| Rubix |
 Rubix Nova Slayer
| ZRX61 |
 ZRX61 Victor Meldrew
 Posted: 05:27 - 22 Jun 2006 Post subject: |
Remove the disc lock?  |
| Rubix |
 Rubix Nova Slayer
| Finglonga |
 Finglonga World Chat Champion
| doggone |
 doggone World Chat Champion
| GearboxGeezer |
 GearboxGeezer World Chat Champion
| MRX Steve |
 MRX Steve Could Be A Chat Bot
 Posted: 11:48 - 22 Jun 2006 Post subject: |
Once you've warmed you bike up pull your clutch in and hold it in for about 10 seconds, then put it into gear and to try ride off and it should work. ____________________ Rieju MRX 50 Castrol Edition |
| extreme3d |
 extreme3d World Chat Champion
 Posted: 12:05 - 22 Jun 2006 Post subject: |
Another simple thing to check, is your sidestand still down? You can often slip the clutch with the sidestand down so the bike starts to move, but as soon as you let the clutch all the way out the safety switch will cut the engine.
As to clutch plates sticking.... Try putting the bike in first whilst sitting on the bike. (You may have to rock the bike slightly to do this). Now release the clutch and the bike shouldn't budge. Pull the clutch in and the bike should move easily as though it were in neutral. It the plates were sticking the bike wouldn't move easily, even when the clutch lever was pulled in.
If so then ensure all sidestands, disk locks are removed and once the engine is started try getting it to move forwards with you feet before slowly letting out the clutch. Hopefully this forward motion will take some of the initial load off the engine.
Has the bike got a main stand? Or if you can get access to a paddock stand you can try running the engine and going through the gears very easily with the rear wheel then held off the deck (don't rev to fast though as with no load the chain won't like it!) |
| Rubix |
 Rubix Nova Slayer
| Rubix |
 Rubix Nova Slayer
 Posted: 12:57 - 22 Jun 2006 Post subject: Warming |
Once I have warmed up the bike, if I leave the clutch in and rev to around 4000rpm, and if I ever so softly let it out, I can take off with out a problem. But its initially take 15mins to warm the bike!!!
It also does this, when I have ridden for a little bit and put the bike into neutral whilst opening the garage door, it will stall if I go to take off again?
and yes the stand is up. ____________________ Zxr250R import / 2001 CR125 / YZF R6 2007 work done.
https://www.youtube.com/watch?v=25rNTRHH6mI
https://www.youtube.com/watch?v=dYnOSzqolig |
| Rubix |
 Rubix Nova Slayer
 Posted: 13:08 - 22 Jun 2006 Post subject: |
Many thanks to MRX Steve and extreme3d your posts have helped me
not fix the problem but more of an understanding of what is going on.
Rolling the bike a little before I start it (extreme3d) has helped heaps.
Thanks guys.
P.s thanks GearboxGeezer what do you do to relieve the problem? ____________________ Zxr250R import / 2001 CR125 / YZF R6 2007 work done.
| craigs23 |
 craigs23 Mr Muscle
| Rubix |
 Rubix Nova Slayer
| craigs23 |
 craigs23 Mr Muscle
| Rubix |
 Rubix Nova Slayer
 Posted: 13:31 - 22 Jun 2006 Post subject: |
When I bought (imported) the bike had to have Australian 2006 compliance , new plugs , leads etc even new tyres !
Nearly everything had to be changed for new, and my importer also
had to for compliance and registration laws.
Its in A1 condition , and only done 15,000 kms. ____________________ Zxr250R import / 2001 CR125 / YZF R6 2007 work done.
The last post was made 20 years, 122 days ago. Instead of replying here, would creating a new thread be more useful? |
