My Desmodromic valves, 56k beware.
Klause
PostPosted: 22:36 - 22 Jun 2006    Post subject: My Desmodromic valves, 56k beware. Reply with quote
Second time I've done them now but thought I'd share my experience's with you.
Abit of a mouth full but really is quite easy, just different.
https://img434.imageshack.us/img434/4803/valvediagram5cc.gif
Desmo valves push down on the valves and lift them back up, unlike your normal valve system that relies on springs to bring the valves shut.
This means there are two clearances to measure A and B in the picture.
A, being the opener clearance is quite easy to measure just like any other valve clearance check.
B, on the other hand is different, not so important either, aslong as the shim can be turned with finger pressure with some resistance then it's normally ok. If it's dead tight or moves way to freely then measuring will be required.
Anyway...
You take the inspection covers and find yourself this...
https://img68.imageshack.us/img68/7271/dscf00193lk.jpg
Just like the picture! Anyway you get your engine to TDC and measure gap A and feel the closing shim.
Gap A measures a little too small. Needs to be 0.15mm and my feeler guage won't fit in, 0.10mm feels a little too loose so I reck'n it's around 0.11mm. No problem! Means I don't have to buy shims, all I need to do is sand it smaller.
You take out a clip slide the rocker across and take the shim off the top of the valve, like so...
https://img423.imageshack.us/img423/7421/dscf00212gi.jpg
You go upstairs to a comfy chair and desk, measure the shim, then work out how much you need to take off it.
0.11 gap measured. 0.15 wanted
0.04 to take of
shim = 2.94
2.94-0.04 = 2.90
So I just need to sand it down to 2.90, I use an honing stone seems to work well and keep it even, used the smooth side to polish it off. I just keep measuring it every 30seconds of sanding to make sure I don't go past what I want.
https://img508.imageshack.us/img508/5183/dscf00178xa.jpg
https://img144.imageshack.us/img144/2615/dscf00163ly.jpg
I'm 18 and can do it, ok fair enough I've done a bike mechanics course, but they didn't teach us how to do this, just how it works.
https://img75.imageshack.us/img75/5751/dscf00229ph.jpg
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
Zimbo
PostPosted: 23:48 - 22 Jun 2006    Post subject: Reply with quote
Nice one Klause, it's nice and easy isn't it???
Klause
PostPosted: 00:19 - 23 Jun 2006    Post subject: Reply with quote
The first real time I checked them was on the 600 engine, and none of them needed doing, but as it was my first time I wasn't quite sure if checked them right. I did the 600's one again and one needed doing.
The 750 engine which I did today needed 3 openers doing. None of closers have needed to be done, listening to the chibba chabba of the monster forums this seems common.
The closer shim sounds harder because it's a variable gap really, because pushing agaisnt the spring force is variable. Hence why people go on if it moves by finger force.
Yes, in all it's easy, just like the cambelts, infact most of this engine is piss. Need to learn 4valvers next, might buy an engine to play around with.
*edit*
Ooo, a rating by kickstart, Cool .
garth
PostPosted: 10:25 - 23 Jun 2006    Post subject: Reply with quote
what's hiding under the covers in the last pic?
Italians just use big words to scare the owners into getting them serviced and anally raped by dealers Thumbs Up
Klause
PostPosted: 11:50 - 23 Jun 2006    Post subject: Reply with quote
1970's triumph daytona I believe. There's tons of bits/spares for it! Almost a stable full of it.
Desmodromics comes from greek words about control or something.
kat250
PostPosted: 12:04 - 24 Jun 2006    Post subject: Reply with quote
so how easy was it to change the engine? And was it the imi course you did?
in the famous word of jimmy pop "would you F*ck me for blow"
In the words of banditshigh "would you blow me to f*ck"
palmer
Fiddled Kiddy
PostPosted: 13:27 - 24 Jun 2006    Post subject: Reply with quote
Whats that in aid of then?
Klause
PostPosted: 14:20 - 24 Jun 2006    Post subject: Reply with quote
Quite easy, I few things I had to change but nothing hard.
IMI course? Nope. Motorcycle Engineering VRQ Level 2, level 3 next year.
Wave2k
G's Stalker
PostPosted: 15:12 - 24 Jun 2006    Post subject: Reply with quote
Can you do my Desmo valves Very Happy.
Ducati 1299 Panigale
2009 Corvette C6 z51
Klause
PostPosted: 15:42 - 24 Jun 2006    Post subject: Reply with quote
Wouldn't mind having a look at 4valve ones. But theres annoying fairing and probably coolant/radiator crap in the way. Got to love air cooled Thumbs Up.
Got a manual for yours yet? Wouldn't mind reading it.
Zimbo
PostPosted: 19:20 - 24 Jun 2006    Post subject: Reply with quote
I'd get them done by an expert mate, it's important they're right, money well spent.
PostPosted: 19:40 - 24 Jun 2006    Post subject: Reply with quote
I have a manual (916 & 748), but unfortunatly it is on paper and weighs a ton. Will try and scan it.
Klause
PostPosted: 19:45 - 24 Jun 2006    Post subject: Reply with quote
Nice one Keith, no worries if it's to much hassle.
PostPosted: 20:04 - 24 Jun 2006    Post subject: Reply with quote
Currently in Charlottes work desk waiting for a chance to play with the high speed scanner they have.
The last post was made 20 years, 82 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 85.57 Kb
