Radial Calipers
dainesefreak
PostPosted: 13:13 - 09 Jun 2006    Post subject: Radial Calipers Reply with quote
Anyone noticed increased brake pad wear over a standard setup? This might purely be down to the compound of the stock Honda items on this occasion, but I've only done around 4600 miles and am looking at having to replace the feckers. Never even thought about it on my last two Blades with a standard brake setup at this kind of mileage. I'm quiet progressive with my braking too, wouldn't say that I'm overly aggressive with them and I'm not a brake, brake, BRAKE, sort of rider.
Mr.Everready
PostPosted: 13:38 - 09 Jun 2006    Post subject: Reply with quote
I've not changed my pads in 10,000 miles.
Dark
PostPosted: 14:16 - 09 Jun 2006    Post subject: Reply with quote
I reckon nearly 5000 miles out of a set of pads is pretty good Confused
My Bikes in order:- Yamaha RXS100 / Suzuki X7 250 / Yamaha RD350LC / Kawasaki
KR1S 250 / Kawasaki ZXR750 H2 / Honda C50 / Kawasaki ZX7R P5 / Kawasaki ZX10R / Suzuki GSXR 400 / Honda CBR1100 Blackbird & Yamaha FZR 600
Superlight
PostPosted: 14:33 - 09 Jun 2006    Post subject: Reply with quote
Less than 5,000 miles for front pads doesn't sound good to me.
(Unless a lot of it was on track!)
I've just replaced rear pads at a bit over 5k (lots of filtering), but the front have got a long way to go.
I would've thought pad compound is more likely to be the culprit, rather than radial calipers.
Get some that aren't made from cheese Wink
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
dainesefreak
PostPosted: 15:10 - 09 Jun 2006    Post subject: Reply with quote
Honda OE pads are generally rated to be better than most after market pads so I'll be sticking the same in again. They are probably a softer compound than the last gen Blades then. The mileage is mostly country roads, so they are probably going to have been put through it more than slow A road/dual carriageway use.
What sort of mileage are you looking at then Dark? You would probably be the most comparable to me bike wise.
Dark
PostPosted: 09:24 - 12 Jun 2006    Post subject: Reply with quote
I've done 3,000 miles and i reckon i'm going to need some new pads pretty soon, my next service is at 4,000 miles so hopefully they'll last until then.
DucatiEVO
PostPosted: 13:49 - 12 Jun 2006    Post subject: Reply with quote
Got about 5500 miles on my Blade and the pads have plenty of life left in them. but the wear is all down to the rider and the roads they ride. I wouldn't worry about it, just change them as needed.
aKa: Ducky
PostPosted: 14:04 - 12 Jun 2006    Post subject: Reply with quote
Unless you're going for really expensive pads like Performance Friction, I wouldn't worry.
It may well be that radial calipers grip tighter, so use pads quicker (I believe one of the plus points is that you can use smaller rotors because they work better). Whether this should lead to increased wear specifically is another matter.
dainesefreak
PostPosted: 09:47 - 13 Jun 2006    Post subject: Reply with quote
Cheers all. Thought it was worth an ask, as I said, never got near changing pads on the 954's at this sort of mileage. Perhaps I'm getting more aggressive in my old age. Grrrr. Rolling Eyes Wink
The last post was made 20 years, 115 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 60.29 Kb
