| jim |
 jim Derestricted Danger
| Scooby |
 Scooby Scrappy Doo
| jimmy |
 jimmy Guest
| McJamweasel |
 McJamweasel BCF Junkie
| jim |
| Kickstart |
 Kickstart The Oracle
| Scooby |
 Scooby Scrappy Doo
| jim |
| Kickstart |
| zaknafien |
 zaknafien
| McJamweasel |
 Posted: 15:49 - 12 Apr 2002 Post subject: |
Or Jim.
As in 'l Fix It  ____________________ BCF: Be yourself, just don't be an arse. |
| jim |
| Kickstart |
 Posted: 00:32 - 15 Apr 2002 Post subject: |
I would be tempted to pull the top end off the engine to check, but not sure how difficult that is on the DT. Also worth checking the reed valves (old RDs used steel reeds, which could prove expensive if they broke).
I have known 3 bikes have problems with the ignitions. One was the Gilera which basically shorted out the electronic rev counter. The 2nd was the RS, which is an unknown problem (I will find out when I have some known good bits to swap around), and the other was on an MBX125, and that might have been from using the wrong plug (Autolite kart race plug, when very well but fouled up quickly round town). On the first 2 of these I kept on getting a healthy spark, and the bike would run, but the Gilera would die as soon as you gave it any throttle.
Burning a hole in a piston is normally down to pre ignition of some type. Possibly as you say due to carbon build up (which gets hot enough to ignite fuel, plus takes up volume so raises the compression). However this is normally due to ignition timing being out or too high compression. Ignition timing can normally (on a 2 squeak) go out due to a fault in the ignition, or maybe it the rotor manages to more. The rotor is normally keyed to the crank, but the key can shear off allowing the rotor to move on the crank
Keith |
| Ropehead |
 Ropehead Guest
 Posted: 23:00 - 15 Apr 2002 Post subject: Bla Bla |
Jim i'v got some TZR. 1989 parts for sale as u probable know most parts are the same
All very tidy and in good working order:-
dtr 3db1 -88-89
tzr 2rk -87-89
- Wiring Loom.
- CDI unit.
- Generator & flywheel.
For a pic go to
https://www.findit.co.uk/motorbikes/parts/265429.htm
[email protected]  |
| jim |
The last post was made 24 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
