Why oh why
PostPosted: 16:59 - 10 Jun 2006    Post subject: Why oh why Reply with quote
Do the Japanese not put a little more thought into the design of their bikes with regard to ease of servicing.
Just been changing the headstock bearings on my KLE. All set and ready with my new bearings, races, a selection of drift punches, hammers, chisels and blowlamp.
Whip the yokes out and set to with a cold chisel to remove the bottom bearing. It was a bit reluctant but a good roasting with the blowlamp got it shifted eventually.
Right. Now to tackle the races in the headstock. Hold on Confused there's no lip! The races are smaller in diameter than the centre tube of the headstock. There is absolutely nothing at all to get a tool onto to drive them out.
They aren't notched so I have left them in, the only way I can see to get them out is to weld a lip round the inside but my welder is broken.
Why oh why couldn't they just make the race a wee bit bigger than the tube it sits in?
iCraig
PostPosted: 17:02 - 10 Jun 2006    Post subject: Reply with quote
Don't blame the whole of the Japanese bike industry, just blame Kawasaki! Razz
tatters
Exxon Valdez
PostPosted: 17:11 - 10 Jun 2006    Post subject: Reply with quote
Even worst is that the exhaust on my Kawasaki FX400R that runs right under the oil filter chamber so you have to remove the whole exhaust to change the filter. Laughing
McGee
O RLY?
PostPosted: 17:16 - 10 Jun 2006    Post subject: Reply with quote
I get kinda pissed off with the fairings the way they are attached and trying to get them off on some bikes.
R6's are a complete bitch and so are thudercats I heard. Shocked
Its pronounced Jixxer!
Visitor Q
$25 whore
PostPosted: 17:36 - 10 Jun 2006    Post subject: Reply with quote
Try putting the carb block back on a cbr 600.
All the screws face the same way. Which means the last one is a foot ish away, through an engine.
Riiight
McJamweasel
BCF Junkie
PostPosted: 11:37 - 11 Jun 2006    Post subject: Reply with quote
But Honda have done the same as well, so thats at least half of the Japanese bike industry at it!
Jack_Cheese
PostPosted: 12:20 - 11 Jun 2006    Post subject: Reply with quote
That's clever design to the corporate bosses. If it's easy to service, you'll do it yourself, then the dealers lose out on money, and kawasaki could lose out on parts money.
They deliberately make things awkward, most machines are made only so the pros can take them apart.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
PostPosted: 13:37 - 11 Jun 2006    Post subject: Reply with quote
I just checked in the workshop manual. Changing the headstock bearings in a KLE500 requires a total of EIGHT "special" tools.
By designing the bike with the headstock inside diameter 2mm wider, you wouldn't need them.
Jack_Cheese
PostPosted: 14:02 - 11 Jun 2006    Post subject: Reply with quote
Time to bore it out?
Jack
fast_tzr
PostPosted: 14:06 - 11 Jun 2006    Post subject: Reply with quote
Derbi do it aswell. To get the casing off, one of the bolts is behind the frame, so I ended up having to undo all the engine mounts and move the engine a couple of centimetres to the right just to get one bolt out. Of course, to be able to move the engine, you had to remove the exhaust. From what i remember I ended up stripping about half the bike eventually! Shocked
And the worst thing is, it still needs putting back together again....
element
PostPosted: 19:56 - 11 Jun 2006    Post subject: Reply with quote
scooters are even worse. My speedfight is something else. To get to anything you have to take half the bike apart. To change the brake pads on the rear wheel you have to remove the exhaust (eventually found a way of avoiding that), remove the wheel, remove the caliper...
All the panels bolt to each other in ways ways that require more and more panels to be removed. Horrible to work on. I wanted a sports bike till I realised how difficult they can be aswell... I think my next bike after my DT will be a supermoto Very Happy
04' DT125RE (run-a-bout) // 89' DT125R (rebuilt + supermoto conversion)
SPARES FOR SALE. 2RK TZR // 82 DR125 // DT125R/E .... PM ME...
Itchy
PostPosted: 19:59 - 11 Jun 2006    Post subject: Reply with quote
didn't somebody once say? ,
a bike ain't a proper bike unless you can put you fist through it , that said though they look OK , classics would probably be more of a handful maintenance wise.
RascalsCustar...
PostPosted: 20:36 - 11 Jun 2006    Post subject: Re: Why oh why Reply with quote
Because it'd be just your luck and in keeping with 'FFS' trends, the lip would brake off.
The last post was made 20 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 82.06 Kb
