| motorbikes010 |
 motorbikes010 Two Stroke Sniffer
| tonyyzf |
 tonyyzf Brolly Dolly
 Posted: 08:55 - 16 Jun 2006 Post subject: |
Make sure you have the right grade of spark plug and get the fuel mixture checked, if its running weak it'll heat up and be in danger of seizing. ____________________ Something dark reddish with two wheels and cagiva written on the side
SS50, CB175, CB250N, CB350, CB750K2, DT250, CB750K1, CB750F1, XS1100, CB750F2, FJ1200, FZR1000, YZF1000, GSXR1000, Cagiva Navigator, Triumph Tiger 1050
https://www.cliqueyclanmcc.co.uk/ |
| 0ddball |
 0ddball World Chat Champion
| motorbikes010 |
| mr jamez |
 mr jamez World Chat Champion
 Posted: 11:27 - 16 Jun 2006 Post subject: |
Get the spark plug out and compare it to this, gives you a clue as to what the mixture is like.
https://www.spark-plugs.co.uk/pages/technical/diagnosis.htm
If the bike is running lean, you need to check that you have the standard jets and the collet is in the correct place on the needle, has an aftermarket exhaust been fitted? someone may have messed with the jetting. The lubrication system may be at fault, check the adjustment of the oil pump and you should have a nice haze of blue smoke when the bike is warm. ____________________ NSR 125F > BROS 400 > NC30 > BROS 400 > Trumpet S4 > '97 VFR 750 |
| motorbikes010 |
| motorbikes010 |
| robbie21mcn |
 robbie21mcn Nova Slayer
| 0ddball |
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 16:55 - 16 Jun 2006 Post subject: |
It might help matters if you told us why it melted the original piston & what was done (if anything) to stop this happening again with the new piston...  |
| motorbikes010 |
 Posted: 20:49 - 16 Jun 2006 Post subject: |
I dont know about that... I have a feeling the person I bought it from ran it without 2 stroke oil.
What I have done is I changed the 2 stroke oil to castrol TT. I re-adjusted the oil pump as I read in the manual. I ran the bike without the Cap on and let some bubbles come out from the system. There weren't many there, Then i turned off the engine topped the coolant level and then i took it for a 20 mile test ride. Went uphill and through traffic and all over oxford. The temp gauge was at the most on half.
The plug was checked and tightened. It seems to be fine now....
I was using sh1t 2 stroke before so it could have been that?
What do you think?
| ZRX61 |
| Vin |
 Vin World Chat Champion
| simon1221 |
 simon1221 World Chat Champion
The last post was made 20 years, 139 days ago. Instead of replying here, would creating a new thread be more useful? |
