle control is the key though, you need to be able to hold the throttle at 5,000 rpm without having to look, you should know axactly where that throttle position is. Next you need to know where 7,500rpm is, then you need to know exactly how much you need to turn the throttle to get from 5,000 rpm to 7,500 rpm. Get that ingrained in your hand and head.
So all you need is two throttle positions subconciously programmed in your head, a hefty jab of the rear brake, a controlled dab on the clutch and your away.
My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600
numark1
Scared of girls
PostPosted: 11:28 - 06 Jun 2006    Post subject: Reply with quote
I prefer this method now.........
2nd gear at about 30-40 rev the bike to (about 10 on my zzr) then dump the clutch. The front comes up nice and slowly at a very controlable rate. I then run out of steam at about 75-80 with the wheel still up (fuck up the gear change) then the wheel hits the deck. Laughing
quacker_boy
Cuddle Bitch
PostPosted: 15:37 - 06 Jun 2006    Post subject: Reply with quote
Clutchless shift you pussy Razz
Cillit-BANG
PostPosted: 15:45 - 06 Jun 2006    Post subject: Reply with quote
Any advice?
Don't do it round town. If your going to mess up, the chances are it will be in front of a lot of traffic.
Practice on nice quiet roads.
McGee
O RLY?
PostPosted: 15:54 - 06 Jun 2006    Post subject: Reply with quote
And if you do it in town make sure there are plenty of hotties to see you do it.
A lot may think what a wanker, but one will be wanting to rip her panties off for ya Wink
Its pronounced Jixxer!
Visitor Q
$25 whore
PostPosted: 15:55 - 06 Jun 2006    Post subject: Reply with quote
@ Dark
Maybe trying to get him to work the balance point etc in his first wheelies isnt the best idea Wink
@ Killa
Just in first, get to about 30, close throttle abit then pull it hard on.
Front will float up.
Dont get too cocky too early, as power wheelie tend to suddenly flip. But id imagine you'll enjoy getting used to the front in the air.
My advice, keep away from clutching it until you are used to getting the front up. Ive been off of biking since last summer basically (had a few weeks at easter mind you) cos of uni, and my wheelying is a bit pants now. So im sticking to power wheelies till i get abit more confidence back.
The couple of clutched ive done have been more ragged then a badgers arse.
Pogo crazy.
Dark
PostPosted: 15:58 - 06 Jun 2006    Post subject: Reply with quote
Good point Bonny, i may have neglected to say be careful and take is steady, but i'll be surprised if he could get it to lift without the use of the clutch.
Keep us posted Killa
Visitor Q
$25 whore
PostPosted: 16:01 - 06 Jun 2006    Post subject: Reply with quote
Well ive never rode a zx7, but i have an old school steel frame cbr 600 which i was adamant couldnt be power wheelied.
Now ive got used to it, worked out body position etc its a piece of piss. Im just working on not running out of revs.
But it sucks that the gearbox just WILL NOT change to second in mid air. And for anyone who tells me im not doing it right, ive managed it on 2 other bikes quite happily. The cbr physically will not do it.
numark1
Scared of girls
PostPosted: 16:04 - 06 Jun 2006    Post subject: Reply with quote
I would do powerwheelies until you get used to the front floating but they are amateur wheelies, too fast and not as controlled.
Clutch for the win. Although if you pratice loads you better learn how to replace clutch plates/ fork seals. Laughing
Dark
PostPosted: 16:09 - 06 Jun 2006    Post subject: Reply with quote
The ZX7R is very very front heavy. I did Jimmy Fireblade's wheelie school on my old one and he demonstrated how to wheelie my bike on my bike, which was very cool to watch, and he said that power wheelieing a ZX7R is nigh on impossible.
Clutching it up isn't anywhere near as aggressive as you'd imagine on the 7R, between 5000 and 7500 rpm its quite docile in fact, but once you add the jab of the rear brake it shoots up into the air nicely. Also the balance point is quite high compared to some other bikes i've ridden so it takes a bit more to loop it.
A mate of mine had problems shifting into second on his TL1000 and he found that he was rushing the change. He conciously throttled quite far past the balance point before he attempted the change and slowed the gear lever action down, by the time the change was complete the bike was had only dropped back a smidge below the balance point and it didn't take a lot of throttle input to get the bike to sit properly again.
killa
Won't Shut Up
PostPosted: 16:14 - 06 Jun 2006    Post subject: Reply with quote
Hmmm, i have tried the power wheelie, it does seem to just want to hug the floor.
I need to practice maybe at getting that torquey point where it wants to rag.
So would you guys say that the margin for error using the clutch is quite short?
I dont want to do it a couple of times and then just think 'F*ck it' and flip over. I guess i just dont know how hard it is to flip.
Thanks for your advice guys...
Sparks!
Sir Tart-a-lot
PostPosted: 16:15 - 06 Jun 2006    Post subject: Reply with quote
Dark have you definetly got your whole balance point perception down here?
