| jonboy22 |
 jonboy22 Crazy Courier
| syl |
 syl World Chat Champion
 Posted: 23:36 - 13 Jun 2006 Post subject: |
I thought about getting one of those, but you have to fill it up every 500 miles. How often do you have to lube your chain - not much more often than that. ____________________ Current bike: Kawasaki Z750S |
| White Noise |
 White Noise Mr Dudwee
| 0ddball |
 0ddball World Chat Champion
| fuzz |
 fuzz World Chat Champion
 Posted: 11:57 - 14 Jun 2006 Post subject: |
| dmahon wrote: | I thought about getting one of those, but you have to fill it up every 500 miles. How often do you have to lube your chain - not much more often than that. |
I only have to refill the reservoir after about 1000 miles. You get to alter the oil flow so you don't make a mess of your swingarm nor end up with a rusty chain.
The trouble with second hand kits is they have already been set for one bike - what if you want to put it in a different place but the vacuum/delivery tubes are too short? (You could buy replacement tubes, I suppose.)
You can but the parts separately direct from Scottoiler if you know what you need. It should work out a bit cheaper than off-the-shelf as you end up with loads of small parts not needed. And I do recommend the dual injector, it's so much easier to fit and adjust.
Before you fit one though, if you do, get all the rust off the chain first and relube as you would normally. The Scottoiler takes time to lube the chain, so you could be riding on a 'dry' chain for a fair few miles. ____________________ https://www.bikepics.com/members/fuzzbcf/
Bikes: '99 NSR125R, '00 SV650S, K1 GSX-R600, '97 CB500, K3 SV1000S, '16 VFR800 |
The last post was made 20 years, 144 days ago. Instead of replying here, would creating a new thread be more useful? |
