Brake disk bolts
tatters
Exxon Valdez
PostPosted: 17:53 - 09 Jun 2006    Post subject: Brake disk bolts Reply with quote
I need to get hold of some new 8x25mm brake disk bolts (12 per disk) as most of the old ones had to be removed with a cold cheizel and hammer.
As far l can remeber brake disk and caliper bolts are high tensile steel bolts but l can,t find any metric ones at work we only have 316 stainless steel bolts (food/medical/marine grade) in all metric sizes up to 12mm, would they be safe to use them or will they not be able to take the shear load of a brake disk?
JGY6000
PostPosted: 18:53 - 09 Jun 2006    Post subject: Reply with quote
try https://www.hyperbolt.com/ top guys, there only round the corner from me but they post out stuff aswell and most of them are bikers!
tatters
Exxon Valdez
PostPosted: 20:10 - 09 Jun 2006    Post subject: Reply with quote
£4.70 per bolt Shocked
£4.70 x 30 = £141 Don,t think so Confused
JGY6000
PostPosted: 20:29 - 09 Jun 2006    Post subject: Reply with quote
thats becuase their titanium
Delvard
PostPosted: 22:38 - 09 Jun 2006    Post subject: Re: Brake disk bolts Reply with quote
What I've used these past 4months. Checked them often, so far so good.
A thing of beauty is a joy for ever: Its loveliness increases; it will never Pass into nothingness; but still will keep A bower quiet for us, and a sleep Full of sweet dreams, and health, and quiet breathing.
Superlight
PostPosted: 23:26 - 09 Jun 2006    Post subject: Re: Brake disk bolts Reply with quote
Don't forget the thread lock.
For next time, you might find a bit of careful blowtorching removes the need for the hammer and chisel. The aim is to melt the thread lock without melting the tyres!
You only need two tools: WD-40 and Duct Tape.
If it doesn't move but should, use the WD-40.
If it shouldn't move but does, use the Duct Tape.
edd
PostPosted: 23:43 - 09 Jun 2006    Post subject: Reply with quote
316 stainless should be easily strong enough for disc bolts. I totally agree those discs are a bitch to get off. Ive just been taking the discs off a thundercat wheel, and even wiht the aid of a blowtorch, penetrating oil, and a decent set of allen sockets 3 bolts are rounded Evil or Very Mad
Bluespark Automotive - Diesel Tuning for Performance and Economy
Superlight
PostPosted: 00:05 - 10 Jun 2006    Post subject: Reply with quote
Sure are a pain. A mate of mine broke one of my allen sockets changing a disc, but that was before we realised they were thread-locked!
I wouldn't want them coming loose while I'm riding though Thumbs Down
ZRX61
Victor Meldrew
PostPosted: 00:22 - 10 Jun 2006    Post subject: Re: Brake disk bolts Reply with quote
NO! Rolling Eyes
PostPosted: 00:55 - 10 Jun 2006    Post subject: Reply with quote
A 12.9 high tensile steel bolt has a tensile strength of 1200Mpa and will permanantly stretch at 90% of the proof load stress.
316 stainless has a tensile strength of 580MPa and will permanantly stretch at 55% of the proof stress. That makes your stainless bolts roughly equiuvalent to a grade 6.5 steel bolt.
At a pinch you could use grade 8.8 bolt to hold a disc on. It is probably more tolerant of cack-handed tightening (less likely to unscrew itself if you undertighten it) but would ideally be replaced after each use.
12.9 is more appropriate, 6.5 is way-out.
Slow to reply coz he has been educating himself about different grades of bolt and their properties. They say you learn something new every day, I was cutting it fine today though Smile
tatters
Exxon Valdez
PostPosted: 15:03 - 14 Jun 2006    Post subject: Reply with quote
I got a box of 100 Unbrako 8mmx25 Button Head Allen Bolts with a rating of 12.9 Thumbs Up today for £7
Saved me a few quid insted of buying titanium ones at £4.70 per bolt Very Happy
owdamer
PostPosted: 18:55 - 14 Jun 2006    Post subject: Reply with quote
I had that problem. I used my dremel to cut 2 flats onto the head so I could get a proper grip with the molies. worked a treat.
The bolts I took out were stainless ones. I think i'd fitted em years ago as the originals had a lot of surface rust and looked scruffy.
I've just fitted genuine yam ones to mine now. £29 for 18.
The last post was made 20 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 76.52 Kb