If your mate throttled "quite far past balance point" he'd be on his arse... unless hes on the rear brake anyway.
Also sit down proper balance point you shouldnt be able to see over or through the screen usually, unless you're going very fast anyway.
my mate used to stunt a 7r, didnt do too bad on it but it wasnt the best for wheelying so he got a proper stunt bike instead Laughing
All depends on your speed etc..
PostPosted: 16:22 - 06 Jun 2006    Post subject: Reply with quote
Just start low with the clutch - rev a little, dump and it probably won't come up.
Rev a bit more, comes up a little.
Shouldn't end on your arse if you use common sense (which includes not dumping enough power through the clutch to get to the balance point first time Smile ).
Best to learn how to wheely properly Smile.
Dumping the clutch properly shouldn't do clucth plates in too much.
Dip the throttle before you get to the revlimiter, then pull it back on to the same position or more for a soft landing.
Sparks!
Sir Tart-a-lot
PostPosted: 16:24 - 06 Jun 2006    Post subject: Reply with quote
Also worth noting that hitting the revlimiter on the back wheel can cause bikes to self-destruct and explode Laughing
Dark
PostPosted: 16:27 - 06 Jun 2006    Post subject: Reply with quote
Hi Sparks!, i'm pretty sure i could still see through the screen whilst
at what i would call the balance point, granted it was only just and the front wheel obscured the vision a little.
The balance point as far as i know is where the front wheel is neither moving up or down at a constant throttle.
and ok, i agree, quite a bit past the balance point will result in looping the bike. It was probably a gnats c0ck past the balance point but it felt like quite a bit to my mate, its all relative.
Once you get the 7R up and balanced its great for fast wheelies, its just getting it there.
Sparks!
Sir Tart-a-lot
PostPosted: 16:30 - 06 Jun 2006    Post subject: Reply with quote
That's pretty much it.. only the revs shouldn't be rising at all if anything it'll get slower as shouldnt need much throttle..
nice one for wheelying a 7r.. seems a few people struggle with them for some reason..
Dark
PostPosted: 16:33 - 06 Jun 2006    Post subject: Reply with quote
Nice one, thanks. It took 4 years before i got the hang of it though Rolling Eyes
and now i'm struggling to get used to the ZX10R, its such a nervous little f*cker compared to the nice friendly 7R Confused
PostPosted: 16:42 - 06 Jun 2006    Post subject: Reply with quote
[quote="Sparks!"]
On some bikes you can be on a fairly constant wide open throttle and have the wheel at a fairly set height, but still be running out of revs.
I would describe the 'normal' balance point being the point that your revs and height are constant.
Of course, if you're flash, there's also a 'balance point' where the bike is balanced with the engine disengaged - clutch in, or in neutral. Have to be a tad good to do that, though!
Sparks!
Sir Tart-a-lot
PostPosted: 16:53 - 06 Jun 2006    Post subject: Reply with quote
Called a coaster.. not amazingly hard once you get used to rear brake.. I'm gonna try em' soon.. it will only stay up for as long as you have momentum though you can't just wheely along at a set speed with the clutch in.... I was getting hang of wheelying on idle so no throttle at all .. but it's kinda hard.. need to practice that more so can start no hand stuff... but once you get used to rear brake you can bring it up a bit faster than normal, go past BP and pull clutch in and ride it out on the brake with no power... easier said than done tho Shocked
I almost caught the idle in the vid but think I either had too much brake or the idles not high enough cos it almost stalled instead.. will get hang of it one day soon tho Cool
Nolongerhere
PostPosted: 18:10 - 06 Jun 2006    Post subject: Reply with quote
Killa I have a zx7r too! Power wheelie aint gonna happen the zx7r was designed for race and handles so well due to being fornt heavy! I have spokent o loads of 7r owners and they all say dont bother wheeling the 7 it doesnt like it and when u let it down it will generally go down harder than most. I have pulled wheelies on mine generally revving the bike fairly hard and dumping but compared to other bikes i have riden the 7r is not my 1st choice of bike to wheelie on the other hand fuck me does it handle!!! Thumbs Up Very Happy
killa
Won't Shut Up
PostPosted: 08:37 - 07 Jun 2006    Post subject: Reply with quote
K...Had a go last night on a country road, i did get the girl up a few times, granted i think they were a little fast because of the way i brought it up.
She definatly doesnt like the return to the tarmac, i might be able to perfect it but i think it is worth hanging back as i cant afford to break things.....
Cheers for the tips people! Wink Thumbs Up
Killa
Edit:- Just to add, what is it like bringing up a big twin, easier? harder?
Dark
PostPosted: 08:43 - 07 Jun 2006    Post subject: Reply with quote
The best way i found to land a wheelie on the 7R was to give it a big handful when its two thirds of the way down (if theres enough room to do it) that smooths the landing down.
I've only ridden a MilleR but that was very easy to wheelie, it was actually quite viscious in first, but seemed very contollable
The last post was made 19 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 136.89 Kb
